Saturday, Oct 07, 2006 at 22:02
Hi Viv
I guess that you know there is a section down the south end that you can't take trailers? I understand that there is a way around it that involves travel on private property or something like that. We did not investigate as we never intended to go that far down.
We did Billiluna to
Well 33 (Kunawaritji Community) in July this year. We in a petrol Paj (NM) and Aussie Swag trailer and brother in a Hilux trayback and Campomatic trailer. We had 140 litres (useable)
fuel in the car and 100 litres in Jerries in the trailer plus 120 litres
water in the trailer
tank.
Water no probs as
Well 46 was good and
Well 33 also. We had an estimated 120 litres
fuel left at Kunawaratji and could refuel there, although we had to wait 24 hours for the truck to arrive as they had been held up due to
water on road. We ran same tyre pressure in camper as in front of car, down to 18psi as needed.
It's a long story I guess but we basically had "no problems". Didn't have to be towed or snatched over any dunes, had to have more than 1 go at 4 dunes with 1 dune taking 3 goes. This was just because I was pigheaded and didn't use the run up on the second go, preferring to think that I would be OK. Most of the dunes are fine, it is just the ones that do a hard turn right at the bottom and don't give you a chance to line up the vehicle and get revs right that present challenges (in my opinion anyway).
I certainly endorse the comment above, make sure you can back the units for 50/100 metres and, if possible, practise this in soft sand as that changes the dynamics significantly. We purchased the DVD from this site and that helped our planning a lot although that does show the vehicles approaching the dunes at what seems to be high speed. We did not find that necessary but certainly had to have the revs up. Our Paj is auto but you can (and I do) drive it in manual so keep gears low and revs up. I learnt that high range was better than low range as in low, when changed back to 1st, the power to the back
wheels was too high and more chance of bogging down.
People talk only about the sand and dunes but be prepared for
water crossings and mud (we had both in July and you are 2 months earlier) and rocky "breakaways" (whatever they are...) but kms of sharp dangerous looking rocks that necessitate (for us anyway) 10/20 kms per hour not wanting to get punctures. And the absolute worst part of the trip we did was just after
Tobin Lake where you travel along the dunes and the "oopty doos" are awful, or maybe it was the last 30 odd kms into
Well 33 where the corrugations were real bad and unavoidable, so grit the teeth and keep moving.
We had intended to go to
Georgia Bore but had seen enough abondoned wells,
sand dunes and spinifex after 670kms so we decided to go out on the Kidson Track/Telfor
Mine Rd, plus this option gave us Carrawine Gorge and
Marble Bar.
Be prepared to suffer scratches on car and camper. Mind you most of ours have rubbed out but only after hours of cut and polish.
Don't worry about the
Halls Creek to Bililluna section-- easy going. We had intended to start from
Halls Creek but there is a very
nice camp just 17 kms in from Bililluna,
Stretch Lagoon that we heard about in HC so we made this our start point and were glad we did.
The other advice I would have is to over prepare. Our tyres had done 50,000 kms and had over 50% tread left but we put newies on. We have OME
suspension on the Paj that gives a lift plus harder working. Our trailer is relatively new s no extra stuff needed there.
!00 to 150 kms per day was enough. We set off at 7.00 am each day and planned to pull up by 3 ish.
Now the bad news??? At the Community there were 5 vehicles being worked on, yes 5, in 1 day. They have a work
shop and some
tools but no tradesmen. The groups in on the day we were there were lucky that there was a welder and an auot electrician also waitng for
fuel (they were on 2 motor bikes and side cars) and they offered to help out. A Jackaroo had lost his radiator off the mounts and back into the fan, one on the road had broken a front wheel stub, one dropped an engine mount bolt (lucky that they found it), 1 a staked tyre and another with tow bar worked loose.
Two Prados on track at the same time as us had problems with bull bars or front bumpers/panels (or something) vibrating loose and the one that burnt was just a couple of days in front of us.
As for our vehicle and trailer we got through OK, if we ignore the scratches. Had it checked over in
Geraldton and all OK but then when we got home we decided to replace the back shockers. The Hilux was the vehicle with tow bar problems and then they did a shocker on the trailer.
If I can help anymore just let me know.
Rusty
198246
