Are used TD Discos any good?
Submitted: Wednesday, Aug 25, 2004 at 08:22
ThreadID: 15806 Views:2627 Replies:6 FollowUps:2
A mate of mine is looking at a 2nd hand Disco for $7,500 he describes it as follows:
"Land Rover Discovery 1993, 190 000kms , 2.5litre Tdi Turbo Diesel, has bull bar, tow bar and has always been serviced at a very reputable service centre."
He knows the guy who is selling.
Its obviously done some work nothing off road.
Any words of wisdom from those in the know?
Gaz
Reply By: Banjo - Wednesday, Aug 25, 2004 at 08:42
Only know of one owner and his went bang when the timing belt let go, well under the rec change period. Expensive repairs resulting of course....its always a possibility with belts, but one should be able to rely on the rec periodic changes.
AnswerID: 73869
Follow Up By: stitch - Wednesday, Aug 25, 2004 at 10:49
Same thing happened to my cousins Disco, 2 hrs out of Mt. Isa. A bit of an inconvenience with a boat on the back and all. It had to be transported back to Sydney as no one up there could work on it. He had to buy a 4x4 Rodeo to continue the journey north to Point Parker.
FollowupID: 333949
Follow Up By: Member - Jeff M (WA) - Wednesday, Aug 25, 2004 at 19:22
I've also heard about the t-belt issue, apparantly Land Rover changed the recommended t-belt change to every 70k. I spose if you do that, your in the clear. I just changed the t-belt on the surf today with only 50k since last. I always like to know that it was done while the vehicle was in my hands....
FollowupID: 333977
Reply By: Rosco - Bris. - Wednesday, Aug 25, 2004 at 09:21
Gary
Manual or auto?? Manual boxes had some problems up to about 1996.
They don't generally have a good resale value and 7.5K seems a tad high, but if it's in good condition it may well be worth it. Check for rust at the bottom of the front guards behind the wheels.
190k over 11 years is less than average, so it hasn't done too much work.
AnswerID: 73873
Reply By: Des Lexic - Wednesday, Aug 25, 2004 at 10:54
I don't think much of the new discoes and I doubt they would improve with age like a bottle of red does.
Rather have the bottle of red!!!!
AnswerID: 73881
Reply By: Member - Alan- Wednesday, Aug 25, 2004 at 11:03
My 1996 300Tdi Auto was a good vehicle. Economical, powerful enough to pull a 1.5 tonne van, good in the dirt, not too bad in sand once the tyres were let down to proper pressures.Comfortable as well.
With a roof rack and shelf in the back I could carry everything for 3 humans and 2 kids OK.
The only real disaster was the heater core which is a big job to change being in behind the dash and aircon pipes.
Otherwise it was a good reliable vehicle.
The only real prob. in Perth is getting mechanics who want to work on something other than Toyotas, and that includes those employed by so called specialist LR repairers and the main stealers!
AnswerID: 73882
Reply By: drivesafe - Wednesday, Aug 25, 2004 at 19:00
Hi Gary W, saw your posting earlier and not being sure, took the question over the Australian Landrover Owners Online forum and put the question out there.
Got some good replies but it would be better for your mate to put the questions he needs answers to, to the the forum himself.
It’s another great forum like this one but mainly aiming at LRs and he will find it at : - www.aulro.com
AnswerID: 73922
Reply By: Disco200Tdi - Thursday, Aug 26, 2004 at 12:08
Gi day Gary,
I also actually own and drive a 1993 200 Tdi disco so have first hand knowledge of the beast in question.
The main things to took for are:
1. drivetrain backlash. This apprears as a clunk in the gearbox area. What happens is the gearbox mainshaft and transfer case input gear splines wear and eventaully strip due to lack of lubrication. The fix is to cross drill the input gear.
2. Grinding gearchanges. This is syncro wear in the gearbox. Slow smooth gearchanges are required and clean oil (ATF). You can usually still get another 100K at least before requiring a gearbox rebuild.
3. Body mount cracks. These only really show up on vehicles that have seen haevy duty offroading or overloading on outback trips.
4. Timing belt. On 200 Tdi's not really a problem if regulary changed. I do mine at 70K. The next model, 300 Tdi's did have have some early problems but all should have been sorted by now.
This list might sound scary but you will find the car no less realiable than any other 11 year old car, and the price of $7500 for a Tdi in Melbourne sounds good.
John D
AnswerID: 74047
