Plan check before I buy: solo full-timer, working online, under 3.5 t
Submitted: Friday, Nov 13, 2026 at 10:21
ThreadID: 154318 Views:462 Replies:3 FollowUps:1
Hi all. I'm planning to live full time in a self-built vehicle on a car licence, working online most days with client video calls. Nothing is bought yet. Before I lock the plan I'd value criticism from people who've done it, especially through UK winters.
The plan in short:
- Weight: designing to 3,300 kg loaded, 200 kg under the 3,500 kg limit. Build, kit, water and me come to about 1,060 kg, so I'm after a base of about 2,240 kg or less empty.
- Power: 920 Ah lithium (two 460 Ah, inside the heated space), two 50 A DC-DC chargers, about 430 W of roof solar, and a Victron MultiPlus 12/1600/70 for hook-up. Winter plan: about 4 hours of driving a week plus one hook-up night. I estimate 1.4 to 1.8 kWh a day.
- Heat: a 2 kW diesel air heater, fitted by an installer. Backup: a separate 100 Ah battery for it, a -10 C sleeping bag and two CO alarms.
- Water: a 70 litre tank inside and two 20 litre cans, with a filter tap. Grey water goes in two 38 litre portable containers kept inside. No fixed grey tank.
- Separating toilet with a fan. A 2-ring gas hob on a 7.5 kg refillable bottle, with a spirit stove as backup. An upright 12 V compressor fridge.
- Shower: a portable pump shower with kettle water, plus a gym membership.
- Internet: a 5G router on two networks with a roof antenna, Starlink Mini as backup, and bonding on the laptop.
- Bed: a fixed double across the back, with a swivel seat and a desk I can use with the bed down.
Questions:
1. What would you cut or add?
2. Is 920 Ah with 4 hours of driving and a weekly hook-up enough for a UK winter while working?
3. Has anyone lived with portable grey containers and no fixed tank? How did it go?
4. What do you regret about your layout or kit?
5. Did your build come in heavier than planned, and by how much?
Thanks in advance.
Reply By: Member - John - Friday, Nov 13, 2026 at 11:50
Will, as this is an Aussie site, I doubt the answers you will get will be of value to you, especially for UK Winters....... Good luck with your build and your travels.
John and Jan
AnswerID: 649767
Reply By: Member - McLaren3030 - Saturday, Nov 14, 2026 at 08:26
Hi Will H7,
Firstly, this is an Australian Site, so perhaps you may be trying to compare “apples with oranges” as to the information we can provide. The only comparable parts of Australia to the UK would be Tasmania with a similar distance from the Equator.
What do you estimate your daily power requirements will be? Will you be using a microwave oven or electric kettle/jug or or an induction cooktop, or Airconn? Any high power electrical appliances, particularly those with a heating element, will drain your batteries very quickly.
Rule of thumb with Solar capacity vs Battery Capacity, is that for every battery AmpHr you have, you need double the watts of solar capacity. You are not even close with your current set up. One thing you need to understand, is that in the real world, solar panels only give you between 50% to 70% of their rated output. When rating solar panels, manufacturers use “laboratory conditions”, that is the light source is at the perfect angle to the panel, something that is not achievable, particularly in the UK. Given your location is the UK, and the angle of the sun to your latitude, you will be lucky to get even 50% of the rated capacity, particularly in the northern UK. You also state that you will rely on only 4 hours driving per week as additional charging. Even 4 hours driving per day is unlikely to to do very much in the way of keeping the house batteries charged., particularly if they are below 50% SOC (State of Charge). You will definitely need to be connected to a mains power supply every night.
Does the vehicle you are building have a “smart alternator”, that is an alternator that detects the voltage of your cranking battery, and then drop its output when the cranking battery is back up to full charge? If so, your alternator is definitely not going to put enough charge back into your “house batteries” in 4 hours. You can compensate for this by connecting the power supply to your house batteries from your vehicle cranking battery via a VSR (Voltage Sensitive Relay). This will ensure that there is a “drain” on the cranking battery to keep the alternator at full capacity, but cut the power to the house batteries if the voltage of the cranking battery drops below a certain value, thus protecting the cranking battery from being discharged to a point that you are unable to start your vehicle.
AnswerID: 649770
Reply By: Peter_n_Margaret - Saturday, Nov 14, 2026 at 09:27
Hi Will. Quite a challenge you have there.
Like the previous posters, we will struggle to offer relevant experience to your plan.
Margaret and I have spent 18 months touring Europe (3 x 6 month expeditions), in a self contained motorhome, including a couple of months north of the Arctic Circle, but not in winter, so that will leave out some very important areas of consideration from our experience.
We did spend some time touring in northern England in winter once, but not in an RV, so not relevant.
Firstly, I think your chances of staying under the 3,500kg limit are most unlikely, but it is a worthwhile target. We were about 4,500kg in a 6m sandwich panel (50mm of polyurethane foam) 20 year old Iveco (15 years ago).
We had similar solar to your plan (I added more after we purchased the vehicle), but much less battery capacity. I was surprised how well the solar performed. Fridge loads are lower at lower ambient temperatures and in summer north of the Arctic Circle the days are very long. Winter would be a different challenge entirely. You can not have too much solar.
We carried 2 x 12kg (?) gas bottles and cooked on gas. Less would have been OK, but 2 bottles provide some flexibility when the first runs out. They were inside the insulated habitat area (but sealed from it) and had heated valves.
Our central heating was circulated hot water powered by gas, but we rarely need it. The same system provided hot water. I think diesel would be preferable for both. I don't see a need for a seperate back-up battery. Diesel heaters are not big power users.
In Oz, we can charge our Li house battery direct from the (non smart) alternator, without a DC-DC unit. The 85A alternator provides 14.2V which is ideal and delivers 45A charge to the house, almost from idle.
Good luck.
OKA106 motorhome
AnswerID: 649771
Follow Up By: Peter_n_Margaret - Sunday, Nov 15, 2026 at 09:27
I forgot something that might be relevant to you, depending on your budget.
Because we were quite uncertain about our power requirements, we purchased a second hand Efoy methanol powered fuel cell from a friend in Europe.
https://www.efoy.com/
What a brilliant bit of kit :)
This one was quite small, both in physical size and in output.
It was 75W output, which does not seem very useful, but it can deliver that 24 hours a day, so that adds up.
It made about the same noise or less as a compressor fridge and the waste products were a little bit of CO2 and some pure water (which could be run into the RV water tank).
It was installed inside the van, under a seat.
It used pure methanol for fuel and produced about 1kWh of power per litre of fuel (from memory) which was used directly to charge the batteries.
We used it for a while when our AGM batteries failed and it saved our lives.
I wish we could have brought it home, but it could not be put onto an aircraft because there might have been remnants of methanol still inside.
FollowupID: 931678
