VIC HIGH COUNTRY MAPS - I NEED HELP !
Submitted: Wednesday, Jul 19, 2006 at 20:26
Member - Willie , Epping .Syd.
Good evening ,
I got the Rooftop Adventure maps suggested on my previous enquiry last week , but none of them seem to cover the area east of a line drawn south from
Mitta Mitta to the
Mitchell River N.P.
I have a heap of maps for west of this line but nothing to the east . I am intersted in the
Mitta Mitta River area upstream from the dam , Snowy
Creek , Gibbo River in the north and the
Tambo River and Haunted Stream in the south .
I have looked at the Adventure maps in the ExplorOz
shop , but when you click on them the map you get is too small to read . ( The
shop should address this )
Thanks ,
Willie .
Reply By: Crackles - Wednesday, Jul 19, 2006 at 21:31
Unfortunately Willie Rooftop maps haven't covererd that area yet & the only other general touring map by Hema (1:300,000 The High Country Victoria) is a little outdated & inacurate in
places. The best maps by far are the 1:50K or 1:25k topographic series but can get pretty expensive when covering a large area. As a general planning map the Hema sheet would do but the scale does tend to get one a little lost at times. Some others may be able to shed light on more options but I'm unaware of any at this time.
Cheers Craig.........
184354
Follow Up By: Crackles - Wednesday, Jul 19, 2006 at 21:52
One map I forgot to add that covers the Haunted stream & Cassilis areas is the Rooftops "Bairnsdale / Dargo" sheet (#1). It has a fair bit of overlap to the North West with the other ones you already have but doesn't go far enough to cover the Mitta & NSW border area. It almost covers right down to the coast but the 4x4 tracks down that way are disjointed, have fewer highlights & generally aren't as challenging.
Cheers Craig............
441016
Reply By: Trevor M (SA) - Wednesday, Jul 19, 2006 at 23:24
I have a set of Columbus High country maps that I am sure will cover the area you want. I don't know the area so not sure which of the 100 or so sheets (on CD) cover the area you want.
Member message me your email address and I will send you some screen shots to see if it is what you are after
Trevor
PS throw out some more place names to help me locate the right maps
184381
Reply By: traveller2 - Thursday, Jul 20, 2006 at 08:14
I had the same problem when we were down there at
easter Willie, just loaded the topo maps, 1:25 and 1:250 plus a couple of 1:100's.
184408
Reply By: davidfromOutbackstuf - Friday, Jul 21, 2006 at 15:19
willie
have a map named "the upper murray-touring map and visitor guide which covers east of miita across to
tom groggin and as far south as
omeo.
goes across in west to lake hume and nth to jingellic
scale is 1:180 000. map is 1998 produced by towong shire council 02 6071 2999
cartography by natural resource systems 03 9269 4555
may help you
otherwise as said above rooftops bairnsdale-
dargo-
omeo adventure map covers some of the area mentioned
david
184668
Follow Up By: Member - Willie , Epping .Syd. - Friday, Jul 21, 2006 at 16:04
David ,
I will contact them and try to buy the map .
Thanks a lot for your trouble ,
Willie .
441372
Reply By: Member - Darren T (VIC) - Friday, Jul 21, 2006 at 21:12
The Upper Murray Tourist map is a good map. Shows the area from (and including) Hume dam, entire upper Murray across to the Alpine way in the Kosciusko NP, and everything in between, down to
Omeo. Mitta and
Dartmouth Dam are in the centre of the map.
For more detailed maps, you might also like to try the Vicmap Topo maps -
Granite Flat 8324-1-1
Snowy
Creek 8324-1-2
Dart - Gibbo 8424-N
Benambra - Leinster 8424-S
Cheers.
184720
