Auxiliary battery fitting to V6 2005 Prado
Submitted: Saturday, Nov 05, 2005 at 14:21
ThreadID: 27841 Views:5964 Replies:5 FollowUps:1
Greetings all, is anyone experienced in fitting an auto auxiliary battery under the bonnet of a 2005 V6 petrol Prado? I see very little space in there, left or right side, and possibly a few mods or rehanging/relocation of gear depending on the selected mounting location. I am trying to weigh up this against simply fitting a deep cycle battery inside my camper. Naturally I would prefer to have the battery fitted in the vehicle. I would appreciate any constructive help. Thanks, Mulcs.
Reply By: mprice2233 - Saturday, Nov 05, 2005 at 15:04
Try this guy
link text
AnswerID: 137922
Reply By: 4145derek - Saturday, Nov 05, 2005 at 16:29
link test
Link to D.I.Y. Kit.
AnswerID: 137930
Reply By: Member - Drew T (VIC) - Saturday, Nov 05, 2005 at 17:55
I have fitted an aux bty to my 2003 Prado 120 V6. Aux bty easily goes behind the rhs headlight once you move the power steering reservoir
Used a Pirahna tray & Redarc isolator (see previous posts). Quite a simple job & only complication is relocating that power steering reservoir (unbolt, then drill out the 3 rivets holding the top/bottom parts together & bolt the top half (the slide mount) to the new bracket which comes as part of the Pirahna tray)
PS: The kit shown in the replies above & also the SupercheapAuto kit both seem excellent value for money
AnswerID: 137940
Reply By: kimprado - Sunday, Nov 06, 2005 at 18:05
I had a dual battery system and Glind shower fitted by TJM Dandenong (Victoria) in the same model you have. The work was excellent and I have'nt had a problem.
Hope this helps.
Kim
AnswerID: 138080
Reply By: Sand Man (SA) - Monday, Nov 07, 2005 at 07:57
Another option you could consider is the use of a "thumper" portable battery system. Available in different sizes they are a practical alternative to the installation of a "permanent" second battery for a similar cost.
The "thumper" is available as a "kit", complete with a Car Charging Kit, Anderson connectors and cable and a heavy duty jump start cable this system is a true and practical alternative to a "fixed" battery. And as the battery system is an AGM type, they are completely safe. A 75A/h unit is a practical size giving sufficient capacity while still being truly portable. And being AGM they charge up relatively quickly from the vehicle alternator.
When I get to a camp site, th thumper goes in the camper annex to run the fridge, fluros, etc.
Had I known of their availability before I installed my dual battery system, I probably wouldn't have bothered with the permanent one.
I am not connected with the manufacturer in any way. Just an owner/user of one of the most practical and portable power units I have stumbled across..
The Thumper is available from Blue Apple, Home of 12 Volt. (08 85362144) and they will deliver Australia wide.
Bill
AnswerID: 138170
Follow Up By: mulcs - Monday, Nov 07, 2005 at 11:53
To 4145Derek, 2233MPrice, Drew T (Vic), kimprado and Sand Man SA
Thank you for the great ideas and alternatives. I really appreciate your help out there. This is my first contact through this site and you guys make me look forward to further tripping and meeting up along the way.
Mulcs.
FollowupID: 391869
