Getting CT into garage
Submitted: Wednesday, Oct 12, 2005 at 15:23
ThreadID: 27212 Views:3572 Replies:26 FollowUps:23
Hi, I am asking this question because I am sure I am not the only person with this potential problem.
I am about to purchase an offroad CT and need to be able to park it out the back for the time we are not using it. Most of the time at this stage. I have a driveway about 50m long down the side of the house with the garage at the end of it. I need to get the camper in the garage so I can back up to it and hitch it up and tow it out of the yard the right way around. My problem is that the driveway is very narrow and there will only be about 90mm either side of the CT and the vehicle. I therefore think it is not realistic to back it in as there is absolutely no manoeuvering room. The CT weighs about 1tonne empty, so it would be quite difficult to push it along the drive manually - also, drive is a bit rough with grass in the middle of two tracks, so the jockey wheel would create a lot of friction. How do people overcome this problem?
Reply By: Member - Chrispy (NSW) - Wednesday, Oct 12, 2005 at 15:29
Get a jockey wheel with a ratchet? I saw them at S/C for about $130 last time I looked....
AnswerID: 134309
Follow Up By: Member - Chrispy (NSW) - Wednesday, Oct 12, 2005 at 15:32
Like this one...
Ratchet-driven jockey wheel: [ View Image]
FollowupID: 388413
Follow Up By: flappa - Wednesday, Oct 12, 2005 at 15:49
I have one of those Jockey Wheels on my CT and works really well , except, grassy and or muddy inclines.
If the driveway is flat , then being on grass with this jockey wheel wont be an issue and it will push/pull 1000kg easy enough.
FollowupID: 388417
Follow Up By: Sky Pilot - Wednesday, Oct 12, 2005 at 15:54
A question about the ratchet jockey wheel. Can it push the trailer backwards and not just pull forwards? That is what it'll take to get it into the garage right way around.
FollowupID: 388418
Follow Up By: Member - Chrispy (NSW) - Wednesday, Oct 12, 2005 at 15:54
I guess my main point with it is that it's slow too... so you wouldn't go screaming into the walls, hitting them given that you've only got 90mm either side to fool with.
FollowupID: 388419
Follow Up By: Member - Chrispy (NSW) - Wednesday, Oct 12, 2005 at 15:55
Sky Pilot - just turn it around!!!
FollowupID: 388420
Follow Up By: flappa - Wednesday, Oct 12, 2005 at 16:11
Works either way , push or pull.
Its just a matter of flipping the rachet over.
FollowupID: 388426
Follow Up By: flappa - Wednesday, Oct 12, 2005 at 16:15
Quote: I guess my main point with it is that it's slow too... so you wouldn't go screaming into the walls, hitting them given that you've only got 90mm either side to fool with.
Actually , you would be surprised at what can happen.
I almost lost my CT in the creek using one of these.
Once its moving , it uses its own momentum (sp) to keep moving.
The Rachet doesn't have any braking system , so , if it goes . . . it keeps going.
FollowupID: 388427
Follow Up By: Member - Chrispy (NSW) - Wednesday, Oct 12, 2005 at 16:23
Yeah... but I think he's talking about using it on a long, but generally flat driveway.
FollowupID: 388428
Reply By: Member - Beatit (QLD) - Wednesday, Oct 12, 2005 at 15:43
G'day Sky Pilot,
Some time ago I saw an advertisement for a 12V power dolly that has a tow ball on top and drives the trailer. From memory it is UK inspired but the add was local and seemed to have a caravan/boat application so should do the job. Thought the add was from North Qld somewhere.
Sorry don't have any further details.
Kind regards
AnswerID: 134311
Follow Up By: Member - Jerry C (WA) - Wednesday, Oct 12, 2005 at 23:11
Hi Sky Pilot,
A couple of suggestions, look at "Power Dolly" on Google there are plenty. The other is go to your nearest Light Airport, Bankstown, Archerfield etc and walk around some of the hangers, there are probably plenty of Briggs & Stratton engines driving a pair of wheels pushing / pulling light aircraft around, maybe even some electric models and if you are handy with a welder go for it.
Jerry
FollowupID: 388466
Reply By: Member - Roachie (SA) - Wednesday, Oct 12, 2005 at 15:43
Have you considered mounting a towbar on the front of your vehicle's bullbar? This makes it so much easier to actuately move a trailer/van up a driveway. However, with only 90mm either side, I think that whatever you decide to do, you are gunna have to have 3 people involved (one on either side watching wall/fence etc) and you (the driver).
Other than that, it could be done using the same idea on a ride-on mower etc, as long as the driveway is reasonably flat.
AnswerID: 134312
Follow Up By: Member - Beatit (QLD) - Wednesday, Oct 12, 2005 at 15:46
G'day Roachie,
Think you have to have the tow ball off centre so as the driver can see. This could be a problem as weel.
Kind regards
FollowupID: 388416
Reply By: Member - Paul P (Bris) - Wednesday, Oct 12, 2005 at 15:50
G'day
I use a jockey wheel with a ratchet lever mechanism(see your Super Cheap Store)
I have a fully concreted driveway and enough room to turn my CT around.
I drive my vehicle into the shed with the trailer attached. Disconnect the trailer and (using the ratchet wheel and a little muscle) park the CT hitch in along side the vehicle ( in the shed).
When hitching up I reverse the vehicle up my driveway and turn my CT around ( I can do this in my shed if I have to with a little hand/lever powered manual backing and shoving)
In your case I suspect a little backing and shoving using your vehicle may be need as well.
If you have a part time 4wd with auto hubs fit a set of manual hubs and then you can use low range in 2 wheel drive , on hard surfaces, without dramas.
If the area is relatively flat the ratchet jockey wheels will work quite well, even if the ground is a little uneven. Mine has a pump up tyre.
My thoughts
Paul
AnswerID: 134313
Follow Up By: Sky Pilot - Wednesday, Oct 12, 2005 at 15:56
Unfortunately it is a single garage - I have no manoeuvering room anywhere between the front gate and garage. If the ratchet device can push the CT backwards, it may be possible.
FollowupID: 388422
Follow Up By: Member - Paul P (Bris) - Wednesday, Oct 12, 2005 at 16:01
The ratchet wheel is probably worth a try. They are not to expensive. They work in any direction. Mine has quite a long handle allowing the application of good leverage. Make sure the tyre is pumped up to recommended pressure.
Paul
FollowupID: 388423
Reply By: Peter 2 - Wednesday, Oct 12, 2005 at 15:57
Another idea the father in law did was to get one of those 12v supercheap boat winches (the black ones that are a copy of an actual superwinch, about $90 from memory), connected it to a battery in the garage (which was charged occasionally) and dragged his caravan backwards up hill into the garage, was very tight like your situation.
Then he would tow it out when going away.
Eventually he knocked the back out of the garage and stored the van in a carport behind the garage.
AnswerID: 134314
Reply By: Member - Jay Gee (WA) - Wednesday, Oct 12, 2005 at 15:59
I purchased a trailer jockey from one of those accesory places. Forgot the name of the place but can check when I get home tomorrow.
It cost about $120 or so and is really useful for moving trailers around.
AnswerID: 134315
Reply By: signman - Wednesday, Oct 12, 2005 at 16:02
Why not just reverse it down on the vehicle.
Heck it's only a 50 metre driveway, and you've got 90mm either side.
AnswerID: 134316
Follow Up By: Member - Chrispy (NSW) - Wednesday, Oct 12, 2005 at 16:07
And... if it's a rental property.....
"Oh! I didn't see those huge scrape marks down the side of the house ma'am! It must've been the last tennant!!"
If it's a mortgage of your own on it... go the jockey wheel :)
FollowupID: 388424
Reply By: Member - Steve (ACT) - Wednesday, Oct 12, 2005 at 16:14
I'm assuming you have a trailer with the small solid tyre on the Jockey wheel, I got sick of trying to move the trailer on soft ground after camping for an extended period and changed the wheel to one of the large pump up tyre type from a caravan shop.
We found when trying to move the camper because of it's weight it was getting it moving that was hard, once the momentum was there it was fine. The larger wheel made getting the momentum up and manouvering the trailer much easier.
Not sure if that helps but worked for us.
Sandy
AnswerID: 134318
Reply By: ev700 - Wednesday, Oct 12, 2005 at 16:46
Sky Pilot
If you saying that:
- you must leave the landcsaping, grass, fence, gates etc as is; and
- you cannot reverse it even with assistance.
Then that rules out the towing vehicle unless you want to put a tongue and ball on the front of the vehicle. But you may not want to do that.
And it also rules out mechanised/levered/powered jockey wheels and manual pushing. Because as you said the ere is an undulating surface and soft ground in the middle (which you don't want to concrete or put in landscaping 50/50 grass and blocks.
If you could get it in off the street you could bridle the rear of the CT and tow with and electric winch from the end of the driveway while one person helps steer the CT from the front (after unhitching from vehicle of course). People use such arrangements to drag boats from the water. You can buy cheap electric winches of suitable capacity (power and cable length).
But maybe your gate is too narrow for easy reversing from the street and you don't want to widen it. Then you could put a towing tongue on the front of the car and do it that way (as mentioned earlier). But maybe that is not on either.
Another way is an expensive turn table in the front (needs $ and flat ground) or equally expensive two level parking alongside house towards front (as seen at the caravan shows). But even if you had the $, you still need to get the CT into the front yard.
My final idea could be rails - but that would be ruled out if you didn't want to change the landscaping and anyhow the surface could be undulating (or uphill where a winch would also be required).
I'd possibly put a cover and entrance on the other side of the yard but I accept this is probably ruled out. Either that or put in a double carport at the front.
I regret that I can't think of a solution off the top of my head unless you can change some of the parameters to help.
EV700
AnswerID: 134322
Reply By: John L G - Wednesday, Oct 12, 2005 at 17:17
Sky
If you have a winch on the bull bar why not use that?
Simply put a block in the garage and run the wire under the trailer, up to the block in the garage and back to the rear of the camper.
Simple, no cost and easily controlled from your hand piece.
John G
AnswerID: 134326
Reply By: ev700 - Wednesday, Oct 12, 2005 at 17:59
Cripes if this is someone trying to get ideas for a money-making invention we should all get a cut.
Another idea is to bolt or weld an el cheapo (but hopefully robust) winch to the rear of the CT. Then it is always there for recovering the CT as well. Operatie off the CT's batteries.
Hope there is a Minty for that.
EV700
AnswerID: 134332
Reply By: kev.h - Wednesday, Oct 12, 2005 at 18:32
Hi Sky Pilot
The simplest solution assuming your drive is fairly flat is to make a dual jocky wheel from two wheel barrow wheels with a ball mounted in the middle to go into your hitch then add a long handle between the wheels have seen this used in caravan yards if you want i can email you drawings pretty simple and works well
much easier as you have a handle to steer with
Regards Kev
AnswerID: 134336
Follow Up By: Tim HJ61 (WA) - Saturday, Oct 22, 2005 at 19:35
One of these on ebay at the moment - Item number: 4583048076
FollowupID: 389649
Reply By: Kiwi Kia - Wednesday, Oct 12, 2005 at 20:34
Hey sky pilot, if you have pushed a Cessna or Piper around the tarmac you will have used a T bar attached to the nose wheel huband steered with one hand, easy as... Well, just do the same to the jockey wheel on the trailer.
AnswerID: 134359
Reply By: Sky Pilot - Wednesday, Oct 12, 2005 at 21:03
Boy, talk about quick response. I am blown away by the number and quaility of responses. Just adding a little to the parameters.
90mm either side of both CT and vehicle to house and fence.
CT must be backed in so I can tow it out.
No room in single garage to manoeuvre.
No room in back yard to manoeuvre - the garage is only about 20 feet from the back of the house.
driveway flat but rough in the centre - I might have to concrete the centre or the jockey wheel would be running on dirt and grass and the odd low plant my wife loves to grow in it.
No winch on bull bar.
I like the winching options though. The one with the permanent electric winch mounted on the back of the CT is interesting - as long as it didn't pull the back wall out of the shed ;-)
Also, the ratchet handle for the jockey wheel looks like it has potential,
We're not leasing, but SWMBO would kill me if I scratched the house ;->
AnswerID: 134371
Follow Up By: ev700 - Thursday, Oct 13, 2005 at 08:55
Quote: "- as long as it didn't pull the back wall out of the shed ;-)"
OK here we go: "You could improve the anchor point in advance, Dear Martha, Dear Martha".
Sorry, no offence intended - my spouse says "Yes, but" to me frequently and I have become a bit sensitive to it. It reminds me of that song about the hole in the bucket. ;-)
FollowupID: 388483
Follow Up By: chump_boy - Thursday, Oct 13, 2005 at 09:11
Sky Pilot,
If you are looking for a small, electric winch, let me know. I import the larger (9500lb and 12000lb) units, but my supplier also makes small ATV winches. I could get a quote if you are looking...
email is chumpion at tpg dot com dot au.
FollowupID: 388486
Reply By: Andrew from TrekTable - Wednesday, Oct 12, 2005 at 21:15
Sky Pilot,
I'm with Roachie on this one. Once you have a towbar mounted to the front of your car, you'll find it ever so helpful. Don't mount it off centre, put it right in the middle. I push my 23foot boat around this way and you can see everything you need to. You get very, very accurate control.
I've made brackets that fit inside the bullbar plus others which mount to the winch plate. My preference is to use square RHS the same size as your Hayman Reese towbar so you can simply unhitch your whole towbar tongue (leaving your CT attached to the TREGG hitch), turn your car around and slide the tongue into the front mount. You then have your front towbar with you wherever you go simply by swapping the tongue from back to front.
Food for thought and not expensive.
Andrew
AnswerID: 134375
Reply By: Member - Pesty (SA) - Wednesday, Oct 12, 2005 at 21:17
Sky pilot
You can get a dual wheel jockey wheel and also electric ones too
Call at your nearest caravan accessories place , I think they will have most of the options available.
Also maybe a caravan/CT forum site may also have ideas
Cheers Pesty
AnswerID: 134376
Reply By: OMN - Wednesday, Oct 12, 2005 at 21:57
I can't back a CT very far without challenge but seriously my mate can back a CT or anyhting much else down a driveway and into a shed with 90mm or thereabouttts each side with hardly a missed beat.
Or more precisely the bit i ahve watched him back down is literally just wider than the mirrors on a 100 series or Patrol. I had difficulty driving the CT out of his driveway forwards let alone backing down it without the CT on the back.
Admitedly he has a lot of practice towing trailers almost 3 times a week on average etc.
But if your car fits down the driveway then it can be done, not by me but it can be done.
Mark
AnswerID: 134393
Follow Up By: Sky Pilot - Wednesday, Oct 12, 2005 at 22:12
Something to think about and maybe work up to - slowly. In a LC100, I have to fold the driver's side mirror back to get through the gate. That will give you an idea of width. The gate is the narrowest part, but there is one other spot equally as narrow where a downpipe runs down from the guttering. That I might end up getting shifted if possible.
FollowupID: 388461
Reply By: Paul - OzRoamer Camper Trailer - Wednesday, Oct 12, 2005 at 22:42
Hi Sky Pilot
I have the same problem at times and have considred getting one ofthese.
http://www.eztug.com/
Whilst expensive they will solve your problems and maybe save damage on both your new CT and the house.
AnswerID: 134409
Follow Up By: Sky Pilot - Thursday, Oct 13, 2005 at 06:45
Thats pretty impressive isn't it. So easy. Do you know if they're available in Oz? I'd say it would be pretty expensive, but would certainly allow you to manoeuvre anywhere.
FollowupID: 388474
Reply By: Member - Davoe (Widgiemooltha) - Thursday, Oct 13, 2005 at 00:03
You might surprise yourself especially with some practise. Pay carefull attention to your mirrors and use low range . dont be afraid to drive forwards a couple of metres if things start going north and straighten things up. I am not the worlds best reverser and do it infrequently but by taking it easy I usually make do when the need arises. the more you do it the easier it wil get. when at caravan parks you will be able to earn cartons doing complicated reversing manoeveres for grey nomads as they seem to struggle with even basic reversing
AnswerID: 134421
Follow Up By: muzzgit (WA) - Friday, Oct 14, 2005 at 00:22
YEP. That can be fun.
FollowupID: 388598
Reply By: Sand Man (SA) - Thursday, Oct 13, 2005 at 08:14
What is your budget restraints?
At the last Caravan & Camping show I saw the ultimate solution to your problem.
The Caravan or Camper trailer is permanently fitted with an electric motor to each main wheel and you "drive" the thing with a remote control joystick, whilst you are in any position around the trailer that you desire. Probably more suited for the "bushtracker" type van but would certainly solve your problem.
You just need to determine the pros & cons.
Cheapest solution is no doubt the ratchet type jockey wheel and because it sounds like you need a driveway repair anyway, why not brick pave it and fill in the centre bit.
Bill
AnswerID: 134438
Reply By: ev700 - Thursday, Oct 13, 2005 at 08:46
Sky Pilot
Can you competently reverse the trailer off the road and through the front gate?
This is the start of the problem for most people, especially if there is a narrow busy street/narrow gate.
If not, what prevents you from widening the gate, improving the condition of the driveway etc. Especially if as you say, the mirrors of the vehicle have to be folded back because they are too wide for the gap.
With respect, could you list out all limitations and suggestions dispensed with?
It all becomes a bit academic and full of "Yes, buts" if there are limitations we are unaware of.
It is highly probable that parking the CT in storage is the best option.
EV700
AnswerID: 134442
Follow Up By: Sky Pilot - Thursday, Oct 13, 2005 at 09:39
OK, just took some pics and uploaded them. Go to this URL and look for yourself.
Driveway Restrictions
FollowupID: 388489
Follow Up By: Sky Pilot - Thursday, Oct 13, 2005 at 13:01
"This is the start of the problem for most people, especially if there is a narrow busy street/narrow gate."
Actually, ev700, having been out there when taking the photos and looking at how I might back in a CT from the road, you might be right there. The street is one way. Just two lanes wide, one for parking, one for a traffic lane. There is no parking on the other side of the street, just a gutter and a tree beyond that. Actually reversing the CT in straight enough to start it straight down the driveway might be quite difficult if not impossible.
FollowupID: 388523
Follow Up By: ev700 - Thursday, Oct 13, 2005 at 20:50
Sky Pilot
If you can drive straight in and past your house you might be able to turn the car off into the back yard and walk the CT into the garage.
However take heart that it is possible to really improve your reversing through practice in a deserted shopping centre park. But you must practice with mirrors and/or a guide.
I always feel gret sympathy for those who reverse their boats at public ramps while the yobbos make it hard by trying to beat them in. At least with a CT you are not likely to encounter the cr*p that takes place daily at busy boat ramps.
EV700
FollowupID: 388580
Reply By: Truckster (Vic) - Thursday, Oct 13, 2005 at 12:15
10cm per side clearance?
With or without a guide you should easily be able to reverse that down the driveway if you have good mirrors.
Thats more room than you think... used to have to park the boat down the backyard with similar clearance down the side of house, adn fence on other side.
Practice.. and for the 2-4 times a yr it comes out it shouldnt be an issue.
YMMV
AnswerID: 134469
Follow Up By: chump_boy - Thursday, Oct 13, 2005 at 13:13
I have to agree with Truckster on that. 9cm is actually a fair bit.
The gate posts on our drive fit nicely under the mirrors of our cruiser, so long as the airbags are inflated a bit. We then have to have one mirror in the bushes on one side (i have trimmed the bigger branches...), and clear a 10m long verandah by a couple of centimeters on the other, for the full 10m.
I backed one of those moving trailers up the other day, and it took a few goes (like 5 or 6...;-)....), but got there in the end. There was honestly a centimeter either side.
With a bit of practice, you should be fine. Just line it up right to begin, then off you go, and don't be afraid to start again.....
FollowupID: 388524
Reply By: Member - Landie - Thursday, Oct 13, 2005 at 13:26
Hi Sky pilot
Looked at your photos - me tip, back it in. Backing a KK is not too hard as it has a fairly long drawbar. A bit of practice and you'll have it sorted.
AnswerID: 134476
Reply By: SKP - Thursday, Oct 13, 2005 at 15:30
How much room is there between the house and the shed? From your photos it looks like there is enough room to manually swing the trailer 180 degrees. You could perhaps convince 'swmbo' to let you make a nice turning circle there!
( I can turn my Tvan around inside my 18' x 18' garage) Good Luck. Steve P
AnswerID: 134487
Reply By: Spade Newsom - Thursday, Oct 13, 2005 at 20:11
Sky Pilot,
I have to agree with others regarding backing it in. The challenge would be too great not to have a go. The practice itself will improve your skills here no end. You should be able to see quite well either side as long as you can get it straight to start with. You could always unhitch at the front gate, straighten it up and hitch up again until you really get the hang of it. The hardest bit I find is once you get to the shed you can't see inside it from the vehicle because the shed is dark, that's where the missus help comes in.
Had a similarish situation to yours (say 30 cm either side and 10m lane) and had to park it right angles at the end of the lane. Got it first attempt and was quite smug. About 3000 more attempts got it only once again. All that practice did improve my reversing significantly, from terrible to OK.
Good luck.
AnswerID: 134525
Reply By: Member - Brad (NSW) - Friday, Oct 14, 2005 at 04:06
Sky Pilot.
looking at your pictures if your not confident I would start with painting a green line (which isnt too ugly) down the ride hand side of the driveway. This would take a little time to set up but once you can see the right hand trailer wheel touching the line you can reverse it no problem, as i said, it will take a bit to mark out.
Another option I can see is this one and probably the option I would choose if I wasnt comfortable reversing : actually, might get especially for caravan parks etc.
A great alternative
[ View Image]
No Im not affiliated with this company, but I was impressed with how powerful this machine was.
I saw these at the Rosehill show. Must be a great advantage for all types of trailers. A lot safer I would guess in public places to.
AnswerID: 134556
