Another starlink question
Submitted: Monday, May 04, 2026 at 17:43
ThreadID: 152466 Views:1875 Replies:9 FollowUps:31
Hello,
I've tried searching and have even tried contacting starlink.
But because I don't have a account set up I don't seem to be able to contact them.
My question is if I buy starlink mini and use it for a trip of a month or so when I return home am I able to convert the roam plan to a residential plan?
William
Back Reply Expand Un-Read 2 Moderator
Reply By: Stephen L (Clare) SA - Monday, May 04, 2026 at 19:20
Hi William,
Simple answer is No, the Mini is sold as a mobile devise and not as a residential dish which are also bigger and permanently mounted.
AnswerID: 649199
Follow Up By: Member - William B - Monday, May 04, 2026 at 19:23
Thanks for that Stephen.
I was seeing if was possible because I'm over paying Telstra prices.
I'll have to look around for another internet provider. When I get back.
William
FollowupID: 930968
Follow Up By: Briste - Monday, May 04, 2026 at 21:46
I don't believe that Stephen is correct. You can use a Mini on a residential plan. If in doubt, check with the experts on Australian Starlink & LEO users FB group. The question has been asked and answered before, e.g. here.
I have a vague recollection that that may not have been the case when the Mini was first released, and it may not currently be the case in some other countries.
The issue with using it on a residential plan is that the router is in the dish and so will usually be outside to get a view of the sky, which may result in a weak wi-fi signal. This can be solved by plugging an external router into the Mini, as it has an RJ45 port.
FollowupID: 930970
Follow Up By: Stephen L (Clare) SA - Tuesday, May 05, 2026 at 10:13
First question Briste
Do you actually own and use a Starlink Mini?
To clarify my original reply, these are the only options on my own Starlink account for my Mini.
1 Complete Pause
2 Standby Plan $8.50 month, still using but slow internet
3 100gb/$80 month plan
4 Unlimited/$195 month plan
So if you have a mini, where did you get the home residential plan from.?j
FollowupID: 930971
Follow Up By: Stephen L (Clare) SA - Tuesday, May 05, 2026 at 10:34
Bristi
I stand corrected, Google say you can but the Mini is primarily for the ROAM plans but like I said above I only have those options
Perhaps you might have to contact Statlink
FollowupID: 930972
Follow Up By: Briste - Tuesday, May 05, 2026 at 10:46
Yes, I have a Mini. Currently on Standby as I am home in a major metro area at present. (I also have a Gen 3 without an active service plan - long story.)
I logged into my SL account - this was on the web, not via the app - and selected to manage the Mini, then selected to resume service, and was offered the full range of plans, including residential.
This was my understanding - that all dishes can access all plans. The one exception to this that I am aware of is that you can't activate a new dish on standby, but once the dish is linked to your account then that limitation is gone. I can reactivate my inactive Gen 3 straight onto standby - I just checked and was offered this option. I think this has also been discussed on the main SL FB group.
My only caveat is that I have never used SL on a residential plan. Is it possible that were I to go ahead and switch to a residential plan that I may get rejected? I don't think so. This question gets asked often enough on that FB group, and the commercial providers and installers who admin and moderate that group and who always seem to know what they are talking about consistently say that it's possible. Also, before I posted I did a search on the SL help site, and could find nothing to indicate a residential block on the Mini. Finally, FWIW, the usual AI searches (to keep Allan happy) say that it's possible.
FollowupID: 930973
Follow Up By: Briste - Tuesday, May 05, 2026 at 11:27
A further tip for William: if you want to run the Mini with an auxilliary router, e.g. at home, then this combined power and data cable will probably be helpful. Sold by various stores, but this mob have it in a range of lengths.
Don't forget to get a small voltage booster if you power it off 12V when travelling.
FollowupID: 930974
Reply By: North 200 - Tuesday, May 05, 2026 at 17:23
I use a mini when I’m travelling on the$80 plan then standby when home.
At home I have a Starlink set up permanently on the roof on a $69 plan, better service than the nbn. Starlink supply the house equipment for free.
AnswerID: 649203
Follow Up By: Stephen L (Clare) SA - Tuesday, May 05, 2026 at 19:05
Yes can vouch that our Mini is a lot faster than our home NBN
FollowupID: 930978
Reply By: Member - shane r1 - Tuesday, May 05, 2026 at 19:56
Screenshot of my Starlink options
Also you can activate a new Starlink anywhere (that you can get satellites) regardless wether it for roaming or residential
And I did activate my mini on residential when I first got it
Robbo
AnswerID: 649204
Reply By: Member - William B - Wednesday, May 06, 2026 at 18:28
Well I've pulled the trigger and brought a Starlink mini.
Now the games begin.
William
AnswerID: 649207
Follow Up By: Stephen L (Clare) SA - Wednesday, May 06, 2026 at 20:50
Well done William and you will not regret your purchase.
Do your research about setting up your phone and iPad/tablet to get the most out of low data modes that will use less data when using them.
There is one downside…….lol, they are continually doing software updates, but this does not come from your personal data and works perfectly on the $8.50 stand by mode.
All the best
FollowupID: 930980
Follow Up By: Briste - Wednesday, May 06, 2026 at 22:26
Congratulations. There is a Starlink Tips and Tricks document that gets posted on some of the FB SL groups. It explains a lot, including how the various plans work, and also how to minimise data use on the $80 roam plan. Worth getting for a new owner.
FollowupID: 930981
Follow Up By: Peter J4 - Thursday, May 07, 2026 at 08:23
The starlink will do updates even if fully disconnected and it is advisable to do so every month so that when you do want it to activate it has a good idea of satellite positions and what it's supposed to do.
There has been at least one occasion that I know of that starlink advised that if dishes weren't updated by XXXX date then they would be bricked.
FollowupID: 930982
Reply By: ExplorOz - David & Michelle - Thursday, May 07, 2026 at 13:49
Just sharing a bit of our personal experience/story with Starlink as long-term travellers, as most people these days understandably recommend the Mini, but our reasoning has ended up a bit different based on how heavily we rely on it for work.
We’ve been using Starlink since early 2023 and started with the Gen 2 - the motorised rectangular dish before the Mini arrived in 2024.
Starlink have been excellent to deal with. We had one very sad "operator error" incident with the Gen 2. We had packed it away in its storage area in the rear of the vehicle on top of the roller drawers - still connected to power, but forgot to put it into stow/packaway mode and shut it down properly.
It was sitting face down, still trying to orient itself and find satellites. As we're driving, we became aware of this strange whirring noise and kept wondering what it was - was it the trailer, was something rubbing, what was making that sound? By the time it clicked, it was too late. The motor was fried. I think it was my fault...:(
From a riverside camp at Owen Springs in Central Australia we used the Starlink online support form asking what we should do? Next thing we get a message back saying effectively "it’s shipped and on its way to your home address". Great customer service... except we weren’t going home for another couple of years! What a palava that became trying to redirect it and organise collection from a post office further along our travels. We had no real plan for where we would be, when! We eventually collected it in Townsville.
To be honest though, that whole experience taught us a lot about long-term travel logistics. Being able to predict and commit to being in one location on a certain date really isn’t in our DNA. Before our big 2023-2025 trip we were usually only away maybe 4 months at a time, so most things could just wait until you got home. But once you’re travelling long term, you quickly realise how important online ordering and freight logistics become. You work out systems pretty fast because eventually something always needs replacing, repairing or upgrading.
Interestingly though, the Gen 2 still technically worked. We just lost the auto-tracking motor function, so we manually positioned it ourselves and it connected fine. That actually gave us confidence that manually aiming a dish was perfectly workable in real travel situations. So when the Gen 3 arrived without auto-tracking, we already knew it was a practical and probably more robust solution anyway. The deal however was it had to send it back in the same packaging the new one arrived in.
David converted our Gen 3 to 12V pretty quickly because we spend long periods fully off-grid relying on solar. What we’ve found is that Starlink can start dictating campsite selection more than you expect. We were constantly chasing solar input to keep up with power needs, and ended up changing solar panel types - finding the iTech world soft panels less capable than the hard Kings panels! With our limited packing space, the inconvenience of that reality meant a bit of a packing adjustment but it was worth it. You also need a clear sky view for Starlink connectivity, so suddenly camp selection starts revolving around sun access and sky visibility. That can be tricky in places like Tasmania and Victoria with hills and trees everywhere. Much less of an issue in the deserts and outback areas of WA and SA.
Then we had another mishap... someone tripped on the cable and pulled the Gen 3 clean off the roof. It cracked the face of the dish. We taped it up because we were worried about water ingress if it rained, and that was over a year ago - it still works perfectly.
We’ve looked seriously at the Mini because the compact size is appealing for travel, but after comparing performance and our actual workload needs, the Gen 3 still suits us better. Since we run our whole business remotely through Starlink, reliability and throughput matter more than convenience for us.
There’s also the fact David built a pretty neat integrated router/setup around the Gen 3 system already, so changing to the Mini becomes more than just swapping the dish itself. It turns into a bigger and more expensive changeover than it first appears.
So at this stage we still haven’t decided whether, when the time comes, we’ll simply replace the cracked Gen 3 with another Gen 3 or make the jump to the Mini instead.
From our research, internet performance while driving generally won’t match a properly set up stationary dish, and we don’t currently run that kind of in-motion setup anyway. To be honest, part of the joy of outback travel for us is being offline sometimes. We actually like disconnecting for periods of time, then setting up properly and doing focused "work sessions" when needed rather than being permanently connected 24/7.
What’s surprised us most travelling Australia long-term is actually how good normal mobile coverage has become. We use Telstra and yes, there are still blackspots exactly where you’d expect them, but for general travel it’s often more than sufficient.
That’s also important for us because it keeps us testing ExplorOz Traveller in real-world conditions - offline for days, reconnecting later, syncing data, uploading reviews and photos, checking trip planning, updating Places, mapping work etc. A lot of the improvements through Traveller versions 8, 9 and now 10 came directly from solving those kinds of offline/online workflow challenges while travelling ourselves.
We’re definitely not typical users though - we basically run our full office remotely from the road, including app development and mapping work. For casual travellers, the needs are probably very different. Each to their own.
Thanks if you stuck with my long story this far - Michelle ;)
Hopefully I haven't made too many technical errors in my explanation as I'm not the technical expert.
AnswerID: 649208
Follow Up By: Briste - Thursday, May 07, 2026 at 22:36
I upgraded from a Gen 2 to a Gen 3 for ease of travel and improved performance. I considered the Mini, but was prepared to pay the price of increased power consumption to get better performance, esp in areas with trees.
I had some (self-inflicted) issues with the Gen 3 while travelling, and while SL replaced it when I was in a position to receive a replacement, the only option at the time to maintain connectivity was to buy a Mini.
I'm staggered about how well it performed, and as a result I question whether a Gen 3 is really necessary for travel. I haven't done an exact A-B comparison in a location with obstructions, but the Mini with the latest firmware did pretty well, and I had no problem getting decent speeds (I seem to recall that in the early days of the Mini it was speed limited).
Is there anyone who has actually found that they *need* the performance of the Gen 3 when travelling because the Mini wasn't good enough?
In-motion use is possible with both, but it's easier with a Mini, as there are stacks of mounts.
FollowupID: 930985
Follow Up By: ExplorOz - David & Michelle - Friday, May 08, 2026 at 10:51
Briste - interesting! Thankyou, that is a good reference point for consideration. May still revisit this then.
FollowupID: 930989
Follow Up By: Member - shane r1 - Friday, May 08, 2026 at 21:05
Our mini is working very well , just flat mounted on the roof rack.
Speedtest now just south of Balladonia 339 down 43.5 up
Shane n Jenni
FollowupID: 930992
Follow Up By: Briste - Friday, May 08, 2026 at 22:37
Can't complain about that! I have seen similar.
The big attraction for me of the Gen 3 was that it is supposed to be able to track more than one satellite, hence the higher power consumption. If that's correct then it should perform better when there are unavoidable obstructions.
But my reading also suggests that the latest Mini firmware is more tolerant of obstructions. If that's correct then the $64 question is just how much difference is there between them in practice with obstructions? In my use to date I haven't really seen the Mini struggle. If the opportunity arises I might try and do a comparative test.
FollowupID: 930993
Follow Up By: Member - LeighW - Wednesday, May 27, 2026 at 17:46
Currently at carnarvan gorge parked under tree cover. Gen 2 dish is unworkable, showing obstructions everywhere working on and off. Gen three mounted in same position shows a lot of obstructions but works much better with the occasional drop out.
Young girls beside us were setting up an mini, I asked them how it was working and one said it was going ok and they had been streaming. She then made the comment I hope it works with the cloud cover rolling in?
Interstingly starelink worked ok till we got to somewhere I can't remember but a bult up area it was. Then at 6PM or so the speeds dropped to 0 and no service. I logged a ticket with starlink and they indicated the cable was faulty even though speeds started around a 350 megabit and then quickly dropped to zero. I cranked up the gen 2 when we got to Carnarvan and after a couple of days I thought I'll try the gen 3 again, no problem works fine. Starlink were throttle my service so much where we were previously that it was unworkable. I can understand them throttling a roam sevice to give priority to fixed installs but when I'm paying more for a roam service I expect to get some service, not zero. If they keep throttling to the ponit of no service then its pointless having starlink roam.
FollowupID: 931045
Follow Up By: Briste - Wednesday, May 27, 2026 at 19:14
I assume you're at the Big 4 at Carnarvon Gorge, formerly Takarakka Bush resort, rather than up the top in the open area with the views. That would really test a SL dish. I was last there four years ago, before I bought my first dish, a Gen 2. IIRC there is Telstra coverage there? Interesting that the Mini was doing ok, but it depends a lot on where you are relative to the trees. In my experience you don't need a huge gap in cover, but you do need a small gap in roughly the right direction.
The Gen 2 cables are shockers. I had that first dish replaced by SL due to cable issues.
Which Roam plan are you on? Sounds like what you'd expect on Standby.
FollowupID: 931046
Follow Up By: Member - LeighW - Friday, May 29, 2026 at 16:45
Yes Big4 resort, Telstra cover is bad. Doubt cable was faulty as it still working ok since we got here. I don't think the young girls had any success with their mini as the next night they purchased fire wood and sat around the fire till late then webt to bed.
FollowupID: 931048
Follow Up By: Briste - Friday, May 29, 2026 at 18:19
Yes, I had a similar experience a few years ago with my old Gen 2 up at Lake Catani on Mt Buffalo, where there is a lot of tree cover over some campsites. My understanding is that since then, SL have updated the firmware to make dishes more resiliant under obstructions. Not sure whether that applied to the Gen 2.
One advantage of the Mini is that you can run it off a small battery, and thus move it to an area of better reception, rather than be tied to where the 4WD or van is. I have an adaptor to run it off a Makita battery, but there is a range of options. (I guess you could also move the 4WD). The Mini actually has a better wi-fi range than even the Gen 3 (I have both and ran a test), so you'd surprised just how far away you can position the Mini. Dish security may be an issue in some locations.
FollowupID: 931049
Follow Up By: Member - LeighW - Saturday, May 30, 2026 at 17:22
Been monitoring power usage of the gen 3, it is averaging 26W. Dish security, why would anyone steal one when they cant use it?
FollowupID: 931050
Reply By: Briste - Thursday, May 07, 2026 at 22:40
You learn something new every day. Today I learned that you CAN activate a new dish onto Standby, if you know how. See here.
AnswerID: 649210
Follow Up By: Member - William B - Friday, May 08, 2026 at 08:32
Hi Briste,
That link doesn't seem to work.
Maybe Elon has jammed it.
William
FollowupID: 930986
Follow Up By: Briste - Friday, May 08, 2026 at 09:07
Shoot! Sorry about that William and others. Try this.
(I suspect the problem came from using a link generated inside FB.)
There are a lot of good magmetic roof mounts available for the Mini. The Dishy Mini Mount is very popular so I bought one. Happy with it so far, but there are plenty of good ones out there.
FollowupID: 930987
Follow Up By: Peter_n_Margaret - Friday, May 08, 2026 at 10:40
Most plastic (including fibreglass) and glass is transparent to the Starlink signal and the antennae can sometimes be mounted INSIDE the roof of the vehicle for better protection.
FollowupID: 930988
Follow Up By: Briste - Friday, May 08, 2026 at 12:24
I tried an internal mount under my Prado's sunroof, but found that when stationary in full sun the Mini got too hot and ceased working. I too had thought that an internal mount would be better. Perhaps that mount held the dish too close to the glass, but decided to mount outside rather than try other under-sunroof mounts. I doubt that that the metal sections of the roof would allow any other internal mount options.
I bought the Dishy Mini Mount with the optional perspex screen for improved protection. It has a sufficient gap between the dish and cover for cooling.
FollowupID: 930990
Follow Up By: Member - William B - Friday, May 08, 2026 at 20:40
Unfortunately Briste I had already connected it.
Bugga.
I had ordered a mount from Amazon to mount it to my roof rack.
When it arrived it was a 3d printed one that was of very poor quality and it didn't sit properly and one of the bolts seized and broke.
I've returned it and found a 3d design on the net and printed my own. It's better and I saved myself $129.
William
FollowupID: 930991
Reply By: Member - nick boab - Tuesday, May 12, 2026 at 07:37
Starlink mini power up
by Jasonoid a solid youtuber .
I thought this YouTube video from Jasonoid that came up on my feed maybe of some interest to some starlink users .
AnswerID: 649216
Follow Up By: Stephen L (Clare) SA - Tuesday, May 12, 2026 at 08:44
Not a fan of plugin cigarette lighter units, seen too many fail and cars wiring is not designed for those high power outputs, damaging the wiring and sockets.
So what happens if you want to go hiking, you can not power your mini with these units.
There are many portable power supplies available that will fit into a backpack that will run your mini for many hours, including my latest purchase from CTMODS, very small inbuilt power supply/tripod that will run your mini for up to 8 hours.
These CTMODS power banks/tripods are brilliant
FollowupID: 930994
Follow Up By: Allan B (Sunshine Coast) - Tuesday, May 12, 2026 at 18:42
What is it with these people?……..
……. "45,000mAh"?? ….. That's like saying the creek crossing was 45,000mm wide.
It is 45Ah dammitt.
It is yet another con job, trying to make you believe the product is larger than its reality.
I am so sick of constantly being conned, duped and hoodwinked by salespersons.
7
FollowupID: 930995
Follow Up By: Member - David M (SA) - Wednesday, May 13, 2026 at 09:56
Allan. It is surprising that you are still being "conned, duped and hoodwinked by salespersons." :)
Dave.
FollowupID: 930998
Follow Up By: Allan B (Sunshine Coast) - Wednesday, May 13, 2026 at 10:36
Ah Dave, constantly I'm afraid. And also by politicians and health advisers.
My vulnerability seems to increase at a greater rate than my age.
And my tolerance decreases at the same rate.
Anyway, I thank Stephen for bringing this gross ineptitude to my attention and I emailed the advertiser (CTMODS) and respectfully pointed out their error. I'm sure they will be grateful for the advice and correct it immediately.
FollowupID: 930999
Follow Up By: Member - William B - Wednesday, May 13, 2026 at 15:49
Hello Allan,
Please look out your windows and let me know the colour of the pig flying past please.
William ??
FollowupID: 931003
Follow Up By: Allan B (Sunshine Coast) - Wednesday, May 13, 2026 at 18:39
Hi William,
I just got home to view your request……
I looked out of my window but can't see a thing…… it's totally dark. Sooorrry.
FollowupID: 931004
Reply By: Briste - Sunday, May 17, 2026 at 08:54
Starlink have just announced across-the-board price increases. The $80 roam plan is now $85 and the $197 plan is now $210. Not big increases, but Standby has the biggest percentage jump, from $8.50 to $15.
AnswerID: 649236
Follow Up By: Member - William B - Sunday, May 17, 2026 at 21:07
Blast!!!! Typical for me
FollowupID: 931025
Reply By: ExplorOz - David & Michelle - Thursday, May 28, 2026 at 12:55
Ok so we listened and we bought a mini and have it fixed on roof so fulltime connected. Its going brilliantly. Still have the Gen 2 on the same plan if we need wider coverage at camp etc. Didn't need it last night - mini was fine.
David has the mini connected to the same router (inside the wagon) we use for the Gen 2 so that improves the Wifi range. He made his own brackets on the 3D printer.
AnswerID: 649272
