nylon skid rails?
Submitted: Thursday, Sep 21, 2006 at 23:26
D-Jack
Hi there, where can get Nylon skid rails for the bottom of my camper trailer kitchen box? Hoping to get them up to 2m long.
Reply By: Member - Roachie (SA) - Friday, Sep 22, 2006 at 00:05
I would think that a boat trailer maker would use that stuff. I know that the manufacturers of Ultimate Campers have a blue-coloured nylon strip of stuff they attach to the lid of the campers if the owner is going to want to carry a boat on top. You may be able to give them a call to see if they can assist. 02 4472 9110
Good luck
Roachie
195842
Follow Up By: D-Jack - Friday, Sep 22, 2006 at 00:37
Thanks, hadn't thought of a boat trailer maker, but then again hadn't thought of anything except bunnings (no luck there!)
453998
Reply By: Wilankurgab - Friday, Sep 22, 2006 at 00:09
Hi D-Jack,
How about the skids used on boat trailers?
I assume any boating store will be able to supply, and possible use the Goss dry lube stick may help it slide
195843
Follow Up By: D-Jack - Friday, Sep 22, 2006 at 00:38
Cheers W
453999
Reply By: Barnesy - Friday, Sep 22, 2006 at 01:26
I got nylon from the local CBC bearings
shop. They had a box in the
shop full of off-cuts and i picked up a block of 12mm thick stuff for $5. I cut it into 25mm strips with my jig saw and I'm laughing. Too easy.
Barnesy
195857
Reply By: smort - Friday, Sep 22, 2006 at 06:05
Hi all
I needed some nylon strips to line a non edge damaging mount for an axe under my truck - searched high and low - hardware stores hobbly stores to no avail - didnt go to the bearing suppliers though - found my solution at home - cut up an old nylon cutting board - many colours - red for meat green for - oh I forget etc. You can get more at most $2 shops - warehouse etc - cheap as chips
hope this helps
195867
Follow Up By: Member - MUZBRY (VIC) - Friday, Sep 22, 2006 at 07:40
Gday
Nylon cutting boards are not made of nylon,,,,they are made from HDPE ,,high density poly ethylene,,If some is needed ,,just ring old muzbry, itsa my business.
454024
Reply By: Robert - Friday, Sep 22, 2006 at 08:04
Look in th yellow pages for plastic fabricators, they sell all sorts of plastic. For slides Polyethelene is better than nylon.
195882
Reply By: Member - MrBitchi (QLD) - Friday, Sep 22, 2006 at 08:11
As others have said, a chandlery will have it in stock. Commonly used as skids on boat trailers.
195884
Reply By: Max - Sydney - Friday, Sep 22, 2006 at 10:46
Mate
In
Sydney, Cadillac Plastics at Silverwater is the place to go for anything plastic. And from a quick Google I see they are in every state.
I've been out of engineering for a while but suggest you ask who ever you get it from about Delrin instead of Nylon - it used to be the go for slides - abrasion resistant and slippery.
For what its worth
Max
195926
Reply By: marq - Friday, Sep 22, 2006 at 17:43
Go and see your local (or larger city) plastics wholesaler or reseller.
195987
Reply By: Member - Vincent A M (NSW) - Friday, Sep 22, 2006 at 20:31
Dunbier trailer stockist (most marine shops) have one of the better ones it has a grove in the middle so the screws or pop rivets do not have to be rebated & come in lengths up to 3.5mtrs
196011
Reply By: SA_Patrol - Saturday, Sep 23, 2006 at 08:18
Have to looked at Teflon strips,
196087
Follow Up By: Member - Andrew (QLD) - Saturday, Sep 23, 2006 at 10:53
hehehe.....have you looked at the price of PTFE (Teflon) sheets lately? :-)
Andrew
454296
Reply By: Member - MUZBRY (VIC) - Wednesday, Sep 27, 2006 at 07:26
PTFE in sheet form or roll is over $70.00 per lin /m that is 1200mmx 1000mm x .5 thick So for every .5mm thicker you just double the cost..So 1mm is $140.00 per lin m and 2mm is $ 280.00 per and that is wholesale not retail
Try HDPE much cheaper and very tough ..it can be drilled and riveted or glued down.. I hope that this is helpful
196742
Follow Up By: Member - Andrew (QLD) - Wednesday, Sep 27, 2006 at 08:55
yeh, i went to price some to make an "edge protection" for rope rescue purposes........was thinking along the lines of 12-15mm stuff that was to be grooved/routered to allow flexing.
Gave up that idea quickly!
Andrew
455141
