wiring h/duty lighter socket to rodeo
Submitted: Tuesday, Aug 30, 2005 at 19:31
ThreadID: 25997 Views:2587 Replies:5 FollowUps:3
I am putting a heavier duty lighter socket in my 1996 Rodeo 2.8 t/c twin cab. Where is the best place to connect the 'ignition on' wire?
Reply By: revhead307 - Tuesday, Aug 30, 2005 at 19:43
G'day,
I take it your running the ignition voltage to a relay? Your best friends are a test light and multimeter.
usually tapping into dash clock, or power antenna out lead off the back of stereo are useful.
however i usually only tap onto accessories not ignition...i can see your point, but i never leave the keys in the ignition running accessories anyway, so for me it has the same effect.
If u want a dedicated ignition voltage not acessories...then probing round the steering wheel is your best bet...but i prefer to leave those wires alone.
Jeff
AnswerID: 127509
Reply By: Willb - Tuesday, Aug 30, 2005 at 19:44
Hi, what sort of current do you need to be pulling through the socket, are you replacing the original one or putting in another one. If you need a high current draw maybe you will need to go to the battery. If not check down near the fuse panel and piggy back of one of the heavier wires. I would steer clear of any of the connections to do with the engine management side of things. Usually there is a spare slot in the fuse box that has a igition feed but nothing on the other side, you could fit a connection to the other side of the fuse holder and use that one.
Will
AnswerID: 127510
Follow Up By: brinol - Tuesday, Aug 30, 2005 at 19:58
Hi Wilb,
I am putting in another to charge a Blue Apple battery while on the move. Will check the fuse box for a spare
FollowupID: 382013
Reply By: Willb - Tuesday, Aug 30, 2005 at 20:00
Excuse my ignorance but what is a blue apple battery?
Will
AnswerID: 127521
Follow Up By: brinol - Tuesday, Aug 30, 2005 at 20:05
Will, It is the original battery now marketed as a Waeco Thumper 12/240 volt, 48 A/hr.
Brinol
FollowupID: 382016
Reply By: Time - Tuesday, Aug 30, 2005 at 20:36
You could probably do with one of these
http://www.fridgeshop.com/Default.asp?id=207&category=3
AnswerID: 127526
Reply By: Sand Man (SA) - Tuesday, Aug 30, 2005 at 20:44
brinol,
Are you using the Controllers that originally come with the Thumper?
I Recommend you purchase the Charge Controller kit to enable a controlled, high rate of charge to the Blue Apple unit.
The positive wire should attach directly to your Primary battery's +tve terminal with an in-line fuse if you only have a single battery or to the secondary battery if you already have a dual battery system.
When you purchase the charge controller kit from Blue Apple, you get the two controller units, the fuse & holder, the correct size twin core cable, a 50amp Anderson connector and a "patch lead" consisting of two Anderson connectors, one which connects to the one you install and the other to a duplicate connector on the Thumper.
This is the solution supplied by the manufacturer and is first class. Any other solution will only provide a slower rate of charge and will NOT protect your primary (starting) battery from potential discharge or damage.
The unit I have is rated at 75 usable amp hours and charges in about 3 hours from the alternator, via the control units.
With the dual battery system and the Thumper, I have about 6 days of "fridge life" available without running the vehicle to recharge any of the batteries.
P.S. From memory two charging sets are available, a 20amp, or the 30amp unit which is better suited to the high end Thumper range.
Bill
AnswerID: 127529
Follow Up By: brinol - Tuesday, Aug 30, 2005 at 23:37
Sandman,
Seems like a thorough solution. Will give it a go.
Brinol.
Thanks fellas or the input.
FollowupID: 382073
