UHF Handhelds
Submitted: Friday, Jan 19, 2007 at 23:56
ThreadID: 41416 Views:2775 Replies:9 FollowUps:5
Hi all. I am thinking of buying a Pair of GME or Uniden UHF Handheld radios.
Maybe 2 to 5 watt. They say these units have a range of 6 to 12km in a straight line with no obstructions like hills. Better still if you are near repeaters.
Interested to hear of anyone who has UHF's of a like nature and their experience with them i.e tuning into various channels, talking person to person, etc.
Are you able to hook up a larger aerial to these units as an accessory?
Is the reception better at nighttime?
What is clarity like compared to in car models?
Your thoughts and experience please.
Reply By: Footloose - Saturday, Jan 20, 2007 at 00:01
You'd get better advice and experiences if you mentioned the function that these units are expected to perform, and what your constraints are.
AnswerID: 216568
Reply By: Member - Doug T (W.A) - Saturday, Jan 20, 2007 at 00:57
As I have said on a few other posts now, I work with many different Truckies and other Pilots and find that every time I hear a radio that sounds distorted and scratchy it is a Uniden , all GMEs and Icoms are crystel Clear and easy to read, the problem is they can't hear them selves ,
Site Link
www.icom.net.au/2000_web/index2.html
Doug
AnswerID: 216572
Follow Up By: Member - Doug T (W.A) - Saturday, Jan 20, 2007 at 01:00
You probably ask yourself ....How do I know this , simple, I ask them what they're using or "are you using a Uniden" and the answer is always a yes
FollowupID: 476981
Follow Up By: Member - Davoe (Nullagine) - Saturday, Jan 20, 2007 at 06:11
Dead correct accept I have gone 1 better and driven the 200m too see why ( I already knew) why there radio was so bad and - yep uniden
FollowupID: 476990
Follow Up By: Member - Phil G (SA) - Saturday, Jan 20, 2007 at 21:20
When I hear a scratchy radio that is only 200 metres away, I give them a hand to repair their aerial - usually nothing to do with the set.
FollowupID: 477142
Follow Up By: Richard D - Sunday, Jan 21, 2007 at 18:20
Phil,
Thanks for that info, I thought it was my hand held GME that was the problem.
The guy on the other end with his Uniden, swore blue that he'd never had a problem with others. All I can hear is a faint whisper.
Uniden 'in car ' radios appear O.K., but the hand helds seem to be crap.
Richard
FollowupID: 477330
Follow Up By: Member - Phil G (SA) - Sunday, Jan 21, 2007 at 20:57
Hi Richard,
In my experience, poorly performing UHF sets have always had an aerial problem - usually poor installation of the PL259 connector on the aerial lead, or those elevated feed antennas coming adrift at the base.
I've been trying to stay out of the Uniden vs GME debates. Must say I have two Unidens - a UH088 thats now been in 4 vehicles and a UH040 0.5watt handheld that's worked well over the past 5 years. GME is an Aussie company and thats a good reason to support them, all else being equal.
FollowupID: 477348
Reply By: Dave & Shelley (NT) - Saturday, Jan 20, 2007 at 01:03
Hi there,
The main question is what will you be using the hand held units for. Hand held UHF units come in handy for a wide range of applications such as assisting when reversing bigger trailers/vans etc... We have a GME 1 watt unit and it works well around 2 - 3 km. I usually use it when I am off bushing walking by myself and can call the other half at camp. The will also work well between vehicles, but only over very short distances with smaller hand held units. The main problem is that the antenna is small and in the front of the vehicle. The actual vehicle blocks the signal going back and signals coming forward there for restricting the range.
If you go hand held and want to use them for vehicle comms, you can buy more expensive units around the 5 watt level with a vehicle mounted antenna. They can be set up to work as a standard UHF radio (CB type) and cost around $400. I wouldn't really bother as my father did this when he first started touring Australia and went back to a car based unit after 3 months.
I would opt for a GME 3200/3400 or equivalent with a smaller hand held unit. That way you get the best of both worlds.
Hopefully this helps, good luck
Dave
AnswerID: 216573
Reply By: Robin - Saturday, Jan 20, 2007 at 11:12
Hi Nomads
Reccomend Uniden UH075 as probably one of the best hand helds (Icom is also up there). around $350 though.
It has the range , 5watts, and can have both seperate aerial connection and seperate mic.
They are not so easy though to charge in a car , and if this is your main use I would get an in car unit.
As well as above its a well packaged unit , and essentially waterproof.
Keep one in a mobile phone holder as second unit in the car.
We have several handhelds, and this is one that has survived much of the knocking around that they get when used on enduro bikes.
Robin Miller
AnswerID: 216608
Reply By: Darian (SA) - Saturday, Jan 20, 2007 at 11:55
I bought a GME 6200 for $400 on a show special in SA - included fast and slow chargers - seemed the best at the time re features - NiMH (not Nicad) battery - the Icom 5 watter ran a close second for me - the Uniden extra compact 5 watter looked so small I assumed the battery would have reduced life compared to these others. The 6200 has scan and duplex, plus selcall and CTCSS capability (selective mute - I have it teamed with the in car unit for selcall and mutes etc). Stumpy antenna only used so far but range is very good (can get a longer antenna for it) - when in convoy, others tell us it is as clear as our in-car Icom 400 pro and it reaches way out on gently undulating terrain - seriously compromised over decent hills though (like most UHF). The selcall function bites right through low hills though, when voice struggles ! Good battery life. Very sensitive on incoming - picks up a lot of regional traffic on scan mode.
AnswerID: 216615
Reply By: Sand Man (SA) - Saturday, Jan 20, 2007 at 12:36
As other shave stated, it depends on what use you want to use them for. Are they in addition to a vehicle mounted base unit.
How much are you prepared to pay?
How do you intend charging them?
A good compromise is a 2 watt handheld which cost in the order of $170 and are powered by AA batteries. These will give a reasonable range if communicating back to a vehicle mounted unit.
I use rechargable AA's in most of my portable 12 volt radios, cameras, etc. and I can easily recharge the flat batteries from the vehicle.
All 5 watt handhelds to my knowledge use an internal rechargable battery which requires a unique charging base.
Bill
AnswerID: 216625
Reply By: Member - extfilm (NSW) - Saturday, Jan 20, 2007 at 14:52
I have a 2 watt and a 5 watt handhelds bought from DSE a few years back. I use them on building sites when I am blowing strings through conduits. Or give them to the labourors to use. These things as you could iagine have been through hell and back. They both still work perfect, they have been dropped, rained upon and misused by labourers because they did not purchase them themselves. I cannot see the writing for the buttons anymore but they work fine.
I took them out to the simpson a few years ago and whilst on a dune gave a quick call. Got a reply, had a brief chat and found out the person on the other end was at poepell corner. i checked my speedo, By the time I got to Poepell it registered 25kms. I was reading them clear and they were reading me fine to. By memory the 5 watt cost $298.
I also have one in the vehicle and have really not used it.
AnswerID: 216648
Reply By: Member - Glenn D (NSW) - Saturday, Jan 20, 2007 at 21:12
Hows it going Nomads ,
If you get a radio and it comes with an antenna , putting on a bigger one wont make it transmit further, effectively ( actually it will because line of sight between visable horisons will change with ant height, will probably only be effective if you have an ant that is at 35000 ft ) for uhf.
Glenn.
AnswerID: 216730
Reply By: Member - Ivan H (NSW) - Sunday, Jan 21, 2007 at 20:41
We use them on our car cruises.
When I had my car I had an in-car Uniden UH013, coupled with a GME 6db aerial.
Now that I sold the car I use my Uniden UH075 hand held coupled with the same aerial when in a mates car. Same great results as the in-car unit.
AnswerID: 216892
