GPS & Laptop mapping
Submitted: Tuesday, Aug 22, 2006 at 09:48
Member - Sally C (ACT)
OK, I've got my laptop, I've got Oziexplorer, I've got Desert Tracks loaded and now I'm looking for a GPS. The kids want to get a Magellan Explorist XL with all the bells and whistles and topo maps loaded, but I'm resisting because I don't think I need to go that advanced. Can someone please tell me how I get the GPS to interface with the mapping software. Can Magellan GPS units interface with Oziexplorer - or do they only talk with their own software - Discover AUS? I'd really appreciate some feedback regarding what I'm sure is really simple, however I can't seem to get anyone at the retail level to show me.... Thanks heaps
Reply By: flappa - Tuesday, Aug 22, 2006 at 09:53
Magellan GPS units talk to Ozi (as do Garmin etc etc).
My old 310 Magellan can talk to Ozi with the appropriate cabling.
Not all Explorist DO connect to Puters. I think the basic ones dont , 100, 200 etc. I'm not sure at which level the Explorists DO talk to Puters.
Its a matter of finding that one that can , getting the appropriate Cable , and setting it up.
190204
Reply By: John R (SA) - Tuesday, Aug 22, 2006 at 10:13
I'd work on the assumption; if I can get a serial cable for the gps unit, it'll work with ozi.
Start there, and find a retailer who knows these things (I'd be inclined to find a specialist online. gpsoz are pretty handy - check the directory of this website).
I use a Garmin II+, and a handy feature of this unit is that I can plug an external antenna in (I've got a little magnetic job about the size of a matchbox that sits on the roof = good reception). That means I can stuff the gps unit & all the leads out of the way, rather than trying to mount the gps on the dash and hope it gets reasonable reception through the window.
After that, it's worth thinking about what else you might use it for. If you're going geocaching, you might prefer the smallest unit for easy handling. Odds are you'll use the gps independent of the laptop at some point!
Hope this helps a bit!
190209
Reply By: pt_nomad - Tuesday, Aug 22, 2006 at 10:25
Sally,
The OziExplorer web site lists system requirements as :
A PC running Windows 95/98/ME/NT4/2000/XP
For Upload/Download - Most Garmin, Magellan, Lowrance, Eagle, Brunton/Silva and MLR GPS receivers.
For Moving Map (real time tracking) Any GPS receiver which outputs NMEA 0183 sentences.
If your real purpose for getting a GPS is to drive the computer - get the dumbest one possible that outputs data suitable.
However driving around with a laptop on can be a a pain in the buttski.
I use a PDA running OziExplorerCE - this is a good thing as if can be mounted and remain visible with out consuming large amounts of cabin space.
Some PC's and PDA's are able to use 'bluetooth', it is also possible to buy bluetooth gps units that only send out data (they don't have a display). No good for bushwqalking but good for PC's PDA's as they only need data and there is the advantage that blue tooth is radio - no cable (other than power to the unit).
For bush work, dash mounted GPS units can loose signal in dense bush ( tho I think they are getting better). A blue tooth unit may be found that can be mounted on the
snorkel, I have an external antenna for my GPS mounted on the
snorkel.
Personally I find the moving map display while black top touring as usefull as detailed maps in the bush, so unless you are going to thave the PC on all the time or go with a PDA solution ( Navman PIN seems like a good one for GPS and PDA combined) I'd rekon a unit that does some mapping as
well as data transmission for when your really lost and need to hook-up the computer, would over come most needs.
Bear in mond the most mapping GPS units dont show much ( read virtually nill) information on bush tracks.
Strongly recomend a PDA - the navman uint is probably around what you'd pay for a mapping enabled GPS - so is good value as you can also run OxiExplorerCE ( another licence is required).
Paul (ACT).
190213
Follow Up By: howie - Tuesday, Aug 22, 2006 at 13:47
the gps aerial mounted on the roof/
snorkel is highly recommended sally and as pointed out, you do not need a 'gps' unit in your config.(but if you go hiking..)
just a side question paul, i have a external aerial mounted on my
snorkel to the gps, this is a cable type. does the bluetooth ever 'drop out', i have a fear of all things not connected by solid cable.
447907
Follow Up By: pt_nomad - Tuesday, Aug 22, 2006 at 14:14
Howie,
My unit is a cabled external antenna cable connected to a cabin mounted garmin II+, I have not used a 'bluetooth' unit.
Blue tooth is supposed to have an effective range of 10 metres, which should cover most units mounting locations - but as you point out do the dynamic effects of travel could cause signal loss?
Does any one on the
forum have experience they can share in this area ?
I am in favour of the idea of keeping the gps a dumb data collector and applying the smarts downstream.
btw - the GPS is hooked to the second battery and is powered all the time using a power / data cable.
Sally,
If you getting a cabled unit, its worth getting a unit that can talk data and receive power at the same time - walking and chewing gum ;)
Paul.
447913
Follow Up By: Member - Mike DID - Wednesday, Aug 23, 2006 at 17:32
The unit will be safer from trees and thieves if you mount it INSIDE the
snorkel cap. Provided it's all plastic and not carbon-loaded, it won't affect the signal.
448209
Reply By: Member - Alastair D (NSW) - Tuesday, Aug 22, 2006 at 10:39
Sally,
I have the Explorist XL and it links to Oziexplorer
well. My logic for getting the XL was that the screen is large enough, colour and good resolution to work
well within the vehicle. I did not want to have to mount the laptop for use while driving. This makes it easy to switch between vehicles.
I use the laptop for planning before the trip, down loading tracks etc in the evening and uploading map sections created from other maps etc.
The downside of the XL is that the batteries do not recharge through the cable when connected to power. I do use rechargeable batteries, just have to take them out to recharge. Not a hassle if you mostly use it connected but it drains the batteries quickly otherwise.
Big and bulky if you plan to carry it, but i just pop it in the side pocket of the backpack. Can't understand why some people seem to think they have to have phone, GPS etc on their belt when walking.
I am happy with the XL but if you are going to use the laptop most of the time then you can get much cheaper GPS units which work
well. As said above look at GPSOZ and Johnny Appleseed etc.
alastair
190220
Reply By: Troop-a-dour - Tuesday, Aug 22, 2006 at 12:56
Using your lappy & OziExplorer- you don't really need a whiz bang GPS unit to drice it. I use a Garmin eTrex, and before that a borrowed (& old) GPS12. Both did a sterling job driving the Moving Map and all the other features in Ozi.
Under Configuration in Ozi, you will set up whatever GPS unit you'll be using.
Is your lappy Bluetooth compatible?? If so there are some budget priced Bluetooth GPSs around (try eBay).
Mine is not, so we just use the cable to the COM port, with the 12v cig lighter power cable.
GPSs do suck the internal batterys- so whichever way you go, try to have the facility for 12v power to it.
190244
Reply By: Phil.Fehlberg - Tuesday, Aug 22, 2006 at 13:19
Sally,
The solution that I use is best for my requirements, but there are lots of variations out there.
I use the Garmin Quest with OziEplorer on a laptop. The Quest is quite versatile as it has two modes: On Road (voice turn-by-turn) and Off Road (point to point). The former is great for finding unfamiliar locations by address and the latter for hiking. The Quest connects to the laptop by USB and is supported by Ozi. It also takes an external aerial, so it is rare to lose reception. It's cradle connects to the 12 volt supply via a cigarette lighter plug which also contains the speaker. The GPS turns on and off with the accessories. The inbuilt mapping is quite good and has the latest variations to
Melbourne's freeways. It even directed me to the bottom of Billygoat
Bluff Track. When you pop the Quest out of its cradle, it runs for a claimed 20 hours on its battery. I have used it for two full days hiking, in the pocket of my shorts (and it still had signal there) without the battery failing. However, the battery is inbuilt, so once it does run out you have to the cradle to recharge it.
Using Ozi of the laptop gives you moving map, a much more readable screen (once you have overcome the problem of mounting it) and access to a huge variety of maps - both commercially available ones and custom maps.
190246
Reply By: Kumunara (SA) - Tuesday, Aug 22, 2006 at 13:40
Sally
All you need if you only want to use GPS and laptop mapping is what they call a GPS mouse.
The cost about $150 and any computer
shop can obtain one for you.
I have also seen them advertised on this site.
190250
Reply By: Mike Harding - Tuesday, Aug 22, 2006 at 13:41
Others have given excellent advice so I'll just add the following:
if your notebook does not have an RS232 port but only USB then I would _STRONGLY_ advise that you buy a GPS with a USB coms facility and thus avoid having to use an RS232 to USB converter.
I know some people have had no problems with them but a number of us (who know a bit about computers too) have had nothing but trouble with them - to the extent I ended up buying another (USB) GPS in order to resolve the problem!
Mike Harding
190251
Reply By: Member - Willie , Epping .Syd. - Tuesday, Aug 22, 2006 at 13:55
I am surprised so many of you mount your GPS aerials on the
snorkel . I have seen two trashed by hitting stuff on overgrown tracks . Much safer in the middle of the roof rack at the front .
Willie .
190257
Follow Up By: Mike Harding - Tuesday, Aug 22, 2006 at 13:58
Never used an external antenna for my GPS - Garmin GPS12XL (as was) propped up against the windscreen (inside, of course :) Even in the tree covered High Country always had good reception.
My new 20 channel GPS Mouse sits in the same place and works
well too.
Mike Harding
447911
Follow Up By: Member - Andrew (QLD) - Tuesday, Aug 22, 2006 at 15:34
ye, sticking it on the
snorkel seems like a strange place. Agree with Willie on the location.
For a simple test of the benefits of roof mounting, just chuck your GPS on the roof when monitoring the satellite page. The bars seem to fly off the screen :-) (should be too small a distance for multipath errors from the roof). Works on similar principles as to the best mounting place for an antannae on a vehicle....
Andrew
447942
Follow Up By: Member - Phil G (SA) - Tuesday, Aug 22, 2006 at 20:56
I agree - I've used
mine on both
snorkel and dash, and can't tell the difference - works very
well in both locations.
448023
Reply By: Sand Man (SA) - Tuesday, Aug 22, 2006 at 16:30
Sally,
I, like Mike Harding, have gone through a frustrating exercise in trying to interface a GPS with a serial connector to a laptop via a serial to usb adapter.
My (our) advise is, don't do it.
Unless you specifically need a hand held GPS which you will use away from the vehicle, the GPS mouse, or a GPS card, is all you need.
Both the card and mouse style GPS receiver are avbailable from the
shop on this site, or
places such as GPSOz.
I have found the GPS mouse to be extremely functional. you can place it anywhere within the vehicle that suits you (it has a magnetic base) or even stick it out through a window to the roof of your car if you must. (I have not needed to do this)
Finally, the GPS mouse (or card) is powered from the laptop port so you don't need a separate power cable. The mouse also comes with a testing program to confirm it is working OK.
Just to confuse you a little, a stand-alone GPS is handy at times, when you are not using the laptop, to check things such as vehicle speed against your speedo reading, but it's not absolutely necessary.
190296
Reply By: Member - Phil G (SA) - Tuesday, Aug 22, 2006 at 21:04
Sally,
If your laptop has bluetooth, and you want simplicity, then buy a bluetooth GPS receiver.
If no bluetooth, get a cheaper Garmin GPS, plus power cable and data cable.
The advantage of a proper GPS like the Garmin is that it is still functional if the laptop or inverter stuffs up.
If you don't have a computer yet, consider buying a Tablet PC - they are perfect for mapping in a vehicle as you use a pen instead of keyboard and mouse, and they have a smaller footprint - usually a 10.4" or 12" screen.
190384
Reply By: Member - Sally C (ACT) - Tuesday, Aug 22, 2006 at 21:38
Thankyou all for every bit of info that you have provided. I have to say that overwelmed with the helpful suggestions and, at first glance, it is all starting to fall into place. It will now take me a day or so to read everything....and then I'll probably have another question...or two!!
190394
Reply By: Cornelius - Wednesday, Aug 23, 2006 at 10:37
Hi there
I got a Geko 201 from Garmin. It's cheap but brilliant and waterproof and talks to aussie explorer and does everything the fancy models do. So for around $300 you get the lot if you interface with the PC. So why spend $1000 plus to get the same ......
190499
Follow Up By: Member - Mike DID - Wednesday, Aug 23, 2006 at 17:37
I agree.
Works great as a GPS Mouse AND as a tiny handheld GPS
448212
