2006 Gu patrol 285 70 r17 mud or all terrain
Submitted: Tuesday, Jul 25, 2006 at 09:56
DavidT
Just wondering if anybody has these on there vehicle do they rub on the mud flaps as i have a 2" lift kit and what prices are people paying for them as i am in
sydney
Dave T
Reply By: TJ Hach (VIC) - Tuesday, Jul 25, 2006 at 10:12
I have a set of BFG A/T on my GU in addition to an OME
suspension kit. The front tyres rub on the front mud guard brackets only when I am reversing with a hard left or right hand lock. They do not rub any other time only when reversing. As far as price is concerned can't help as my tyres were fitted as part of the deal when the vehicle was purchased.
TJ
185185
Follow Up By: DavidT - Tuesday, Jul 25, 2006 at 10:16
What tyre size are you running and are you happy with them
441931
Follow Up By: Rokkitt - Tuesday, Jul 25, 2006 at 10:19
I have a 285/75/16 - no rubbing with a 2" lift and mudflaps removed - see post: 35936
Rod
441932
Follow Up By: TJ Hach (VIC) - Tuesday, Jul 25, 2006 at 10:50
David, yep my tyres are BFG AT 285 70 R17, very happy with the tyres.
441936
Follow Up By: Member - Coyote (SA) - Tuesday, Jul 25, 2006 at 15:05
I have Cooper STT 285/70R17's on the smae vehicle (2" Lift kit) and they used to rub. However, if you take the mudguards off and cut away the little plastic bit behind them there is more than ample room for anything you want just about..
441985
Follow Up By: DavidT - Tuesday, Jul 25, 2006 at 16:20
How accurate is the speedo with the 285 70 r17 bfg's
442008
Follow Up By: Member - Coyote (SA) - Tuesday, Jul 25, 2006 at 16:24
I know you asked about the BFG's, but until you get an answer onthem I can tel lyou that the same size Cooper STT's put the Speedo out by 10%
442011
Follow Up By: TJ Hach (VIC) - Tuesday, Jul 25, 2006 at 16:38
With the BFG's my speedo is out about the same, I have already been pinged going through the Domain Tunnel....serves me right should have pulled the finger out and had the speedo recallibrated earlier on in the piece.
442014
Reply By: DavidT - Tuesday, Jul 25, 2006 at 16:02
Do you mean the mudflaps and not the actual guards
185247
Follow Up By: Member - Coyote (SA) - Tuesday, Jul 25, 2006 at 16:45
Are you asking about my post?
Opps yes, I meant Mudflaps. I removed the mud flaps (three screws) and then with a small grinder cut the plastic protrusion off. The only purpose I can it has was a bit of support to the mud flap, but without it, I can still fit the mudflap back on when I am using my standard GU rims with standards tyres ( I have the Coopers on a set of 17" Steel Rims for bush)
442018
