Info on Natmap Raster 2005 Premium
Submitted: Friday, Feb 09, 2007 at 13:31
ThreadID: 42150 Views:3140 Replies:6 FollowUps:7
I'm looking at buying this map system ,(Natmap Raster) after being given a demo by Des Lexic.
Just need a couple things answered if somebody out there uses or knows how it operates.
Can you print off what ever map you have on the computer screen.
Also can we install this on 2-3 computers or are you surposed to just down load into one computer.
Thanks in advance
Cheers Scoof. (SA)
Reply By: Member - Big Al. Gold Coast - Friday, Feb 09, 2007 at 13:51
Print OK
I have all my map CD's on the vehicle laptop and all on home PC
you need at least 256mb ram + 40mb for Raster software
AnswerID: 220805
Follow Up By: Member - Big Al. Gold Coast - Friday, Feb 09, 2007 at 14:00
You can just load the start up files and then insert map CD's as required,
to save drive space.
FollowupID: 481445
Reply By: Member - John and Val W (ACT) - Friday, Feb 09, 2007 at 14:24
Scoof, suggest sign up to the Yahoo forum at
tech.groups.yahoo.com/group/OziUsers-L/
where you will get lots of detailed help.
I think you're asking if you can print just what's on the screen. Don't think so, but ask at the above site. Your computer may well have a "print screen" facility enabled - mine hasn't so I can't check - this would allow you to do a screen dump.
If you're asking if you can print the whole map - You can save as a .jpg, but that's a serious file for big maps. Small ones yes, big ones not a good idea.
HTH
Multiple use - think it's ok to install on multiple machines, but not run them simultaneously. Again ask as above.
J and V
- Albert Einstein
AnswerID: 220817
Follow Up By: Scoof - Friday, Feb 09, 2007 at 14:52
Thanks to you all'
John and Val W,
Thanks for your reply I do have the print screen facility and just want to print, say a 40 to 50 k raduis map.Just to help my guy's to find delivery addresses .
Also when I'am working out route suvey's for delivering our wide loads into other States and areas.
It looks like a great system.
Kind Regards Scoof (SA)
FollowupID: 481459
Reply By: Member - Oldplodder (QLD) - Friday, Feb 09, 2007 at 16:37
In regard to printing. I have NATMAP premium 2005.
Yes, I do print mine for use the car.
My most able navigator prefers to use the map and the PDA GPS confirms her dead reckoning.
So I print out the 1:250,000 k maps at 1:200,000, so that 1cm = 2km.
(And the printing is a little larger for those navigators who won't wear their reading glasses.:o))
Now I do work at a place that has a large format printer, but I keep my prints down to A1 (895mm x 595mm) or B1 (707mm x 1000mm) for a strip map for ease of handling in the car.
I usually print from the mosaic to exactly cover the area I need.
PS - the 1:1,000,000 and 1:5,000,000 are rubbish.
At least 20 years out of date.
Don't even show the Wivenhoe dam outside Brisy, or the 'new' highway leading north of Brisbane. Both built in the 80s.
Not sure of the copyright situation, since most of the 1:250,000 series are avialable for free download over the web. I have copies installed on my PDA, work computer and home computer. Feel since I am a single user, it it licensed to me, not my computer.
AnswerID: 220841
Reply By: On Patrol - Friday, Feb 09, 2007 at 17:16
Scoof
I have it on both the laptop in the car and the desktop at home, I also have it instaled on the hard drive (C/) I have even gone to the trouble to burn DVD back-ups, just in case. By having it on the hard drive I dont need to have the disc in the cd-rom drive all the time. But this option does take up a lot of disc space.
Exellent product. Hema maps are good but are similar to NATMAP with contact and location details added, such as local permit details in aboriginal reserves, service stn details & contact numbers etc.
As for printing you can do a screen capture and print, you will however just have whats on the screen.
If you are set up for "moving map", printing is an unnessisary option.
Hope this helps, on patrol.
AnswerID: 220848
Reply By: Sand Man (SA) - Friday, Feb 09, 2007 at 18:27
Scoof,
I had little luck trying to print a map directly from NatMap Raster screen display.
It will only print on a third, to a half of an A4 sheet of paper.
Solution is to load it into OziExplorer and you can then print a full size sheet on A4, A3, (or whatever your printer will produce) of the image displayed on the screen.
There is no restriction on how many times you may load it.
I have it installed on the Notebook, the Desktop and also on my work PC.
Very good set of maps and work well with Ozi.
Bill
AnswerID: 220860
Follow Up By: Member - Oldplodder (QLD) - Friday, Feb 09, 2007 at 18:39
I usually print the 'high quality option' from NATMAP, using 'print current view'.
Bit of a pain controlling scale.
As you say, Oziexplorer is easier for printing.
FollowupID: 481534
Reply By: fruers - Friday, Feb 09, 2007 at 20:28
If you intend to travel around Aus with digital maps you will probably end up wanting the Hema 4wd Raster map set, which includes the Natmap 1:250k maps, not 100% sure if they're as up to date as the premium. The only downfall is that they're single maps (514 of them) rather than the seamless mosaic with the premium set. Although that saves some work when using them with a PDA.
I initially bought the Natmap premium for $110 then realised that you get all those maps with the Hema 4wd raster maps for $149 (got an exchange). Pretty easy decision economically and the quality is more than adequate.
AnswerID: 220883
Follow Up By: Member - jeff M (SA) - Friday, Feb 09, 2007 at 22:43
Hi fruers ,thanks for Reply
At the moment I need a system to help me do my route survey's and Permit's from all the Gov body's eg, Transport SA,ETSA ,Telecom ,Powercor,SP Austnet, Vic Roads and Dept of Inferstructure (railways) and the like that sort of thing .
Also to help show my guy's were to go when organising deliveries and service calls.
Do you still think I would be better of with 4WD Raster.
Cheers Scoof (SA)
FollowupID: 481588
Follow Up By: fruers - Saturday, Feb 10, 2007 at 07:35
Hi Scoof,
In that instance i would recommend the natmap premium maps. The 4wd raster is only useful if you're touring. For instance if you were going to cape york you can load up one or two maps that cover the whole area and provide info on camping, sightseeing and such, heaps of info that isn't on the 1:250k maps, but they are often at a lower resolution like 1:1M.
In your case where you have a specific purpose there's probably not a lot of value in them for you.
If you go here you can click on the sample images and see what i'm talking about:
Site Link
Sorry to make it confusing :).
FollowupID: 481611
Follow Up By: Member - jeff M (SA) - Saturday, Feb 10, 2007 at 08:08
thanks fruers
I was confused but thats OK only way you learn stuff. LOL
Scoof . (SA)
FollowupID: 481614
Follow Up By: Member - jeff M (SA) - Saturday, Feb 10, 2007 at 18:37
Thanks to all Replys,
Ordered it this morning from the EO shop.
Can't wait to see how helpful it will become.
Thanks to Des Lexic as he come over and gave me a demo.
Cheers Scoof. (SA)
FollowupID: 481665
