faulty fridge
Submitted: Wednesday, Feb 01, 2006 at 17:13
dublediff
I have just opened my in-laws caravan up - it has been in storage for 7 years - and the 3 way fridge is reeking of amonia. I know that this is what they pump for refridgerant so there is something amiss. Before I take it to the repairers is there somebody who can enlighten me as to the possible causes and remedies, as
well as costs. I don't want to turn up at the workshop and appear too dumb??? I guess it is probably just perished seals or similar but some turkey told me it's a whole new fridge that is needed. thanks.
Reply By: Pajman Pete (SA) - Wednesday, Feb 01, 2006 at 17:21
My dad had a chesscold 3 way that went the same way. The repairer's solution - replace the cooling section which cost only slightly less than a new fridge.
Ammonia dissolved in
water is the active mixture so it seem you do have a leak. Looking at the dometic in our Jayco I can't see any seals so I would suspect a punctured condenser or corroded pipework may be the cause.
Pete
152315
Follow Up By: dublediff - Wednesday, Feb 01, 2006 at 22:54
That's what I thought...rats! Thanks Pete.
406105
Reply By: Member No 1- Wednesday, Feb 01, 2006 at 18:31
yep it defintely sounds like corroded pipework
its a hermetically sealed system, so no seals etc
take it to the dump...... and save the money you'll otherwise spend on a repairer telling you the same thing
152327
Follow Up By: dublediff - Wednesday, Feb 01, 2006 at 22:56
Use it or lose it!!!! I think I've lost it! Anybody got a good second hand caravan fridge for sale....Thanks numero uno.
406107
Reply By: obone - Thursday, Feb 02, 2006 at 14:51
hI dd, just had the same problem with
mine. I had a reconditioned cooling unit put in at a cost of $500 (with a 12 month back to base warranty) If you live in the
Sydney area I can give you the name of the repairer. Be careful buying a second hand fridge, if it's more than about 12 years old you could be buying somebody elses problem
Obone
152518
Follow Up By: dublediff - Thursday, Feb 02, 2006 at 15:11
It must be the fantastic weather that we have in
Melbourne that means I have to pay $880 for the same repair- doh! Getting a changeover unit fitted as I speak. I had a nightmare about buying a second hand unit last night too!! Thanks.
406253
Reply By: Member - Roachie (SA) - Thursday, Feb 02, 2006 at 15:40
I used to call the 3 way fridge in our camper "Jeanette" (after Mrs
Howard); cos it was "next to useless".....hahahaha
Anyway, I opted to replace it with a 12/240 volt unit from Engel. Waeco also make a similar sort of unit. Just need to make sure you've got enough battery capacity if you're going to be away from civilisation for weeks at a time....I have 2 x 105a/h SuperCharge SLA batteries that do a great job.
The compressor fridge will set you back about $1,000- for an 80 litre size and is HEAPS better at keeping a constant temp without the need to be dead level like the 3 way units.
Roachie
152533
Follow Up By: dublediff - Friday, Feb 03, 2006 at 14:51
Thanks Roachie, I thought about that angle, but this fridge is 120 litres and built in to the cabinets, the cheapest option was the changover cooling unit. I have a 40 litre engle and that gets plenty of beer cooling duties....
406463
