Car battery Monitoring
Submitted: Wednesday, Aug 02, 2006 at 20:19
mickm52
In the battery section there is mention of both LED and a LCD car battery monitoring and pre warning system. Does anyone know where the LCD unit can be purchased and at what cost?
Reply By: Sand Man (SA) - Wednesday, Aug 02, 2006 at 21:05
Derek from ABR (a sponsor) on this site has a battery monitor
site link
Give him a call for a price.
186812
Reply By: Member - Phil G (SA) - Wednesday, Aug 02, 2006 at 21:22
I run the above from Jaycar electronics and hook it up to the second battery. It uses very little power.
XC-0116 $39.95
But theres plenty of options out there.
186820
Reply By: Member - Craig D (SA) - Thursday, Aug 03, 2006 at 09:15
This is what I have been using for the past two years and I find it terrific for the following reasons:
1. Shows main starting battery and auxiallary votage levels at the same time.
2. Both main and auxiallary are alarmed for low voltage (eg: alt failure or aux not charging)
3. Is temperature compensated for more accurate voltage readings.
4. Shows charge state in both percentage and voltage with coloured scales.
5. Both displays can have their alarms turned off and either or both displays turned off.
The unit is far from cheap - about $140 - but as I said it works for me. I also find it handy in that I know exactly when the main batt is charged and the Redarc Smart Start switches in to the auxillaries, as the leds light up and there is an audible beep. As my auxillaries are in a camper, I can monitor the charging state from the cab whilst driving to give me a warm, fuzzy feeling that all is
well in the charging department.
Regards,
186870
Follow Up By: mickm52 - Thursday, Aug 03, 2006 at 09:31
Craig I presume from your post that it is a Redarc product, if not what is it called and where do you get it.
443938
Reply By: mickm52 - Thursday, Aug 03, 2006 at 09:26
Thanks for your replies. I have tried the jaycar but it reads low and has me panicking until I put a proper meter across the terminals. The one from ABR is the one I am interested in.
186873
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Aug 03, 2006 at 09:38
443943
Follow Up By: Howard T - Thursday, Aug 03, 2006 at 10:13
Hi Mickm,
I just purchased the one that Craig has pictured in his thread. Purchased it from Opposite Lock in
Rockhampton QLD. I think it was ordered from WA.
Howard
443952
Reply By: Member - Craig D (SA) - Thursday, Aug 03, 2006 at 10:20
Hi mickm52,
the LED battery monitor brand is "Chargemaster", and is part of OL's dual battery system that they sell.
Regards,
186881
