Battery size/type
Submitted: Thursday, Nov 09, 2006 at 18:51
ThreadID: 39288 Views:7499 Replies:12 FollowUps:12
Was wondering as to what batteries are being used to power an Engel 60 lt fridge as Im in the process of setting up a duel system to run a second battery in the tray of my D40 Nissan. I was recommended a Century N70ZM which I understand is a deep cycle marine battery but is only 75 Amps I thought around 100+ Amps would be more suitable. Also what is the more prefered type, AGM or some type of deep cycle designed for rough conditions as in the marine one.
Any thoughts on this would be appreciated
Cheers Dave
Reply By: Member - Norm C (QLD) - Thursday, Nov 09, 2006 at 19:04
Dave I'm a big fan of AGM batteries. A bit about them on this link:
www.fridge-and-solar.net/agm.htm
As to size, well bigger is always better. Since you are carrying it on the tray, size and weight should not be big issues. I'd go 120 AH at least. I've got a 120 AH AGM in the back of my Hilux and another in the CT. I doubt that a 75 AH battery would run your 60 lt fridge for 24 hours. Remember you don't get to use all of the batteries capacity and the more often you run it right down, the shorter it's life will be.
AnswerID: 203960
Follow Up By: Kev M (NSW) - Thursday, Nov 09, 2006 at 19:26
I use a 60AH battery for my 60l Engel. No problems at the moment usually get a day and a half out of it before it drops below an acceptable voltage level.
Cheers Kev
Russell Coight:
FollowupID: 463652
Follow Up By: Member - Norm C (QLD) - Thursday, Nov 09, 2006 at 23:21
That's a great result from a 60AH battery Kev. But that must be in fairly mild ambient temps. Assuming you get 40AH of useabale capacity from the 60 AH battery and your fridge draws 5 Amps when it is running (both are estimates only, not attempts to quote facts), your compressor can run for 8 hours in the 36 hour period you mention. In mild temps this is quite feasible, but in Northern Australia it is likely to need a lot more running time. And you may have other power requirements from the battery when camping.
In my experience, the largest contributer to power needs of a fridge is ambient temp. The arguments people have over half an amp difference in the current draw between fridges is chicken sh1t compared to the effect of ambient temp and the impact it has on cycle times.
Not questioning your post at all. Just pointing out that it is probably achieved in a particular set of circumstances that may not always apply.
FollowupID: 463726
Follow Up By: Kev M (NSW) - Friday, Nov 10, 2006 at 07:08
I was running the fridge up in the high country earlier in the year.
So the ambient temp wasn't to high so that would probably explain why I had such a good result from the battery.
The battery was a Super Charge MRV48 from memory. The Cars at the mechanics so I'll confirm when I get it back.
Cheers Kev
Russell Coight:
FollowupID: 463757
Reply By: Alloy c/t - Thursday, Nov 09, 2006 at 19:47
The Engle WILL use some where around 1.9 upto 4.5 amps per hr of run time , variables of ambient temp and fridge temp settings , so for a theoretical start point work on 2 amps per hr X 24hrs = 48amps , then for max battery life should never discharge lower than 50% ,, ergo get the biggest AGM battery that you can afford and have room for.
AnswerID: 203982
Reply By: MAVERICK(WA) - Thursday, Nov 09, 2006 at 20:14
before you go spending heaps of money - how often are you going to have the engel running? if this is for a 'big' multi week/month trip then get a battery which has sufficient amperage to last for 24hrs between starts. if you are going to be stopped for anything more than 36hrs then you need to look at some way of charging other than the vehicle - solar or genset. if however you are only going to be doing day runs every now and then, just put in an el cheapo battery ($100) and this should give you a couple of years of use then just get a new one when it expires. an n70zm is very heavy - try and keep the weight down as much as you can. rgds
AnswerID: 203989
Follow Up By: itsdave - Thursday, Nov 09, 2006 at 21:04
Its a combination of weekend and long trips so I need something to suit both. Im puting in a Rotronics Battery Management system and have been told that running the vehicle for 1/2 hour or so will give it enough charge to last a day while stationary
Dave
FollowupID: 463685
Reply By: raunchy - Thursday, Nov 09, 2006 at 20:53
Hi Dave,
I run a fridge permanently off a dual battery and on weekends sometimes only drive the vehicle once for a short time. Run an Amptech 105Ah Marine batt, dont have a problem. Sometimes run two fridges from it, a 50 litre and a 25 litre as a freezer. Drive daily then, and no issues. If you wanted to stop for a while could be a problem. Also used to run the 50 litre (waeco) in a Courier dual cab diesel for 2 years with no dual battery. Never had a flat battery until the battery died (2 years and the batt was 3 years old when I bought the vehicle) standard N70Z.
Could park the vehicle on Friday in the summer and run the fridge all weekend and still start the car on Monday morning.
Hope this helps
Ray
AnswerID: 204000
Reply By: Member - Andrew W (SA) - Thursday, Nov 09, 2006 at 20:55
I don't know what sort of driving you do, but here's my experience.
1 year ago I put a 110 AH (note - this is Amp hour - not amps - your terminology faux pas has potential to get you into trouble) as an auxiliary battery in my 1HZ 100 Series with one of Derek Bester's ABR dual battery systems. It runs 80l Waeco fridge and 500W inverter usually only having a small load and occasionally, lights.
It was an AGM from a big battery distributor.
1 year later it is not holding charge - maxes out at 12.4V despite being run down to about 9.6V only once and despite frequent LONG alternator recharging.
It was still "under warranty" so I took it back expecting a replacement, but perhaps a discussion about what I wasn' t doing etcetera.
Well, they first tried to tell me that really there was no manufacturing fault with the battery and it had just had a hard life.
They also couldn't really tell me anything that I did particularly wrong with it except use it.
From talking with people who seem authoritative like Derek, it seems that the frequent off-road work; the reasonably frequent extreme heat under the bonnet; coupled with being run down once or twice may well put this battery at the end of it's useful life.
The outcome of the discussion with the retailer is still ongoing 3 days later, but I know for sure:
1. most retailers don't seem to ask enough questions about your use to provide proper advice and the appropriate product (I called 3 big companies/specialists to see what they recommend in terms of technology/product/life expectancy etc.)
2. most retailers can't give any accurate information about their product life in at least my sort of usage
3. it is very hard to know what is the correct information on the subject.
I know it really doesn't give any good advice, but be pedantic, ask a lot of questions, take notes of who you talk to and what they tell you, and then if it doesn't happen you can take them to task.
Andrew.
AnswerID: 204001
Follow Up By: itsdave - Thursday, Nov 09, 2006 at 21:15
Andrew
Sorry about the faux pas . Yes I should have said Amp/Hr.
The Rotronics charging unit also includes a low voltage monitoring unit and relay to hopefully prevent over flattening the battery as this seems to be the main problem in shortening battery life
Cheers Dave
FollowupID: 463690
Follow Up By: Muzzgit [WA] - Thursday, Nov 09, 2006 at 23:02
Having a rotronics with a low battery cut out will still not stop you draining your aux battery if your fridge/lights/whatever are connected directly to it, as they should be.
FollowupID: 463723
Reply By: Steve - Thursday, Nov 09, 2006 at 21:44
Why a MARINE battery in a Nissan ??? Just putting a second battery into a Nissan and connecting a large fridge to it , does not mean you can run it forever !! As you are finding out ...if your rig is high up in the Snowys and temps are cold...you will get a couple of days out of your battery...if on the other hand you are up in the Kimberleys ...in the height of the hot season...expect a day /24 hours max...in between you will have to work it out yourself...don't annoy an auto electrician..expecting him to have all the answers...nobody does...then factor in the temperature at which you intend to carry food etc ...freezing , 4C, 8c, or happy with 12c ??... all more to factor in ..Essentially you are fitting a small battery (100AH)...when you really need abou 50 ah per 24 hours as a general guide..factor in a 50% usable level ...and you are bacl to 100ah ..in 24 Hours ( without recharge)...and running your motor for an hour or so will have minimal .(read very little) effect to re-charging your battery !!!
Sorry..been there done that ...you could add a solar panel etc for stationary charging but that's another matter..it's good and works..but could be a hassle in a Nissan..
AnswerID: 204017
Follow Up By: itsdave - Thursday, Nov 09, 2006 at 22:33
Steve
1. I was told of this particular marine battery because of its quality in rough condition.
2. I am well aware that ambient temps effect the running of a fridge
3. Who is annoying an auto electrician?
4. I would have considered a 100-120 amp/hr battery about average size unless of course you want to go to something like 200 Amp/hr with a weight of something like 65kg. I get the impression that most users on this forum run about the 100/120 correct me if Im wrong, and get 1 1/2- 2 days out of it on average.
5. As for you remark " read very little" in regard to minimal charge.
If you happened to know anything about Rotronics charge systems This particular one is an independent fast charge unit and I am taking the word of its owner Rod who I beleive has a very high reputation on this and other forums
6." A solar panel being a probem in a Nissan" No comment.
I believe this forum is for usefull and helpfull comments and to be able to help each other in this pastime we all share, not sarcastic dribble
Cheers Dave
FollowupID: 463712
Reply By: Richard W (NSW) - Thursday, Nov 09, 2006 at 22:41
I'm running an Engel 40L + Two Zone off a Remco 100A/H AGM charged through a Pirahna isolator.
I found the previous Optima 55A/H didn't last long enough.
AnswerID: 204028
Follow Up By: itsdave - Thursday, Nov 09, 2006 at 22:47
How long do you get on average with the 100 amp batt out of curiosity. Was looking at the 40 ltr as it draws less amps but have decided on the 60 ltr. Holds more beer
Cheers Dave
FollowupID: 463718
Follow Up By: Richard W (NSW) - Thursday, Nov 09, 2006 at 22:56
Still not as long as I would like and it depends on the temperature and how often its opened. Probably 3 days when fully charged. The Two Zone gives me an extra 20L.
FollowupID: 463721
Reply By: crusa - Friday, Nov 10, 2006 at 09:43
Interesting topic........and I will have a look at the forum archives when I get time.
I have been thinking about getting a small portable (temp) solar panel to quickly attach to the rhino bars on top to charge the cruiser deep cycle battery for the Engel 39 litre, at times when vehicle is not being run. Would be interested to hear what others use as have little knowledge on the solar subject ie .........size/brand/type of panel/and what other parts are needed to be able to do this as a temporary charging arrangement. I have a Piranah charging system on the cruiser.
AnswerID: 204070
Follow Up By: Steve - Friday, Nov 10, 2006 at 22:43
I may be able to help as i have a similar system with a panel ...but am sure Dave will disagree...so why not ask him?? He has all the answers to his similar question !!!!
FollowupID: 463973
Reply By: Sand Man (SA) - Friday, Nov 10, 2006 at 12:07
Andrew has posted a very valid point re running batteries too low.
I have knackered two batteries allowing them to totally discharge a couple of times.
The first one was a 77Ah Deep Cycle wet cell battery.
The second one was an expensive 55Ah AGM (Orbital) battery.
I now use a low voltage cutout device which will disconnect the battery supply when it has dropped to 11.6 volts. This is just above the 30% threshold, below which you shouldn't go.
The Orbital will not charge above 12.2 volts and will not maintain that for long.
(It's stuffed.)
I have gone back to a deep cycle wet cell battery as an auxiliary as this is the largest capacity battery (in Amp hours) that will physically fit in the engine bay. At least this wet cell is "maintenance free".
I still use the 75Ah+ Thumper AGM portable system when I remove the fridge from the car and coupled with a 40 watt solar panel I believe I have the best solution at a "modest" cost. The only improvement I could make is to increase the solar cell capacity, or add an Inverter type Gennie, but I have not found the need for these extremes yet.
Bill
AnswerID: 204101
Reply By: Member - andrew B (Kununurra) - Friday, Nov 10, 2006 at 14:13
Gday Dave
I've had pretty good success so far with a fairly std exide extreme - 85 AH from memory. I've only done 2 trips where the vehicle was parked for very long since buying the fridge (80l waeco), but both trips I got 48 and 50 odd hours from memory, both with the voltage not going below 12.2v. The contents of the fridge was very cold when starting, as while the car was travelling to the destination I crank the temp down, and get everything almost frozen, then set the temp to about 2 deg on the fridge, which keeps the inside temp from 2 at the cold end to about 6 at the warm end. This was in 34 degree temps, but only opened the fridge about 10 times per day (had a beer esky).
I think the dual purpose batteries such as the century you mention and the extreme I have can take charge pretty quickly from an alternator, at least until they are about 80 odd % charged, so a short trip etc can give you a handy top up, and while doing so crank the temp down while using the alternator's power so It wont cycle for a while once stopped (and setting the temp back up to normal)
Although from what I have read, the AGM's are better and last longer, for the price and a 2 yr warranty the exide will do me and my circumstances, I now have a 3rd exide which I transfer from the car to the boat as required, it is in a batterybox with external terminals and a ciggie lighter (whitworths $50.00), so I can have a 3 mattery set up in the car, charge the 3rd battery in the boat, and have a dual battery in the boat as well.
Everyone's needs are different, the hard thin is working out what you really need!
Cheers Andrrew
AnswerID: 204120
Reply By: Willem - Friday, Nov 10, 2006 at 21:29
Itsdave
As usual you get a host of different replies when it comes to batteries and fridges.
My experience is as follows:
I run two Century Overlander 700cca cranking batteries in parallel through an ordinary solenoid with a dasboard switch as a cut out.
I have a 32lt Engel with a Two Zone. The Engel is run on Freeze all the time. Normally we drive most days but if sitting still for up to 5 days I idle the Nissan engine for 20 minutes in the evening and 20 minutes in the morning and if it is a warm day, 20 minutes after lunch. This seems to keep the batteries charged at 12.6volts plus. Both my batteries are now 2 years old.
It works for me.
AnswerID: 204208
Follow Up By: itsdave - Saturday, Nov 11, 2006 at 21:07
Thanks Willem
Sounds like if I run the vehicle a couple of times a day as you do it may be the way to go
Dave
FollowupID: 464087
