Wednesday, Sep 07, 2005 at 21:26
I've also got the 2.8 t.
I've just had all new injectors, all new glow plugs, and the small manual primer pump checked over.
I've just copied this from another
forum, and it describes my problems to the nail. Starts dead easy any weather, but then after say 1 0r 2 minutes idling, starts faltering, then stops.
Real hard to start afterwards.
Here's the stuff I copied...
Subject : Pajero
Hi can anyone suggest why my 2.8 n reg pajero cuts out first thing in the morning after 1-2
miles. It then starts with some difficulty but then runs fine all day. A mechanic has suggested it is the
fuel pump drawing in air and that this will need to be taken off and sent to be refurbished at a cost of £6-700. If this is the case surely it would be cutting out continually, not just from cold. I have had a new cold start rely fitted it but still cuts out.
robert clarke
- UK - Wed 12th January 2005 10:38pm (GMT)
Subject : Re : Shogun
Hi mate, I have the same problem with
mine. Apparently it is a common fault in 2.8TD, the seal on the
fuel pump goes. I am booking
mine in at a cost of around 500, dear but i need it done, please let me know hoe you get on with urs
Irfan
Rochdale, Lancashire, UK - Mon 17th January 2005 12:11am (GMT)
Subject : Re : Re : Shogun
I have the same problem and have changed the rubber
fuel lines and cleaned out the
tank. Is the
Fuel pump you are talking about the injector pump or the primmer pump Please let me know
Paul Penney
Larne, Co. Antrim, UK - Tue 01st March 2005 04:00pm (GMT)
I too would like to get
mine sorted out.
When we do get it started, it blows out clouds of smoke, we keep wondering when the CFS is going to arrive.
As my wife says...
It's economical alright, 'cause she gets me to take her to work, 'cause it won't start some mornings.
Ian
128957
Follow Up By: Member - Vince B (NSW) - Thursday, Sep 08, 2005 at 18:09
Hi Ian.
Thanks for your help.
It would appear that my problem could me in the pump afterall. Now to find a good diesel tech on the
Gold Coast!!
Vince
383617
