HZJ105 Extended Brake Lines
Submitted: Monday, May 22, 2006 at 20:28
ThreadID: 34147 Views:2796 Replies:3 FollowUps:3
About to fit a 3 inch lift to the 100 series. Just wondering if anyone has any comments/experience on running extended brake lines or not running them. I am guessing that in the worst case, at full extension of the suspension, bang go the brakes....
Any comments?
Toytruck
Reply By: Member - Doug T (QLD) - Monday, May 22, 2006 at 20:50
Yep thats about the gist of it, I fitted OMEs to my troopie and i notice the lines are at the limits so maybe i should get one of the hose people to knock up a set for me ,can't think of the name of hand but you know who i mean actually there is 2 well knowns ...geez i'm brain dead tonight
AnswerID: 174069
Follow Up By: Toytruck - Monday, May 22, 2006 at 20:57
Doug T,
don't worry mate, I getting more and more brain dead every day. I rekon its too much work and not enough play.
Toytruck
FollowupID: 430037
Follow Up By: Member - Stephen M (NSW) - Tuesday, May 23, 2006 at 20:34
Enzed and Pertex are our main ones here in Sydney. Regards Steve M
FollowupID: 430367
Reply By: kookaburra - Monday, May 22, 2006 at 22:31
hi all, spinners automotive at miami gold coast make long brake hoses for all makes, test them to 3.500 psi. regards kookaburra
AnswerID: 174099
Reply By: Member - Hughesy (SA) - Tuesday, May 23, 2006 at 12:52
Toy truck, I just fitted a 2inch lift but ended up lifting it 4 inches over what it was (dist from centre of hub to wheel arch is 60.5cm and 64cm for front and rear respectively). With the 105 series the flexible brake line runs to the centre of the diff and then out to each side of the diff. Therefore the movement in the middle of the diff is nowhere near as bad as what it is at each wheel. With the diffs at full drop (during fitting) I still didn't get the brake lines taught. I'd reckon you be pretty safe with a 3 inch lift unless you had some other extreme suspension mods going on the rig.
AnswerID: 174205
Follow Up By: Alloy c/t - Tuesday, May 23, 2006 at 12:57
Hope that 60.5cm and 64cm was a typo .,, an otherwise 2 foot lift !!!
FollowupID: 430208
