ARB or TJM side steps and rails
Submitted: Tuesday, Aug 17, 2004 at 11:53
ThreadID: 15626 Views:5560 Replies:5 FollowUps:5
Has anyone checked out both brands of side steps and rails (steel) for a GU patrol and found one or the other to be better?? The price is the same from them both and am not in a position to look over the items personnally.
Reply By: Well 55 - Tuesday, Aug 17, 2004 at 12:17
I guess if you have ARB bar on go ARB. Same for TJM.
AnswerID: 72928
Follow Up By: Austravel - Tuesday, Aug 17, 2004 at 12:18
Thanks but it's a Nissan bar so I could go either way.
FollowupID: 333054
Follow Up By: Well 55 - Tuesday, Aug 17, 2004 at 12:23
Then check to see how they attach. The side bits of the Bull Bar need to be vertical and a measured distance for the rails to attach properly.
You will have to check that with the supplires.
FollowupID: 333057
Follow Up By: Member - Paul J (ACT) - Tuesday, Aug 17, 2004 at 12:31
Hi Tony, "not post related" but how long did the snow last out at your property, was heaps around your area as we left your gate.
Paul....
FollowupID: 333060
Follow Up By: Well 55 - Tuesday, Aug 17, 2004 at 12:48
It lasted in the shade areas till late that afternoon, damm cold out on the horse.
FollowupID: 333061
Reply By: Leroy - Tuesday, Aug 17, 2004 at 15:17
I wouldn't go the ARB as i have seen them come into contact with the sill on a GU. Haven't seen the TJM bars.
Leroy
AnswerID: 72955
Reply By: Bonz (Vic) - Tuesday, Aug 17, 2004 at 17:30
Ths Nissan bars are the same as the ARB one I have been told/seen. Have also seen the ARB side steps hold the whole weight of a 80 series and not deform at all. I would go the ARB stuff myself.
AnswerID: 72970
Follow Up By: Leroy - Tuesday, Aug 17, 2004 at 23:24
but the man has a gu not an 80 series!
Leroy
FollowupID: 333198
Reply By: ginga - Tuesday, Aug 17, 2004 at 17:38
Hi Austravel
If you are in or around Sydney, there's a chap called Col Mawbey (02) 9548 2727 who makes 'Col's Super Steps'. They are heavy duty steel & are priced at about 1/2 the price of genuine Toyo side steps; & they work!!!
Worth a call if convenient for you.
AnswerID: 72972
Reply By: Austravel - Wednesday, Aug 18, 2004 at 08:20
Thanks all for your comments and suggestions.
AnswerID: 73049
