Cobb Ovens - How long to heat up
Submitted: Wednesday, Nov 08, 2006 at 18:56
ThreadID: 39256 Views:4405 Replies:6 FollowUps:1
Everyone raves about Cobb Ovens. How long from lighting the fuel does it take before you can put the roast on?
Reply By: malssurf - Wednesday, Nov 08, 2006 at 19:13
G,day Pajeroman,
Just wait until the heat beads turn to nearly all white. Usually about 20-25 minutes if you use the best quality ones.
Enjoy
Malssurf
AnswerID: 203767
Reply By: Member - Brian (WA) - Wednesday, Nov 08, 2006 at 19:14
Havn't timed but at a guess maybe 30mins for 8 beads
AnswerID: 203768
Reply By: Member - Bruce and Anne - Wednesday, Nov 08, 2006 at 20:12
20 minutes for heat beads, then 2 hours for a no 18 chicken with vegs, sh:t it tastes good too. Make sure you put the herbs and red wine in the moat to really make the mouth water hahaha.
Cheers Bruce
AnswerID: 203776
Reply By: Sand Man (SA) - Thursday, Nov 09, 2006 at 09:50
Yep,
About 20 minutes will see the heat beads burning nicely.
Here's a little tip for you to try.
Take the wire firebox out of the cobb and place it on a firm non burnable surface.
(I use a cast iron skillet)
If necessary, pour a little metho over the beads and ignite. This will allow good air circulation around the beads, but shelter from strong windy conditions.
After the beads are burning well, place the loaded firebox back into the Cobb with a long handled pair of tongs.
A joint or roll of lamb, beef, or pork will take about 1 1/2 hours and I put the spuds & carrots in the moat at the same time.
The same method with more heat beads can be employed for a camp oven when you haven't got (or can't use) a camp fire.
Bill
AnswerID: 203864
Reply By: CYPHER-CHLNGER - Thursday, Nov 09, 2006 at 10:28
About 20 mins for 8 - 9 beads. Well worth the wait !!
AnswerID: 203875
Follow Up By: Member - Lindsay- Thursday, Nov 09, 2006 at 16:25
Make sure you use genuine "heat beads" (registered). The cheaper ones ( BBQ fuel?) are woftams & results in P*** poor performance.
Lindsay & the (Polar) Bear
PS:- Polar Bear won the 8th at Flemington!
Go the Toyotas!
FollowupID: 463605
Reply By: LastAussieWorker - Thursday, Nov 09, 2006 at 21:00
ditched the Cobb in frustration and bought Weber BabyQ instant and works straight away and much more uses than Cobb.
AnswerID: 204005
