laptop mount
Submitted: Monday, Nov 06, 2006 at 21:17
Aknot
I would like to mount my Laptop in our Crusier 80 series prior to our next trip, can anyone suggest some options or give me some ideas. Thanks
Reply By: Member - JohnR (Vic)&Moses - Monday, Nov 06, 2006 at 21:27
Have a look at the one I have had in Moses...........!MPG:10!
203412
Reply By: Mikee5 (QLD) - Monday, Nov 06, 2006 at 21:35
Hi there,
I use a 'stable table' on my knees. I put the laptop into hibernate when not in use, that way it fires up quickly when needed. The GPS (Garmin 126) runs all the time so the lappy is only needed occasionally. When not in use it is shoved down next to the
seat. I also use a Kerio 12v power supply.
Mike.
203414
Reply By: Member - Troll 81 (QLD) - Monday, Nov 06, 2006 at 21:47
Laptop under the
seat and a touch screen in the dash
203417
Reply By: Member - Errol (York WA) - Monday, Nov 06, 2006 at 21:59
Just uploaded a new pic for you in my pic's . This show's a screen mounted but i have now mounted my laptop there insted and taken the screen out . Errol
203420
Reply By: Ray Bates - Monday, Nov 06, 2006 at 22:05
Not a laptop but I have just installed a rear view monitor. I made ,out of MDF a section that fits in the just behind the and storage box. It takes a bit of doing as all the angles in the recess are different. This gismo supports the monitor and is fully adjustable for most angels. I'm shore that the idea could be adapted to take a small laptop screen.
203428
Reply By: Member - Phil G (SA) - Tuesday, Nov 07, 2006 at 08:53
I had
mine sit on a carpeted platform between the two front seats when I had the Prado. I didn't want to have it in the way of everything else. Just meant that you couldn't really use it while driving, which is probably a good thing.
Now I use a tablet PC as a console lid on the truck - best setup I've had.
203490
Reply By: Rock Crawler - Tuesday, Nov 07, 2006 at 09:29
i am sure my lap top pics are here somewere from my 80 , ill try find some for you .
203495
Reply By: Sand Man (SA) - Tuesday, Nov 07, 2006 at 10:41
The most practical option is a "RAM Mount" solution.
GPSOZ are Australian agents and their Web site shows many solutions, or you can select the US RAM Mount Web site, choose a specific product and GPSOZ will give you the cost in Australian dollars and get it in for you if they don't have stock.
GPSOZ - RAM Mounts
I was originally interested in a "VersaTrue Carmount" solution but the cost to purchase and import from the US blew the cost out of the
water.
My solution (pictured below) uses a Versatrue brand clamping solution coupled with a RAM Mount Laptop "Tough Tray". I chose my specific solution as there was no drilling involved. The clamp style base fixes to the Grab Handle on the centre console.
RAM have similar clamping solutions to choose from, or a three leg solution that fixes to the floor and if you cannot select a solution by visiting the GPSOZ web site, I'm sure a phone call to them would get you further help.
!MPG:17!
!MPG:18!
203513
Reply By: Member - Phantom (WA) - Tuesday, Nov 07, 2006 at 13:43
Hi Aknot,
Whilst I don't have one, it is on my wish list...I particluarly like this one from Mobile Desk Solutions
www.mobiledesk.com/
Steve
203534
Reply By: Wayne (NSW) - Tuesday, Nov 07, 2006 at 17:16
Aknot,
I was thinking of doing the same thing so that i could have a moving map.
The problems that I came across is that they are intrusive into the cabin, the lap top will get dust into the workings, and if a disk has to be run while the vehicle is on the move over rough roads it does not do the laptop much good.
I went for a GPS with the moving maps. A lot smaller and can handle the extremes of the vehicle better. I still have the laptop in the vehicle but packed away out of the dust and only get it out when required.
Wayne
203559
Reply By: Tim HJ61 (WA) - Tuesday, Nov 07, 2006 at 18:17
Try this link to 4WD Developments
www.4wddevelopments.com.au/computer.html
I think they are in WA. I know a mate with one in an 80 series that they are happy with.
Tim
203566
