How to drive a diesel?
Submitted: Thursday, Sep 02, 2004 at 16:54
ThreadID: 15986 Views:6138 Replies:12 FollowUps:10
Hi all,
Was once told by an auto elec friend that once warmed up a diesel should be driven hard.He claimed "you can't hurt a diesel" and it should be driven like you hate it.He maintains that light driving and lots of short runs only clogs em up.Is this style of driving recommended or only causing undue stress on the rig?
Thanks Mark
Reply By: Rosco - Bris. - Thursday, Sep 02, 2004 at 17:00
Tell him to stick to his day job.
AnswerID: 74903
Follow Up By: Lone Wolf - Thursday, Sep 02, 2004 at 17:41
Roscoe.........
............ had a look at your rig pics............ awesome!!!
I am just NEVER NEVER gonna do that!!! I don't think I'd even walk across it........ maybe crawl!
Wolfie
FollowupID: 334753
Follow Up By: Rosco - Bris. - Thursday, Sep 02, 2004 at 19:46
Wolfie
Great country up there ... if you ever get the chance, grab it with both paws. Can't wait to get back to catch the bits we missed. Just watch out for the BIG gaps between the logs.
Cheers cob
FollowupID: 334763
Follow Up By: Eric from Cape York Connections - Friday, Sep 03, 2004 at 06:41
Rosco on my second trip the logs at cypress had dropped about 20 inches and was quite gard to cross.
Where is your second pic taken I cant make it out its a bit blurry.
All the best
Eric
FollowupID: 334799
Follow Up By: Rosco - Bris. - Friday, Sep 03, 2004 at 07:42
G'day Eric
2nd pic at Cannibal Ck. Can't exactly recall, was it Nolan's Brook where there's the remnants of another one ... looked like a few matchsticks??
Cheers cob
FollowupID: 334801
Reply By: Davoe - Thursday, Sep 02, 2004 at 17:42
he is kinda right. for combustion deisals rely on heat and compression so if you use your 4.2 diesal like mums hyundai and drive the kids 400m to school then let it cool down before driving it 1k to the shops at midday then pick the kids up at 3 etc etc then it will be continually be driven around at below optimum engine temp and combustion will not be perfect which creates more soot in the oil which is not good for optimum engine life. long runs are best for diesals with a bit of "work" thrown in. As for thrashing them - they are rev limited but thats probably not ideal either. Me? I ride my bike around town as much as possible and save the diesal for trips as much as possible (just my opinion based on my limited mech knowledge)
AnswerID: 74907
Follow Up By: Member - Matt- Thursday, Sep 02, 2004 at 22:44
Your comment about the rev limit reminds me of a fellow truckie who reckoned that on the freeway in his 6 wheel tipper (Merc) with a trailer, he would let the rev limitter decide how fast he could go, just let it cut in and out. A few months after these comments he's off the road getting a rebuild... something to do with the springs on the centrificul weights going thru the injector pump... ah well, you gotta treat em right. matt
FollowupID: 334782
Reply By: Member - Mick S (QLD) - Thursday, Sep 02, 2004 at 17:58
Marcus.
Whilst it's true that diesels like to be worked, the old "drive it like you hate it " philosophy dates back to the GM & Rootes 2 strokes of the '50s & '60S . Modern diesels have quite different torque characteristics and thrashing the pickhandles out of them will produce nothing but excessive fuel use and premature failure.
I agree your mate should keep his day job.
Cheers.
Mick.
AnswerID: 74909
Reply By: Truckster (Vic) - Thursday, Sep 02, 2004 at 18:03
He was only correct in stating that lots of short runs are not good for diesels. They carbon up if you like, and a good long run every few weeks is always good.
Try it, you notice a difference after month or 2 of city work, go for a long run..
AnswerID: 74911
Reply By: Twigiee - Thursday, Sep 02, 2004 at 18:09
Marcus,
Heard this opinion much in the past, actually my uncle is a farmer and he once connected a plough to his hilux and run around the paddock for a few hours to 'clean out' his glazed up deisel!
I'm not sure what's the best solution for a 1hd-t which are known to have big end problems.
Twigiee
AnswerID: 74913
Follow Up By: stitch - Friday, Sep 03, 2004 at 00:28
The best solution for a 1HD-T is to replace the big end bearings as Toyota stuffed it up by fitting bearings from factory that were not of an ideal metallic make up.
FollowupID: 334795
Reply By: Big Trev - Thursday, Sep 02, 2004 at 19:00
Firstly, I have been a heavy vehicle driver trainer since 1987.
Secondly, tell your friend to stick to what he is qaulified to do: "Fix 'em".
Thirdly, get out the drivers handbook from the glovebox and read up up on what the manufacturers say.
Aas previously stated the vehicle should be driven to get the best fuel consumption, horsepower and torque. Normally, that is shown on the tacho by a highlighted area, depending on the vehicle that is around 2000-3000 rpm (as a rough guess).
"Driving them like you hate them", is just that, hating them, and I am sure you don't hate your's. Diesels were never, ever designed to be driven like that. That term came from having uder-powered engines in trucks, and the feeling that drivers had to rev thebleepout of them to get them to work. It is an ignorant approach.
You may be succesful in finding out the optimum engine rev range (or performance chart) by having a search around the web site of tour 4X4 maker.
AnswerID: 74919
Follow Up By: Member - Brett H (QLD) - Thursday, Sep 02, 2004 at 21:41
I totally agree. Not only will the engine perform better for longer if driven correctly but the gearbox and all of those synchros will last longer. Try to get a jap engine with a road ranger into gear at high rpm.....and then think that the synchros in your 4x4 gearbox are having to do the same thing so you can shift smoothly...food for thought to those who understand the jargon.
My 2h has done 330000km and I put 500000 on a Cummins
driving in Sydney . Neither have had gearbox and i have never worn out a clutch. I drive fast and quick but don't flog the vehicles.
FollowupID: 334776
Reply By: 2ndLow - Thursday, Sep 02, 2004 at 19:09
Didn't believe diesel need to work hard. But after consulting some instructor in TAFE, my mate next door (a diesel mechanic) and other source i started to believe. But I was still not convinced until I experieced this myself. I used to drive it for less than 15 mins everyday. Just enough to get it warm up.
About a year ago, engine started to build up some tapping noise. It sounds like tappet but it is much slower than real tappet noise. The sounds even more distinct when under load. Also lack of power.....
Try everything.....use good grade engine oil (CI-4), Fleetguard filter, breed fuel system, injector, adjust tappet ......still same
Finally, after a long hill climb up a trek reving constantly above 3500 rpm (3900 rpm is max limit) for like 1-2 min in High Country...........no more tappet sounds.....regain more power....... now sounds sweet~~~
My engine is TD42....with 360000k on it..........
So just to share my experience on a diesel engine
AnswerID: 74921
Follow Up By: Member - Jimbo (VIC) - Friday, Sep 03, 2004 at 21:09
Kelvin,
I saw you thrash it up that hill, it would have cleared the cobwebs out of a haunted house.
You're one game man.
FollowupID: 334889
Reply By: Muddy 'doe (SA) - Thursday, Sep 02, 2004 at 22:54
My service manual says to change the oil every 5,000 kms unless I am driving the vehicle in harsh conditions. It lists several harsh conditions (dusty, freezing, towing) and also lists "repeated regular trips of less than 8 km" in which case it says do the oil change at 2,500km.
I live 3.1 km from work and quite often go out at lunchtime to shops and errands within about 4 km so the turbo-diesel does lots of short trips. I try to make sure I do at least a 40 to 50km run on the weekends just to get things flowing for a while at good engine temp even if it just an excuse to go for a drive!
As for driving it like u hate it, I agree with above that that only applied to older underpowered units. I try to keep mine in the economical powerband around 1500 to 2500rpm where all the torque is available without thrashing it. If I rev it out round town all it is doing is making noise!
I bought it for reliability and torque on long trips and off road and better fuel economy (although the 4.0 petrol is not too shabby in that department!). I find is cruises very comfortably at 110kph at just under 2,000 revs in 5th.
Muddy 'doe
AnswerID: 74953
Reply By: Andrew - Friday, Sep 03, 2004 at 15:55
Hi Marcus
Diesels like to be loaded (not overloaded) They do not like long periods at very light load (such as idling) or lots of high revs.
If you like to use revs then buy a petrol engine.
You can tell the guys who drive on the governer, they're the ones with all the black smoke pouring out the back.
When lightly loaded deisels tend to glaze up the bores which leads to oil consumption problems and compression blowby because the rings don't seal properly any more, hence the comments about loading her up to deglaze the bores (only works sometimes.
Jiggers like fire tankers which can spend all day idling while on a fire line have been known to suffer badly from this problem.
Line haul trucks have never heard of it because they are running reasonably (sic) loaded all the time.
Diesels are best driving using the engines torque band as previously suggested. Thats when they give their best life and economy.
regards
A
AnswerID: 75032
Reply By: joshinthecity - Monday, Sep 06, 2004 at 00:26
What a shame then that Nissan have seen fit to give a 3.0 GU TD a 2900rpm 110k/ph cruise. ( in manual form )
Insane.
Josh * Just back from the snow *
AnswerID: 75273
Reply By: Mikef_Patrol - Monday, Sep 06, 2004 at 08:31
My 2c
I run mine (Series 3 3.0L Nissan manual) generally between 2,000 and 3,600 RPM. Max torque to Max Power. (Actually, that is probably more like 1700 to 3,250 most of the time).
Slightly bigger tyres will lower the revs at 100 a bit Josh. Mine does about 2700 now (265/75/16). The auto does ~2100 in O/D at 100.
When towing our van at 100, the slightly higher revs make the job easier on the car, doesn't lugg all the time. I keep out of 5th below 80 as well, so as to not strain the 5th gear. All too easy, just have to learn how to drive the particular vehicle. They are all different.
MikeF
AnswerID: 75280
Follow Up By: joshinthecity - Saturday, Sep 18, 2004 at 23:15
All good info Mike.
I have Cooper ST 285/75/16's on mine (series IV manual) and show precisely 2850rpm at 110 (GPS)
Strange, the comparison against the auto don't you think ?
3,600 rpm is a hell of a high shift-point IMO ? I'm rarely , if ever, over 3,200.
Josh
FollowupID: 336665
Reply By: Bros - Monday, Sep 06, 2004 at 17:25
marcus,
Got a HJ 75 2H. Done 334,000 km.
Give it plenty.
Sometimes flat or close to it for hour or two (after market cruise), especially travelling south from North Queensland against 15/20 knot headwind.
Had the rocker cover off the other day to check the valves and was surprised to see no gunk. Could see the metal. Had petrol cars in the past so gunked up you could not see any metal.
Change oil and filters every 5,000 km. Take for a 100k run regularly.
Do whatever suits you, because after all you are the one using and paying.
This is my opinion only and no correspondence will be entered into.
Regards,
Bros.
Work is the curse of the down and out bludger.
AnswerID: 75354
Follow Up By: Member - Brett H (QLD) - Monday, Sep 06, 2004 at 20:06
But remember the HJ 75 2H will only just get over 3000 rpm in 5th. My one even new could get nowhere near the redline in top gear. I haven't tried but I wouldn't be surprised if 4th gear was the same.
FollowupID: 335128
