nissan 4.2 usig a lot of diesel
Submitted: Saturday, Jun 04, 2005 at 07:21
ThreadID: 23576 Views:2810 Replies:10 FollowUps:2
good mornig all
can anybody give me any ideas as to why the patrol has started using more juice. 6 weeks ago i had a snorkel fitted consumption dropped slightly but last 2 weeks its dropped even more down to around 6ks pl bad fuel ?using bp last 2 tanks blocked filter? where do i look?
steve
Reply By: GOB & denny vic member - Saturday, Jun 04, 2005 at 07:23
ps anybody recommend a decent diesel mechanic in se melb (dandenog)area
steve
AnswerID: 114311
Follow Up By: Member - Browny (VIC) - Saturday, Jun 04, 2005 at 20:59
Steve,
Atoc Autos in Sth Belgrave a Diesel 4by guru
9754 2751
FollowupID: 370315
Follow Up By: Truckster (Vic) - Sunday, Jun 05, 2005 at 00:02
BJ Diesel in Dandenong - see Clint :)
... Greens Road. I think they are part of DTS now.
or as browny says Aaron Carlton at Atoc is good.
FollowupID: 370325
Reply By: Bob Y. - Qld - Saturday, Jun 04, 2005 at 07:57
Steve,
We had hornets build a mud nest in upper part of snorkel, on 80 series. Really sluggish, and probably used more fuel too. Made a lot more induction noise though too.
Get about 7km/L out of tojo's up here.
Hooroo...
AnswerID: 114313
Reply By: johnsy1 - Saturday, Jun 04, 2005 at 08:39
Steve check air cleaner as the snorkel will push a lot more rubbish down into the fins also new fuel filters and check the gause filter ib the pump 17mm ring spanner and check the water seperator before you start. You havent run it out of fuel by any chance ?
AnswerID: 114317
Reply By: Max - Sydney - Saturday, Jun 04, 2005 at 12:41
Steve
It seems to have folowed directly on from getting the snorkel fitted. Have you taken it back to the bloke who fitted it and asked him? I'd be wanting to ask him if he left a rag in the snorkel or something.
Max
AnswerID: 114337
Reply By: fisho64 - Saturday, Jun 04, 2005 at 18:22
take the handbrake off!
Wont be your fuel filter as a dirty FF will make it sluggish but only by starving it of fuel.
AnswerID: 114371
Reply By: oscar - Saturday, Jun 04, 2005 at 18:36
Hi Guys I am an earthmoving Fitter of 20 years .Fuel consumption excess of a sudden nature is usually blocked air induction restriction .Air cleaner should be replaced look in the line make sure nothing is blocking .The other guys have said the same .I agree Jeff
AnswerID: 114373
Reply By: GOB & denny vic member - Sunday, Jun 05, 2005 at 12:46
goodday people
thanks for the replys air filter not to bad but will change monday and will try the 2 diesel places and see how i go
steve
AnswerID: 114424
Reply By: Member - JohnR (Vic)&Moses - Sunday, Jun 05, 2005 at 14:02
Steve you don't actually say what has been normal to you in your post. I accept that as part of the way I drive and the weight I carry or close to it. I have just put the figuers through the PDA and it is 16.5 or just under per 100 and I think you will find a few worse than that too, especially if they use petrol.
The other factor you may consider is that ther has been a change in the place you have bought it. I have found in the past ther are some places that seem to have smaller litres so you end up buying more of them. Sometimes there may be more air injected into the flow - or rather not excluded from the flow and is measured as diesel. I would still check the air filter though.
AnswerID: 114430
Reply By: joc45 - Sunday, Jun 05, 2005 at 15:12
Are you sure that when they fitted the snorkel, they actually cut a hole in the side of your fender? ;-)
Gerry
AnswerID: 114436
Reply By: angler - Monday, Jun 06, 2005 at 10:09
Sometimes it may be due to where you get fuel. When travelling to Darwin we filled at Barkley homestead and the use worked out to be 5k/L. All other places it was 7K/L. same on the trip back.
www.bycompass.com
AnswerID: 114523
