frantz filters
Submitted: Wednesday, Dec 01, 2004 at 20:24
ThreadID: 18255 Views:3895 Replies:6 FollowUps:4
hey guys i have read about these frantz filters and the fact you can use toilet paper as the element. my question is do i need to remove the cardboard roll from the centre or can i leave it there
thanks
jason
Reply By: Member - Roachie (SA) - Wednesday, Dec 01, 2004 at 20:27
Not sure about the cardboard centre needing to be removed, but please you use NEW toilet paper and not 2nd hand stuff......tends to clog up your oil galleries with shyt.LOLOL
AnswerID: 86867
Follow Up By: mr diamond - Wednesday, Dec 01, 2004 at 21:18
come on mate dont lead the guy astray.
you can still use used toilet paper.
remember just use the clean side .
FollowupID: 345464
Reply By: David Au - Thursday, Dec 02, 2004 at 08:38
Check with the oil company that this type of filter will not remove the additives from your lubrication oil.
You cannot use ordinary toilet rolls.
These filters had their day twenty years ago.
If you are looking to fit better filtration on a diesel engine, then look to something like a Baldwin B50 filter.
AnswerID: 86913
Reply By: Flash - Thursday, Dec 02, 2004 at 11:30
Yeh, had their day, right.
Tell that to the mechanic who stripped down my mates GQ at 480,000 klms, always run with a Frantz, and which looked and ran like new. (Why did he strip it? Because he was buying it.) He reassembled it and replaced virtually nothing......
Or to me with my Isuzu diesel nearing 25 years old, huge ( god knows how many) klms as the odo stopped years ago -but over 400,000 and 14 year old Patrol, both absolutely perfect mechanically.....
Yes you need the cardboard roll in the centre, you also need the right size (small) centre which is getting hard to get. Some commercial toilet paper is still perfect.
You're probably better off buying the specially made stuff which various suppliers have. Cheers
AnswerID: 86946
Follow Up By: Flash - Thursday, Dec 02, 2004 at 11:33
PS Oil companies don't like them.... because they then sell you LESS OIL!
FollowupID: 345569
Reply By: Howard T - Thursday, Dec 02, 2004 at 16:09
dont forget to use the perfumed kind. Better sniffing perfume (dont go there) than unleaded fumes.
AnswerID: 86999
Reply By: ev700 - Friday, Dec 03, 2004 at 10:01
I believe that bypass centrifugal oil filters are superior.
From motor engineering advice I obtained, no problems fitting one to (say) a Cruiser however a return inlet has to be fitted to the sump.
However some say that aftermarket alterations introduce more risks than they appear to solve. This and the price rule them out - unless one day Toyota offers it ex-factory as an option.
I believe safe extended oil changes via a bypass centrifugal filter would be attractive to diesel owners and would be good environmental marketing.
AnswerID: 87105
Reply By: G.T. - Friday, Dec 03, 2004 at 17:06
Read posts 15993, 16027,17991. A toilet roll oil filter is a W.O.F.T.A.M.
Regards G.T.
AnswerID: 87182
Follow Up By: ev700 - Saturday, Dec 04, 2004 at 02:18
WOFTAM? Is that equivalent to a 'crock of bleep'?
If so, from what i've read that could be a common description of toilet roll filters :-)
FollowupID: 345962
Follow Up By: G.T. - Monday, Dec 06, 2004 at 11:01
ev700--- Yes. W.O.F.T.A.M. = waste of f-----g time and money. Regards G.T.
FollowupID: 346224
