Burning down the loo?
Submitted: Thursday, Nov 25, 2004 at 11:14
ThreadID: 18079 Views:2894 Replies:9 FollowUps:8
I know its best to let sleeping dogs lie but am really curious how people deal with burning their dunny paper. I have always taken a crowbar to dig an extra deep hole and burry the lot, but given the latest views on such matters now feel that by burning the same I maybe even more responsible. However, I am interested in knowing a fail-safe way of doing this as I am having visions of third degree burns in the seating area and or the loo tent going up in smoke. So what is the best way?
Kind regards
Reply By: Des Lexic - Thursday, Nov 25, 2004 at 12:02
Bea, all you really need to do is burn the paper not the waste. You can do this even standing up so 3rd degree burns are unlikely. You may need to use a dry sheet to start the burning off process. Just as a matter of curiosity, how long a crow bar do you use. Perhaps you should consider an extension bar to it but personally, I couldn't wait that long to start work!
AnswerID: 85856
Follow Up By: beatit - Thursday, Nov 25, 2004 at 12:49
It's a 7 foot job and I take your point but I was thinking of the overnight stay type of hole.
Kind regards
FollowupID: 344445
Reply By: howie - Thursday, Nov 25, 2004 at 12:03
is that sleeping logs lie?
anyway, back to the script. burning the paper does not produce a massive fire that you can toast your bread on, although it is best to set the fire after you have finished, being careful of course of local conditions.ie wind & bush fire.
its a sorry site to turn up somewhere to be greeted by last years toilet paper that has been dug up by animals or exposed by weather/water.
AnswerID: 85857
Follow Up By: Gajm (VIC) - Thursday, Nov 25, 2004 at 18:30
Now thats an scary thought, toasting your bread on your dunny fire. I have a mate who reckons everything you take camping should have 2 uses, I will run that idea by him.
And yep nothing worse than the old toilet paper tickertape parade, no hassle to keep a box of matches in the middle of the roll ready for use
FollowupID: 344495
Reply By: Well 55 - Thursday, Nov 25, 2004 at 12:10
My answer to this is dig your hole deep enough to sprinkle a bit of dit on top each time it is used then at pack up time and no longer required add some dry grass etc set it alight let it burn down then fill the hole in.
The burnt grass will kill the smell and prevent it being dug up.
AnswerID: 85858
Follow Up By: Squizzy - Thursday, Nov 25, 2004 at 13:41
A medicine glass of diesel often helps with ignition and sustains the burning process.
FollowupID: 344452
Reply By: fozzy - Thursday, Nov 25, 2004 at 13:28
reminds me of the old paperbag on the doorstep scenario
heheheheheh
AnswerID: 85874
Reply By: Rod W - Thursday, Nov 25, 2004 at 13:49
I normally urinate on my dump so the paper is soggy and wet and nearly disintegrating. I also put some of the local decaying vegetation in the hole before backfilling so that these micro-organisms on the decaying vegetation can also feed on my matter.
AnswerID: 85878
Follow Up By: Gajm (VIC) - Thursday, Nov 25, 2004 at 18:35
Some CSIRO women did a study on the urination technique, and it still takes a bloody long time to break down, albeit twice as fast as not urinating on it. i still think the burning technique is the best as others have stated it stops animals digging it up. As long as you keep an eye on it to make sure its all under control
FollowupID: 344496
Follow Up By: Peter - Friday, Nov 26, 2004 at 18:00
why not a metal container with a lid ,plonk it in and burn it, the dispose of at the next loo
FollowupID: 344652
Reply By: GrantSA - Thursday, Nov 25, 2004 at 15:03
Burning the waste with diesel or grass is a bad idea as the heat kills all decomposting microbes so it takes forever to rot.
Digging too deep for a one off jobbie is also bad as the decomposting microbes are in the top few cm of soil - for a one off no deeper than 20cm, burning the paper, cover with the dug soil and 100m from water courses.
For longer stays a deeper latrine, burning the paper and throwing in a handfull of topsoil is the go so the microbes can go to work - no long, hot fires ie: diesel or leaf litter fires.
Urinating on the paper could be an alternative method of getting the paper to rot in larger holes as the urine would increase the nitrogen content of the paper and make it wet so the decomposers can work on it.
Overseas ie:USA and some places in Europe, it is illegal to dig and bury human waste. All solid waste has to be retained in some receptical and carried out to dumping (so to speak) stations. Maybe for high usage areas in Aus this should also be the go.
For a humerous look at this see if you can get the book "How tobleepin the Forest" - I dont know the author.
AnswerID: 85881
Reply By: Shaker - Thursday, Nov 25, 2004 at 16:57
Why not just 'dump, wipe, burn" then put a shovel of soil on top.
Seems simple enough, thats how we do it, burning in the hole works better than any air freshener too, also drives the dunny budgies outa the dunny tent.
AnswerID: 85895
Reply By: Lone Wolf - Thursday, Nov 25, 2004 at 18:00
What would be REALLY cool is this.........
If we could introduce something into our diet that allowed us to defecate with a skin around it, sort of like a sausage, just twist & snap!
How good would that be?
Wolfie
AnswerID: 85907
Follow Up By: Gajm (VIC) - Thursday, Nov 25, 2004 at 18:39
LoL you are one strange bloke Wolfie. of all the things Iv'e wished for, like spiderman powers, supermans xray vision, the ability to fly, I don't think I have ever wished for a poop with a skin on it
FollowupID: 344497
Follow Up By: D-Jack - Thursday, Nov 25, 2004 at 23:25
I've heard you can swallow a length of pig intestines to achieve the snag style results you are looking for. Be careful not to mistake them for the real thing though
FollowupID: 344546
Follow Up By: Rod W - Friday, Nov 26, 2004 at 10:56
You'll be very wary of the next sasage on the barbie eh?
FollowupID: 344597
Reply By: Member - Heinz- Thursday, Nov 25, 2004 at 18:27
This one is for Lone Wolf. That sausage thing sounds good, only I hope you put it back on the bbq,that way would be the cleanest recycling and good for the enviroment . I wish you good luck.
AnswerID: 85913
