outboard motor bracket
Submitted: Monday, Mar 19, 2007 at 13:44
lmkbm
Just had a duel swing away wheel carrier fitted to my troopie(kaymar).
wheel on one side and want to carry my 15 hp outboard on the other side.
anyone ever done this, or know of where i can get a bracket made?
weight of motor is the same as a tyre and rim.
i live in
adelaide.
thanks
Reply By: Member - Doug T (W.A) - Monday, Mar 19, 2007 at 15:07
Are you expecting Floods ...lol, A mate of
mine has a K&N Dual Caddy on his Troopy, he has modified the left side bracket to fit a Generator so you should have no problems having some type of fixture that you can attach the outboard to, might need to have some means of adding a pad-lock as
well .
Doug
228333
Reply By: Sand Man (SA) - Monday, Mar 19, 2007 at 16:45
You should be able to make a "bracket" yourself, out of plywood.
The Kaymar carrier would already have a steel "hub" that you would normally bolt your second wheel to.
Cut square pieces of 12mm plywood wide enough to be a little bigger than the spacing between the outboard clamps.
Glue about 3 pieces together to provide some width and strength and bolt the plywood assembly to the steel hub.
The outboard can be placed over the plywood section, clamped in a normal fashion, then the clamp handles padlocked together to stop removal.
Marine ply and waterproof glue would be best then a coating of clear marine vanish to seal the ply. It should last for years mate.
228361
Reply By: Member - Vincent A M (NSW) - Tuesday, Mar 20, 2007 at 09:43
Just remember that on some small outboards there swival & cramp bracket are not up to the job & often brake i have seen a few come through work so keep an eye on it
228505
