Friday, May 15, 2026 at 09:35
Hi Peter,
My habit has been to leave the
water pump on at all times except during storage. recent events have caused me to reconsider that.
1) Several weeks ago the poly line from the
water mains to our house meter ruptured but was quickly noticed and caused no damage other than a crater in the garden until the
water supply authority repaired it.
2) More recently we returned from a week away from home to find
water on the kitchen floor. A braided hose to the sink mixer had a pinhole leak. Luckily, it was limited flow and appeared to have occurred shortly before our return and no permanent damage occurred. But it may have been a different story if our holiday had been for a longer period.
3) Several months ago a couple of our friends came home from an extended vacation to find their entire home flooded. A
water connection within the kitchen cabinet had incurred a major rupture. Extensive structural damage had occurred. They needed to evacuate their home for months and now it has been found so substantial that the insurers are considering demolishing the house.
4) Some years ago my sister incurred significant house damage due to a
water leakage in the ceiling during their absence. It was an interesting fault but I won't detail it here.
So I have now resolved to turn off the van pump when vacating. There is an accessible switch that isolates the pump and the supply to the LPG HWS. Incidentally, that switch was provided in order to be able to isolate the pump in the event of an exhausted
water supply as the pump would continue to run continually. Shutting off the LPG may also be considered but not quite a simple as flicking a switch at the exit door.
And in the home, I think that I will turn off the
water at the meter whenever we leave for more than a couple of days. The electrical
power needs to remain on for refrigeration but is less risk due to the RCD protection.
931017
