Steel Rims for LC 100 TD IFS, impossible to get
Submitted: Thursday, Jun 29, 2006 at 17:24
Dirk 32
Oh NOOO... not another wheel/tyre question... but I would really like too see if someone might have an answer for my problem.
I own a LC 100 TD IFS (2006 model) and this seems to be the problem. I wanted to replace my factory alloys and buy a set of Cooper Tyres on STEEL rims. I rang around several tyre
places and all of them said that there are no steel rims available for my car and apparently the combination of the following is the problem in terms of the offset of the
wheels.
Independent Front
Suspension,
Turbo Diesel,
5 Studs
They said if it would have been a V8 they could help me out, but I assume they use 6 Studs.
Is there any way I can get Steel Rims 16x8 for my verhicle??? I find it really hard to believe that there is no soultion for my problem.
Thanks to all of you who took some of their time to read another Wheel/Tyre-Question.
Dirk
Reply By: Member No 1- Thursday, Jun 29, 2006 at 17:35
my 2006 has 17 inch rims?
dunno if 16 ins fit or not......but going by toyota the answer was a resounding NO!
181068
Reply By: luch - Thursday, Jun 29, 2006 at 17:35
try these
Site Link
181069
Follow Up By: Member No 1- Thursday, Jun 29, 2006 at 17:42
for the standard diesel?
its only the GXL petrol turbo diesels which have 17ins alloys
437405
Follow Up By: luch - Thursday, Jun 29, 2006 at 18:18
You might be right not sure
437412
Follow Up By: Dirk 32 - Thursday, Jun 29, 2006 at 18:24
Sorry, forgot that
I have 17 inch alloys on it at the moment, but want to change to 16inch steel... that shouldn't be a problem... wouldn't see, why...
Dirk
437416
Reply By: BennHW - Thursday, Jun 29, 2006 at 17:41
Hi Dirk,
I had a similar problem getting steel rims for my 4X4 - though the problem was with off-set rather than stud pattern.
I wound up going to a mob in
Brisbane called Race Engineering.
They used standard ROH components and welded up the centre to my specification.
If ROH make a 5-stud centre to fit your vehicle, then they could probably do the job ... mind you, if ROH already make a 5-stud pattern to suit your LC, then they probably already have a factory wheel. (Alternatively, Race Engineering might be able to get 'blanks' and drill them to your specs.)
Do a google search for ROH
wheels and you'll turn up their site. They have a PDF fitment chart you can view to see the sizes available.
Hope this helps.
Benn
181073
Reply By: Richard W (NSW) - Thursday, Jun 29, 2006 at 18:14
Dirk,
I replaced the factory steel's with alloys and kept the 5 pattern steels. Running BFG muds on the alloys and AT's on the steels. Check ebay as they come up all the time.
181076
Follow Up By: Dirk 32 - Thursday, Jun 29, 2006 at 19:29
Your's is also a TD like
mine and it came with factory steel. It seems that it is all about the offset. Do you know the offset of your steel rims? is it 60p or something else?
What does 60 p actually stand for?
Dirk
437426
Follow Up By: GaryInOz (Vic) - Thursday, Jun 29, 2006 at 20:57
60p would be a +60 offset. It means the mounting surface (Ms) for the wheel is 60 mm outside the line of the centerline(Cl) of the rim
inside rim|.................Cl...(+60mm)...Ms.........|outside rim
If you can make sense of the diagram
437452
Follow Up By: Member - Andrew W (SA) - Thursday, Jun 29, 2006 at 21:41
Agree with Richard.
The offsets on all IFS Landcruisers are the same as far as I have seen.
The 16"
wheels of IFS Landcruisers should fit (though they won't be 17" surprise surprise) but they will be 5-stud.
They are sold frequent on eBay and usually a 5-setter goes for $200 and singles for about $50. Of course, whip up the bidding and who knows what price the nuts could pay!
Don't buy the 16" steel
wheels from Live Axle Landcruisers - they won't fit ...
well they won't work, even though they have the right stud pattern.
Ciao for now
Andrew.
437463
Reply By: Trekkie (Member - WA) - Thursday, Jun 29, 2006 at 22:02
I think my 2001 LC 100 TD IFS will have the same as your 2006 - I had alloys when I purchased it and have kept them with the original rubber. I purchased a set of steels from the dealer who I got the car from. Apparently a lot of people put after market alloys on & the dealers sometimes sell the OE steels cheap (about $250 for 5) Thats what I did and put Coopers on the steels.
Anyway I recently damaged one of the steels (dont ask me how) and I have been looking around for one. No big hurry, but they are available for around $50 to $65 - Toyota also sell them but want to charge half the price of a whole new car. As suggested try ebay or one of the local sunday trader papers. In
Perth Quokka is a good place to start. The other option is to let your tyre man know what you want. Next time he swaps a set of steels for alloys he can do a deal.
181117
Follow Up By: Richard W (NSW) - Friday, Jun 30, 2006 at 06:14
At the time they asked me how many steels I wanted so I took 6. :-)
437486
Follow Up By: Member No 1- Friday, Jun 30, 2006 at 07:57
2001 V 2006
2001 has 16 ins.....the 2006 td has 17ins...not the same....will they fit? I dont know...in May when I was sorting out delivery time and tyres I wanted ie BFG's AT's Toyota said no go..BFG dont make 17ins...i said take the efin mags off and fit 16 steels with the BFG's...they said no go..the steels wont fit! cant see why myself but they say no.
when I go to get rotation i will take my spare 16 steels and see if they fit.....another couple of k's yet
437495
Follow Up By: Trekkie (Member - WA) - Saturday, Jul 01, 2006 at 00:33
Member 1, Thanks, I was not aware of that. I notice the specs on my year 2001 for GXL and GXV the rims are 8JJx16 for both steel and alloy and on the specs for 2006 the Standard Diesel is the same at 8JJx16 while the TD is 8Jx17. From this you could expect them to be interchangable.
437652
Reply By: stevesub - Friday, Jun 30, 2006 at 08:27
I recently bought a rim for our 78 series Troopy from Goodyear at Morayfield just north of
Brisbane. (Look up the white pages or Goodyear site for contact details) I am sure that I spied a couple of 100 series 5 stud rims there as
well - and they can get more. They sell them for $15 each second hand.
Worth while giving them a call as they say they source second hand
wheels for those of us that want more then the 5
wheels supplied with the vehicle and don't rubbish you like some dealers do if you want split rims as
Stevesub
181146
Reply By: hilux steve - Friday, Jun 30, 2006 at 11:49
best advice, ring the local dealers and c if they have a set of 16X8 ifs steel
wheels,
before the cruiser went to 17inch alloy
wheels they had standard 16x8 steel rims (except for sahara), a lot of the dealers have rims lying around from when the customer requested accessory alloy
wheels, the dealers will have them.
(all 100 series cruisers have 5 stud pattern)
181196
Reply By: barelythere - Friday, Jun 30, 2006 at 18:04
Hi there,I have 4 Toyota GXL steel rims for Landcruiser 100 series and they fit Independant Front
Suspension.There are 4 rims and tyres with Dunlop Grandtrek tyres with about 40-50% tread and hub caps,selling for $400,you can call me on 0400130230 or email,located in
Sydney. Thanks
181270
Reply By: 100TD - Friday, Jun 30, 2006 at 18:51
offset from 98/99 V8 only and 2000 V8 and TD up to now are the same.i bought a second set of rims for muddies that only had delivery kms on them for $20 each from a guy in the trading post.he had heaps of them he got from the dealer he works at.slight problem i cant find his name or address at this stage.Paul
181276
Reply By: Dirk 32 - Monday, Jul 03, 2006 at 13:56
One more time, thank you to all of you!
All confusion is gone and I am almost on my way to pick up some steel rims.
All that only started because one tyre place told me that the current IFS V8 and IFS TD have different offsets.
All clear now.
Thanks a lot
Dirk
181602
