Camp Cooking
Submitted: Friday, May 20, 2005 at 19:16
ThreadID: 23157 Views:3373 Replies:7 FollowUps:5
Can anyone help me , I am looking for a hot plate to cook over the fire. After looking at camping shops in Adelaide I couldnt find one I thuoght was made from thick enough steel.
Any feed back would be great.
Reply By: Al & Mrs Al (Vic) - Friday, May 20, 2005 at 19:21
alex, I've got a primuscoi one, have seen them in disposals stores, it's flat and the legs fold underneath, we used it last weekend overthe fire, and it worked great, it comes in 3 sizes, I've got the largest. You can check out their stuff on www.primuscoi.com.au
Lyn
AnswerID: 112113
Follow Up By: Casnat - Friday, May 20, 2005 at 21:12
I have one that looks the same as those but got it at Cheap as Chips or Cunninghams or the like (can't remember exactly which one it was but you know the type) for about $8. It is cast iron and has fold up legs etc for over the coals but you can remove them and then it fits perfectly over my 2 burner stove.
FollowupID: 368495
Follow Up By: Member - Ivan (ACT) - Saturday, May 21, 2005 at 11:50
Yep - we've got the mid size COI - had the same problem, couldn't find a quality one in a design and size we liked - the COI is great and comes in a sturdy canvas bag.
FollowupID: 368542
Reply By: Brew69(SA) - Friday, May 20, 2005 at 19:23
I just use the lid of my Bedourie camp oven. Works a treat.
AnswerID: 112114
Follow Up By: paj - Friday, May 20, 2005 at 21:05
Ditto,
worksd fine on the fire or stove.
Paj
FollowupID: 368493
Reply By: Member - Davoe (WA) - Friday, May 20, 2005 at 20:41
seen it all now, cant find a hot plate? try the one off your barby
AnswerID: 112124
Follow Up By: Member - iMusty (VIC) - Saturday, May 21, 2005 at 11:09
I second your responce...
FollowupID: 368537
Follow Up By: BenSpoon - Sunday, May 22, 2005 at 13:23
Thats what I'm using- Its thick enough to double as a jacking base in soft stuff too.
FollowupID: 368581
Reply By: Sand Man (SA) - Friday, May 20, 2005 at 20:58
Also, check the Hillbilly range. Top quality gear.
Hillbilly
Bill
AnswerID: 112127
Reply By: 80scruiser - Friday, May 20, 2005 at 21:16
Bought a hotplate from Go Low or Clints crazy bargains for 10 bucks.
Do yourself a favour don't buy too big. I bought one with folding legs large and have never used it.
AnswerID: 112132
Reply By: Member - Anni M (SA) - Saturday, May 21, 2005 at 08:49
Hi Alex,
We were given one with folding legs, and its great. It is just the sort that you buy at somewhere like Snowys or Rays Outdoors. They aren't as thick as you would expect, but they work a treat. If you want something really thick (and heavy!) then there are plates that you can buy to put over your 2 burner gas stove. If you want to be really extravagant then Le Creuset make one for cooking steaks etc. I admit to owning one of each of these, and the one on legs from Snowys is as good as any and much cheaper.
Hope this helps
Anni
AnswerID: 112165
Reply By: Member - Phil G (SA) - Saturday, May 21, 2005 at 11:53
I don't think the thickness of the plate matters much on a campfire.
I tend to put steak over the grille side, and other stuff on the plate. If you've got nice bed of coals underneath it cooks fine.
In Adelaide you'll get good ones anywhere.
AnswerID: 112182
