Low Voltage cutout
Submitted: Friday, Aug 25, 2006 at 10:25
ThreadID: 37094 Views:3455 Replies:8 FollowUps:3
I have a very old Engle fridge that does not have all the gismo stuff and want to install a low voltage cut out in the circuit. My auxillery battery is mounted on the drawbar of my caravan and also supplies my lights and radio. It does not supply my 3 way electrolux fridge. Any suggestions if these cut outs are available, where and the approximate cost?????
Reply By: Member No 1- Friday, Aug 25, 2006 at 11:10
auto electrician would be where i'd start
AnswerID: 190911
Reply By: Leroy - Friday, Aug 25, 2006 at 11:14
check out PostID: 36367. for starters. If you are handy with a soldering iron the one from Oatley electronics may be an option.
Leroy
AnswerID: 190914
Reply By: MartyB - Friday, Aug 25, 2006 at 13:17
Ray,
Yes they are readily available.
I have seen them at Camping Stores, on Ebay, also one of the advertisers here would sell them (Derek from ABR or sidewinder.com.au).
Cost I would guess would be about $60 to $100 for one complete, kits are cheaper.
Cheaper than stuffing up your battery.
from Marty.
AnswerID: 190932
Follow Up By: Thylacine - Friday, Aug 25, 2006 at 13:43
There's a fellow selling pre-made Oatley kits on eBay for around $60. From memory they were modified to suit 4WD service and seemed a reasonable unit.
ps not me or any affiliate etc
ed
FollowupID: 448633
Reply By: Turist (The Original One) - Friday, Aug 25, 2006 at 14:23
Engel have just released a new model with digital read out and selectable cut out voltage, 10.5 or 11.5 volts.
Nice unit, fitted one yesterday.
Can be supplied as a "plug in" model or for hard wiring.
I used the hard wired model, $98.00.
Needs to be wired via a relay so add another $7.00.
AnswerID: 190943
Reply By: Sand Man (SA) - Friday, Aug 25, 2006 at 16:48
Projecta make a good compact unit. Cost is around $39 and available at Kmart, Repco, etc.
The only proviso I would make is to replace the plug and socket with the "Merrit" type.
Bill
AnswerID: 190973
Reply By: Member - Phil G (SA) - Friday, Aug 25, 2006 at 19:45
If you are good with a soldering iron, the Jaycar or Dick Smith kits work fine - thats what I've used on my engels for the past 10 years. And you can vary the cutout voltage. about $30.
Fully made up - the $30 Projecta sure-start is a reasonable option.
If you want the best, get the Engel one that Bob suggests above.
Your old Engel will draw about 6amps when cycling. The above are rated at 10amps, so I'd only use them for the Engel - I mount mine on the fridge itself.
AnswerID: 191000
Reply By: Alloy c/t - Friday, Aug 25, 2006 at 20:00
Ray ,with all the $ you have squireled away you could buy a newer Engle or even better a new Waeco , both nowadays have the low voltage protection built in ..LOL
AnswerID: 191003
Reply By: Derek from Affordable Batteries & Radiators - Friday, Aug 25, 2006 at 20:38
Yes Engel have a new digital one ! I think they are great !
Cut Out
AnswerID: 191028
Follow Up By: geocacher (djcache) - Friday, Aug 25, 2006 at 20:57
What's the difference between the BM12 & the BM IL Derek?
Dave
FollowupID: 448739
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Aug 25, 2006 at 21:12
For extra versatility use the # BMIL Battery Monitor In Line, this model simply screws into your Engel 12 volt lead using the "posi-fit" connections that come standard with your Engel refrigerator, allowing your battery monitor to go where ever your Engel goes. 12 Month Warranty
FollowupID: 448742
