Gps - Flash card or mouse?
Submitted: Wednesday, Nov 30, 2005 at 09:21
Feral
Hi all,
I am looking at getting a gps for a laptop. At this stage I do not think I will run the gps/laptop out of the vehicle so there is no need to have a separate gps unit.
My question is...how sensitive is the flash card gps units are? Will it be able to pick up the sats from console/armrest area? Or will it be better to have a gps mouse that will sit on the dashboard. I would not like to have cables running everywhere hooking up to different sources so that it's least intrusive as it can be.
Any thoughts?
Lyndon.
Reply By: Sand Man (SA) - Wednesday, Nov 30, 2005 at 10:07
Lyndon,
The CF Card type GPS that fits into a PCMCIA slot of a Laptop offers the best in compactness.
No Cables, powered by Laptop, builtin aerial and with the option of an external aerial connection if required.
Check out the ones available from the ExplorOz
Shop CF Card GPS Receiver
141683
Follow Up By: pjchris - Wednesday, Nov 30, 2005 at 10:48
The only thing that I, personally, don't like about this set up is the GPS sticking out the side of the laptop.
I'm the sort of guy that tends to nudge/drop things occasionally and I'm always catching the wi-fi card that sticks out of
mine (Have broken one) and a GPS is worse as they generally are larger.
I have used a mouse GPS and wired it in to 12V in the dash so the cable to the laptop is the only worry.
Currently I use an external GPS mounted inside the dash with an external antenna. It is powered on all the time and connected both to a serial cable that hangs out in the back
seat (Where we mount the laptop) and to the charging cable for my iPaq cradle. So the GPS connects to the iPaq through the same cable as power.
The only thing that worries me about using a mouse style GPS is if some lowlife nicks it. If they nick my antenna then $30 or so buys me another.
395330
Reply By: Rod E B - Wednesday, Nov 30, 2005 at 11:53
With the units you are talking about I assume there is no maps or software
what does the software cost
are the units a good as the dedicated systems I am always getting prompts to buy
141703
Follow Up By: Sand Man (SA) - Wednesday, Nov 30, 2005 at 12:02
Software, such as OziExplorer costs about $120 and NATMAP Premium which gives you all the maps you would be likely to require, about the same.
Some people save money by begging, or digitizing printed maps, but NATMAP is the go.
I have read that some of the NATMAP images are available for free from the Government's Web site, but these are at a lower resolution.
All software is available from the ExplorOz
Shop.
395364
Reply By: Member - t0me (WA) - Wednesday, Nov 30, 2005 at 14:50
The 250k natmap's are available for free on their website (there was a link in the forums earlier). They will do for the most part.
Ozi Explorer is the go for sure. Then copilot or something to satisfy the people telling you to buy one of those all in one jobbies (it will tell you how to get to an address, Ozi won't do that).
If you go for PCMCIA card you will still need an aerial unless the card can see the sky (to see the satellites, and the more sky it see's the more satellites its likely to pickup. So the mouse type is going to be more suitable I think. Lets face it, the laptop is going to be the most intrusive thing, a little mouse gps and its cables won't be much compared to that.
A Bluetooth gps reciever would take care of one wire but you still need to plug it in to charge it up (power) so you're still going to need one cable to it anyway. In your case probably not worth the bother.
If you've got a heated windshield I believe they can block some of reciever's ability to see satellites (I think there's some debate about that). On the armrest the device won't see much of the sky and so won't pickup satellites as easily as it will if its on the dash. I'm not sure if the reciever's are directional at all,
mine always faces up and on the dash.
141743
Reply By: Bonz (Vic) - Wednesday, Nov 30, 2005 at 19:06
Why dont you wire a bluetooth mouse in permanently? No other wires and works a treat
141781
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Nov 30, 2005 at 22:55
yeh, they are great Bonz but I use
mine in the car too so I want to be able to velcro it to the car windscreen too :-)
395477
Reply By: Mr Fawlty - Wednesday, Nov 30, 2005 at 19:39
I am going thru the same process as we speak. I have decided on the mouse GPS antenna which has a magnetic mouse and requires one lead from the antenna mounted on your roof magnetically to the USB port on your laptop. Heaps of them on Ebay for around $80 complete with software. Looks like I will still need maps and driver software if I want anything other than a large GPS. The software is the heart of this type of system especially if you want voice navigation commands. Easier to input your destination etc with a proper keyboard as
well. Several of the PCMIA card devices have an additional antenna that can be externally mounted. All up I recon I can get a vey good navigation system for around $450 which will cover all of Australia (not just main roads) which is about half what you would pay for a Navman or similar....
141797
Follow Up By: Member - Drew T (VIC) - Thursday, Dec 01, 2005 at 10:23
Fawlty .. other than COPILOT mentioned above, what route planning software (ie: directions) have you looked at & what do you reckon is best/
395532
Follow Up By: Mr Fawlty - Thursday, Dec 01, 2005 at 17:15
I am in the middle of an evaluation process, Copilot looks good but I want to find a "source" before I make a commitment... I'm questioning several sellers on Ebay but they don't seem to understand my questions or don't speak english or both. Try doing a Google search for "navigation software" or similar what is out there is amazing. The maps can be downloaded free or you can buy them from Natmap for around $200...
395574
Follow Up By: pjchris - Thursday, Dec 01, 2005 at 17:27
If you're in
Melbourne, have a chat with a company called Organiser world. they sell the CoPilot software amongst others)and are very helpful.
Look them up on the web at Organiser World and give them a ring.
ps. Not associated with them at all...Just a happy customer having bought 2 PDA's and the CoPilot software there.
395581
