Sunday, Sep 05, 2004 at 13:49
Hi Fat Bastard
I Used an Frantz 2 stacker on my LN65 Hilux 2L Diesel with synthetic oil for approx 200,000k ,changed filter every 5000Km (plus 1.5 Litres topup ,system vol was 6L) and oil every 50,000K no oil testing done.
Was chasing more ponies so transplanted the 2.4 with a 2.8 3L inc G/Box and Tfr.
Sold 2L motor to Diesel Mechanic for a mates 2.2 hilux , he was that impressed with the excellent condition of the Motor he came back and brought the G/Box and Tfr next weekend.
The 3L transplant went for 350,000Km with the same treatment before the Hilux was sold with nearly 700,000Km and 18 yrs.
I now have a 100 series HZJ105R (4.2 Diesel) 40,000km (now done 110,000km) at purchase and installed an AMSOIL Dual Bypass system after making an adaptor to take the oil from the original spin-on (system replaces the original spin-on which is a incidentially a combination of full flow / Bypass (the toyota bypass portion filters the full sump approx every 3hrs and has a lower total particulate holding and retention >10 micron capacity).
AMSOIL Bypass =link text
link text
Below what the majors say about their ultra low sulphur fuel rollout
HarrowCaltex
Has a gross energy per unit volume of approximately 38.2 MJ/L.
KEY PROPERTIES
Sulfur, mg/kg 50 max
Flash Point °C 61.5 min
Density at 15°C, kg/L 0.820 - 0.860
Cetane index 46 min
Code 420
Lubricity, mm 0.460 max
Sulfur in diesel fuel:
• Contributes to fine particulate matter emissions
• Can also lead to corrosion and wear of engine systems
• Reduces the efficiency of some exhaust after treatment systems
• May also render some exhaust after treatment systems permanently ineffective
(World Wide Fuel Charter April 2000)
When and where will
Caltex have ULSD available?
ULSD will be progressively introduced at selected terminals from July 2003 although availability will vary between terminals and over time. The current (July 2003) expectations are:
• Banksmeadow terminal (NSW) will have intermittent supply from July 2003
• Bomen (Wagga NSW) will have ULSD available from early August 2003
• Lytton terminal (Qld) will have intermittent supply from July 2003
• Kewdale terminal (WA) will have all diesel as ULSD from approximately September 2003
• Kalgoorlie terminal (WA) will have all diesel as ULSD from approximately October 2003
The amount of ULSD available at Lytton will increase during the second half of 2003. All other terminals will initially sell Low Sulfur Diesel (less than 500 ppm sulfur).
Is ULSD suitable for my vehicle?
Diesel users should not experience any differences in vehicle performance with ULSD from that with LSD. Post 1994 vehicles should experience no difference in operation with ULSD or LSD. In some pre 1994 vehicles, especially those with nitrile rubber, existing cracks or stresses in the rubber seals may not adjust properly to the change in fuel composition of ULSD. It is recommended that owners of vehicles with these seals consider changing any suspect seals at the next maintenance check.
Is lubricity a problem with ULSD?
Under the Fuel Quality Standards Act (2000), diesel is required to meet a certain standard for lubricity. All ULSD marketed by
Caltex will meet this standard.
Are there any other physical differences between LSD and ULSD?
Apart from sulfur content, the colour of ULSD produced at both
Caltex’s Lytton and Kurnell refineries may exhibit a green colour. The colour reflects the additional processing at the refineries and does not affect the quality of the product.
BP
BP ULSD was officially launched on 1st July 2003.
The advantages are obvious.
Less sulphur means less sooty black exhaust smoke. As much as 60% less, in fact. Invisible emissions have also been greatly reduced, and carbon monoxide, hydrocarbons and nitrogen oxides are now just a fraction of their former levels.
Engine-friendly. Wallet -friendly.
New BP Diesel is also a breath of fresh air for your engine, as it can reduce engine corrosion and extend lubricant life. Benefits that you may not be able to see, but that you're sure to appreciate through potential savings in your vehicle maintenance costs.
Removing most of the sulphur hasn't taken anything away from the performance of new BP Diesel. You can expect comparable power and fuel economy, and you'll pay the same price per litre as the higher sulphur diesel.
Where can I buy BP ULSD.
Suitable for all diesel engines, new BP Diesel is available in
Brisbane,
Perth, Kalgoorlie,
Sydney,
Gladstone, Port Headland,
Adelaide and
Alice Springs. By January 2006 supply will be expanded throughout BP's entire nationwide network.
Performance Benefits
Ultra Low Sulphur Diesel will give reduced exhaust soot emissions without sacrificing engine performance. On current engines the fuel will also help to keep engines and fuel systems cleaner leading to reduced incidences of injector fouling and performance loss. Performance benefits are
• Reduced exhaust emissions such as visible black smoke and particulates for the same power output
• reduced sulphur dioxide emissions
• reduced corrosion due to acidic exhaust gas components leading to improved maintenance and operation
• reduced soot build up in the engine lubricants with potential for extended drain periods
• optimum fuel economy and power comparable to normal grades of diesel fuel
• improved storage life
• improved exhaust odour
• lubricity is controlled to ensure that it will meet engine manufacturers requirements for the effective lubrication of fuel system components
Typical Values — based on BP Laboratory testing
Value Typical Specification
Density kg/L at 15 deg C 0.835 0.83 - 0.85
Distillation 95% recovered deg.C 340 350 max
Viscosity at 40 deg C 3.0 2.0 - 4.5
Water % vol less than 0.02 0.02 max
Sediment % mass less than 0.01 0.01 max
Cetane 51
Sulphur mg/kg 50 max
lubricity 300 - 400 460 max
Shell
Ultra Low Sulphur Diesel (ULSD) - Shell Diesel 50
Shell is progressively introducing Ultra Low Sulphur Diesel (ULSD) throughout Australia ahead of the federal legislation start date of 1 January 2006.
Shell Diesel 50 is a premium grade automotive diesel suitable for use in high speed diesel engines in both automotive and industrial applications. The diesel properties are adjusted during winter to minimise waxing in cold locations. Shell Diesel has a high cetane number to help ensure smooth running and which assists starting at temperatures
well below those prevailing in Australia. In addition the lubricity of the diesel fuel is controlled and monitored to help ensure that adequate lubricity is maintained to prevent fuel pump and fuel injector wear.
Shell Diesel 50 is available in parts of New South Wales and Queensland. The New South Wales rollout will be completed by September 2004 whilst remainder of Queensland will be rolled out progressively between now and 1st Jan 2006
In Victoria and Tasmania, Shell Diesel 50 will be available from October 2004.
Adelaide and its environs and the rest of South Australia from mid 2005.
The Northern Territory will have ULSD available from 1 January 2006.
What are the benefits of low sulphur diesel?
• Reducing the ultra fine particles from diesel engine exhausts will improve local air quality;
• Reducing sulphur dioxide emissions, which contribute to acid rain, will reduce the risk of acid rain occurring;
• Reducing sulphur in fuel potentially reduces the risk of corrosive wear in the engine;
• Reducing the sulphur content does not inhibit engine performance; and
Reducing sulphur facilitates the introduction of new diesel exhaust treatment catalyst which will further enhance the reduction of environmentally sensitive diesel emissions.
Will my diesel engine require additional lubrication as a result of using a low sulphur fuel?
Sulphur content is linked to the lubricating properties of the fuel and some low sulphur fuels may require additives to provide lubrication to fuel pumps and injection systems.
Shell addresses this at the refining stage so you do not need to introduce additives into the fuel. Shell Diesel 500 and Shell Diesel 50 will continue to be tested to ensure that they provide adequate lubrication.
75210
Follow Up By: fat bastard - Monday, Sep 06, 2004 at 17:02
Dear Bruce what a wonderful contribution, I hope many people will enjoy it as much as I did.
335112
