100 Series Wiring ??????
Submitted: Friday, Nov 26, 2004 at 22:32
Ozman
I have had GREAT feed back about the engel in the 100 series running on 1 battery. Thanks ALL!!
Now I have decided to rewire the standard rear power outlet to operate all the time.
Has anyone done this? How was it done?
It only works of the Accessories Circuit at the moment.
Cheers David
PS. If iget a flat battery in the middle of nowhere i will be calling on all formites that advised 1 battery is okay/good --- to come save me!!!
Look out for my smoke signals as my radios will be out of order!!
Reply By: Willem - Friday, Nov 26, 2004 at 22:56
If you can afford a 100series you can afford an auxilliary battery. Why stuff around?
86085
Follow Up By: Ozman - Saturday, Nov 27, 2004 at 08:40
True! actually had a thought to dump the new petrol yota and go grab a Turbo D as they come standard with dual batteries.............!!!!!
344719
Follow Up By: Back tracks- Saturday, Nov 27, 2004 at 10:38
Yes they do come standar but you are much better off to stik to the petrol and have the necessary things moved to accommodate the second battery. If you are going to trade on the Landie then wait for the complete new model in 2006.
344726
Reply By: Member - Sand Man (SA) - Saturday, Nov 27, 2004 at 06:03
Ozman,
Great Feedback???
The sensible replies in your previous post recommended you install a second battery. The reason for this is you may not always be in a position to run your vehicle every day to charge your one and only battery. (You may even just forget)
If your (one and only) battery is drained, then to put it simply YOU ARE STUFFED.
The security of having an alternate supply for your Fridge and maybe other accessories is
well worth the initial investment.
If your budget is limited you can restrict yourself to a simple mechanical isolator and a second "starting" battery.
If your main battery packs it up in a remote location, you can use the second battery to start the vehicle.
Just commonsense Mate, IMHO.
86100
Follow Up By: Ozman - Saturday, Nov 27, 2004 at 10:58
Agreed! These forums sure confuse me sometimes!!
I did not realise there are so many experts!!!
I am going out today to look for a second battery!!!
344732
Follow Up By: Nudenut - Sunday, Nov 28, 2004 at 12:28
experts?
crap
just a lot people with no idea on what is best
but we all know i am always right...so get that second battery
344841
Follow Up By: mr diamond - Sunday, Nov 28, 2004 at 12:52
EXPERT.
an x is a has been.
and a spurt is a drip under pressure.
yes this
forum is full of xspurts.right nudey.lol
344845
Follow Up By: Nudenut - Sunday, Nov 28, 2004 at 13:17
you calling me a "Has Been"!
344855
Follow Up By: mr diamond - Sunday, Nov 28, 2004 at 13:21
i woudnt/couldnt call you a has been.
you had to have been something/someone to start with.
344856
Follow Up By: Nudenut - Sunday, Nov 28, 2004 at 13:30
thanks alot !!!
344860
