Annex Pole carriers
Submitted: Thursday, Dec 01, 2005 at 00:12
Rob DG
Hi all, this is my first post and I'm far from experienced. I have a Coromal Silhouette and in order to reduce my tow ball weight I want to mount a pole carrier under the rear of the camper in a north south direction rather than east west. Has anyone done something like this before? or thought about it and then decided not to for wome reason.
Rob
Reply By: Member - Kimberly Kruiser (WA) - Thursday, Dec 01, 2005 at 00:25
G'day Rob
The only real problem with mounting underneath, in a north south direction is that if using the traditional plastic tubes they will be smashed to bits by flying rocks if you do any gravel/dirt work.
The same will happen when mounted east west on the draw bar unless protected in some form.
You will probably receive varied opinions but I really prefer a little extra weight on the ball if your tow vehicle is up to it. Helps the dog stop wagging it's tail so to speak.
Wal.
141858
Reply By: Member - Athol (NSW) - Thursday, Dec 01, 2005 at 02:36
Hi Rob,
whichever way you mount it go to clark rubber and buy a couple of pieces of foam to put inside the ends (I got 3" from memory). The first trip i went on punched a hole through the end of tube. Oh and mount it
well, spoke to a chap at
Innamincka that had lost the lot poles and all, somebody got a bonus if they didnt run over it. Athol
141865
Follow Up By: Sand Man (SA) - Thursday, Dec 01, 2005 at 08:57
Better still, buy purpose designed strengthened endcaps, as used by Telstra, etc.
One type is
orange coloured and screws on.
A dearer, but you beaut twist lock black one is also available, both types from Rhino-Rack, etc.
This is a safety issue not many think about, but the standard PVC endcaps available from Hardware stores are only thin walled and become brittle over time from the Sun's ultra-violet rays.
395510
Reply By: Paul - OzRoamer Camper Trailer - Thursday, Dec 01, 2005 at 07:19
Rob
I think you are playing with fire and as said above stay away from the PVC unless VERY
well protected.
Consider an alloy or Stainless Steel tube (???) on the small rear bar but still in a East West setup. (we do one but not cheap)
Under the body you are playing around with clearence levels and also placing weight on a very light body material - I think the rear bar (if you have one) would be an idea.
141875
Reply By: Member - Raymond - Thursday, Dec 01, 2005 at 07:28
Hi Rob
Had two under the tray of a GU for 90000klms without any damage to them. I had foam in the end caps and also made sure all the poles were the same lenght, made the tube just long enough so that the poles could not move inside them. They were held to the tray with plumbing clamps.
Not sure what the underside of the camper is like for room and clearance though
Regards Ray
141878
Reply By: Ray Bates - Thursday, Dec 01, 2005 at 09:55
I have two 4" PVC tubes on
mine. One on the drawbar and one on the rear bumber bar. They are held on by 'U' bolts and have never given trouble. This way weight is evenly distributed
141910
Reply By: Banjo 1 - Thursday, Dec 01, 2005 at 10:01
Yep -whatever way you go, end protection inside is a good move - the pole ends do suffer damage - the pastic fittings (caps and pin inserts etc) all get hammered. I'd go metal underneath - and heavy duty mountings to boot.
141912
Reply By: Rob DG - Friday, Dec 02, 2005 at 00:52
All,
Thanks for the advice obviously there are pros and cons for idea but with the right sort of prep I think that the posts indicate its workable. Clearance isn't really an issue as they will be no lower than the
water tank, I think.
Alloy and stainless seem a bit excessive, my Silhouette is the on road model and I'm not expecting to tackle anything rougher that a formed track. That said I did do the Beef development road in NQ years ago and my MQ nearly fell apart.
I hear what you are saying about the end caps and protection so will watchout for that.
Rob
142062
