80 SERIES 4.5 ON lpg
Submitted: Friday, Sep 02, 2005 at 17:03
SMALLY
I am interested in some feedback on LPG conversions for 80 series Landcruisers.
Reply By: res.q.guy - Friday, Sep 02, 2005 at 17:25
I did a trip from Melb to
Mildura and return last week and I was getting between 4.6 and 6.2 klm / lt on gas. Two in the car & not loaded or towing.
Neil
127969
Reply By: Diamond (Vic) - Friday, Sep 02, 2005 at 18:27
gday smally.
the 4.5 heads arnt really good on gas.
valves burn out ect.
unless you want to spend big $ on doing the head.
127978
Follow Up By: res.q.guy - Friday, Sep 02, 2005 at 19:47
Mine has done 280,000 klm mostly on gas, and had absolutly no trouble with valves or the head, I must have a good one !!!!
Neil
382602
Follow Up By: Rod W - Tuesday, Sep 06, 2005 at 14:17
I'm the same as res.q.guy, except 250,000ks
383231
Reply By: franksy - Friday, Sep 02, 2005 at 18:33
hi i have a 80 series 92 4l i get about 250 -300 ks out of 88litres this still works out better than petrol i only use petrol every now and then to keep the
fuel pump working if you are in
sydney i recomend you use riverstone gas they have a good name and are relyable
127981
Reply By: Pete. R. - Friday, Sep 02, 2005 at 19:54
I had one on LPG with over 250,000km on it. Only problem I had was when I installed a
snorkel, LPG and snorkels don't mix easily.
If you do get the LPG put on have them install a seperate O2 sensor in the exhaust manifold and don't let them use the OEM O2 sensor. After the gas is on take the truck to a Toy dealer and have them run a check of the OEM O2 sensor.
127999
Follow Up By: ACDC - Friday, Sep 02, 2005 at 20:07
When you install a
snorkel with gas if its a cheapo conversion you must run a pressure balance tube from converter to air cleaner box.
382609
Reply By: Tuff60 - Saturday, Sep 03, 2005 at 00:57
The other solution to LPG systems iwith snorkels is dump the vapour vacuum system and go for a Gas Research throttle body. Does not affect perfomance or economy on petrol and increases performance on LPG and 90% time economy as
well. Also stops the slightly dirty air filter increasing your gas usage. Hope this helps.
128043
Reply By: prado_95 - Thursday, Sep 08, 2005 at 22:09
1FZ-FE engine will do fine on LPG, IF YOU DO THE MAINTENANCE PROPERLY.
I guess from the above your guess how I know? Dealer & 'autherised repair centre'
services failed to check & adjust the valve clearances at 40K increments. Cost me $1700 because of their incompetence.
Now have over 280km, and some mods without further issue.
Dave
129188
