ALL Happy With WAECO,S
Submitted: Friday, Mar 23, 2007 at 12:01
ThreadID: 43553 Views:4051 Replies:26 FollowUps:11
Just a short Question are you all Happy With your Waeco Fridges as I just Brought one a 50 ltr have I done the right thing will I be happy.
What are the Problems that I should look for as I know that there are some Issues with electrics,
Thought hard about a Engel but dont like the steel case.
I am retireing my Bushman 35.
djpatrol
Reply By: Jimbo - Friday, Mar 23, 2007 at 12:05
CF 80, 2.5 years old.
Happy? Yes
Problems? None
And it was a "second" from the Fridge Shop for $980.
Previously had an Engel 39 for 7 years
Happy? Yes
Problems? None
Cost nearly $1,200 close to ten years ago.
AnswerID: 229227
Follow Up By: dj Patrol - Friday, Mar 23, 2007 at 12:12
Hi Jimbo,
I also got a Second from same place for $800 new some small scuffs sounds like I made the right choice.
Hope So
djpatrol
FollowupID: 490030
Follow Up By: Ozrover - Friday, Mar 23, 2007 at 15:53
I got an FF70 from the fridge shop as well, & wasn't happy at all!
Had nothing but trouble with it, ended up getting an Engel & havn't been happier!
FF70 too old maybe, or just a problem child?
FollowupID: 490057
Follow Up By: Member - Blue (VIC) - Friday, Mar 23, 2007 at 16:03
CF 110 from fridge shop, 'bout the same age as Jimbo's, very happy with it...
If you think it's using a litle too much power, check the interior light... Mine was jammed on and contributing quite a bit of heat to the fridge. easy fix tho...
FollowupID: 490060
Reply By: Gronk - Friday, Mar 23, 2007 at 12:09
With a bit of luck ( as with anything these days ) you should have no probs with it..
As said before here, make sure you have full voltage going to it ( same with all fridges )
And, crank it down to zero degrees and enjoy your nice cold drinks !!!!
AnswerID: 229229
Reply By: tomjones83 - Friday, Mar 23, 2007 at 12:11
have a 110l, purchased as a second sep last year for $900. runs great. a little power thirsty but ice cold :-)
AnswerID: 229231
Reply By: Member - Noldi (WA) - Friday, Mar 23, 2007 at 12:49
Have the same fridge for 1 and half years no problem did run 6mm wire to the back though
AnswerID: 229237
Follow Up By: Member - Peter R (QLD) - Friday, Mar 23, 2007 at 13:05
Have the 110l for 2 years no problem have the 50 for about 6 months and the only problem , was as follows
Running off battery , I shifted a few things and, unbeknown to me, the lead became partly disconnected.
Plugged it back in about an hour later and no power.
Took it back to Waeco at Gold Coast and they put it up on the bench in office area plugged it in and pressed the On/Off switch.
Came on immediately.
They told me if it is disconnected for about 5 minutes or more it needs to be restarted.
Pedro
FollowupID: 490036
Reply By: Robin - Friday, Mar 23, 2007 at 12:58
Hi Dj
Got the little 25lt one because with a little bit of work it fits between the Patrols front seats with console removed, hence greatly increased space in rear for other things.
Engels had nowhere near the same size/weight ratio.
Been a seriously good unit without issue, although the replaceable plastic lid catches feel like they won't less many years.
Our camping philosophy is to minimize weight and hassles
The fridges light weight of 13kg , means its easy to put in and out of car, under a tree etc whereas watch so many others have to climb over things to gain access and basically forced to leave there's inside car.
It already only used about 800ma / hr to keep things below 5c but this position meant that it operates in a much cooler average environment than if in rear and hence uses even less current.
We run our entire system with only the cars main battery and the fridge with it selectable inbuilt low volts cut out helps in this regard.
Back it up with good esky sometimes , but this is becoming less now as with some planing because of the smaller size , we tend to have menu that requires low level of frozen stuff , and hence just make sure that supplies for next 24hr are mainly whats keep in fridge. About half is drinks, and despite its small size is one of few that can both keep a 2lt bottle upright and have genuine little space which is warmer for cheese etc.
$520 during Rays 20% off sale 15months ago
Robin Miller
AnswerID: 229240
Reply By: Patrol22 - Friday, Mar 23, 2007 at 13:09
Had my CCF45 for 6 years and never had a problem with it....so happy with the WAECO that I just bought a second 40ltr jobbie to use as a freezer in my camper.
AnswerID: 229243
Reply By: Brew69(SA) - Friday, Mar 23, 2007 at 14:02
I have a FF-70 purchased from the fridgeshop about 3 years ago. It was far from new but for $650 it was a bargain. No probs with it at all.
AnswerID: 229255
Reply By: dawesy - Friday, Mar 23, 2007 at 14:09
Had a CF-50 for about 2.5 years. No problems and very happy with it.
About the only thing that has ever gone wrong was the lid coming loose when bashing the car over some big potholes I didn't see coming. Just whacked it back on, and reminded myself not to hit large potholes at 70 in future.
AnswerID: 229258
Reply By: Robnicko - Friday, Mar 23, 2007 at 14:09
dj patrol,
I have a CF40ac. Bought it when the AC first came out. I have never had any problems with the fridge but did have a problem with the cord they supply. If you open the cord up there are 2 little brass eyelets that are crimped. I soldered them as there was a little voltage drop being caused by it.
Otherwise it's my favourite 4x4 accessory.
Rob
AnswerID: 229259
Reply By: SimonW - Friday, Mar 23, 2007 at 14:41
Hi DJ,
We have a CF50AC for 18 months with lots of use & it has never missed a beat, very happy.
Cheers Simon.
AnswerID: 229271
Reply By: slave - Friday, Mar 23, 2007 at 14:55
Never had a problem with either of our Waecos in the 3 years that we have had them.
Price was the major factor in buying a Waeco against other brands and we haven't been let down.
Mrs S
AnswerID: 229274
Reply By: Shaker - Friday, Mar 23, 2007 at 15:27
QUOTE: "Thought hard about a Engel but dont like the steel case. "
Maybe you should drive a plastic 4x4!
AnswerID: 229278
Follow Up By: dj Patrol - Friday, Mar 23, 2007 at 16:32
Shaker,
I thought hard about that too do you know where I could get a Plastic 4.2Td Patrol as it would solve any Rust and Dent problems.
WOW what have we started now from all the tojo,s
djpatrol
FollowupID: 490064
Follow Up By: Member - Phil G (SA) - Friday, Mar 23, 2007 at 16:48
Our Xtrail has plastic front guards - perhaps the new Patrol will too :-)))
FollowupID: 490069
Follow Up By: Shaker - Friday, Mar 23, 2007 at 18:04
Yes, I saw an X-Trail with a smashed front guard the other, obviously they are 'replacement only' ...... bit like a Waeco .... LMAO!
FollowupID: 490089
Reply By: marcus - Friday, Mar 23, 2007 at 16:23
Had the CF-50 for about three years now and has not missed a beat.It is a good all round size and got a great deal on it with cover,charger,eight can cooler fridge for under a grand.
Mark
AnswerID: 229285
Reply By: Alloy c/t - Friday, Mar 23, 2007 at 17:17
Bought our 80lt in Jan 03 from the fridge shop as a 2nd , not 1 mark on it ,got a deal, $990 with a new cover and the Mobitronics convertor , has never missed a beat ,uses an avgerage of 64 amps per 24hr period with the freezer section set at -18c , only complaint would be that the fridge cover has faded ,but then again so has the cover on our Engle.
AnswerID: 229299
Reply By: Camper - Friday, Mar 23, 2007 at 17:27
Yeah Dj,
Have used my Cf 50 for 4 and a half years now , it's been the beer fridge the whole time we are at home and has done over 40000km's of 4wd and touring trips.
As long as it's got proper wiring from the battery to the fridge you should get many years of fresh food and cold beer!
AnswerID: 229300
Reply By: Member - David A (QLD) - Friday, Mar 23, 2007 at 18:00
We have a CF-60. Works fine, low battery draw. Only hassle has been with the little hold-back strap (joining lid to main body) which parted company early on. No big deal, though.
David
AnswerID: 229312
Reply By: nowimnumberone - Friday, Mar 23, 2007 at 18:07
we bought a 90lrt from the fridgeshop about 3 yrs ago no problems at all.
bought a 45ltr from supercheap $440 about 12 months ago it hasnt had a lot of use but when we use it it works perfect.
AnswerID: 229315
Reply By: Sand Man (SA) - Friday, Mar 23, 2007 at 18:10
dj,
I'm not a Waeco owner but mate, why look for trouble before you have any.
"Bang for bucks" you have bought one of the more popular brands of fridge and I'm sure you will get satisfactory operation from it.
I would guess that many of the problems we hear about on this forum, concern the "seconds" fridges that are sold.
Now how's that! An Engel owner not criticising your purchase:-)
Bill
AnswerID: 229320
Reply By: Member - Doug T (W.A) - Friday, Mar 23, 2007 at 19:19
Just a short answer YES...YES....YES...YES...YES...YES....YES...YES...YES...YES....YES...YES... YES...YES....YES...YES...YES...YES....YES...YES...YES...YES....YES...YES...YES...YES....YES...YES...YES...YES....YES...YES...YES...YES....YES...YES...
AnswerID: 229328
Follow Up By: dj Patrol - Friday, Mar 23, 2007 at 19:32
Evening Doug,
That mean you agree with the Waeco Doug.
FollowupID: 490116
Reply By: Grungle - Friday, Mar 23, 2007 at 19:42
Have had an 80l Waeco for around 4 years and have not had an issue. It has been a great fridge/freezer. Also had a 39l Engle for around 7 before that and was great also. I would stick with the Waeco (myself) due to its features such as low voltage cutout and emergency mode which bypasses all the electronics and runs the compressor non-stop. The Engle used to suck everything from the batteries which used to egg me.
David
AnswerID: 229331
Follow Up By: Sand Man (SA) - Friday, Mar 23, 2007 at 20:50
Yes David,
Would have to agree with you.
I have stuffed two batteries using the Engel, which "runs on the smell of an oily rag" and will suck everything out of the battery it's connected to.
But, I couldn't blaim the fridge.
Rather than replace the fridge, I spent $30 on a low voltage cutout adapter.
Now, "is good"!
Bill
FollowupID: 490121
Reply By: Member - Stephen M (NSW) - Friday, Mar 23, 2007 at 19:57
Got the 50L waeco runs 24/7 and has not missed a beat. Used it in the high country prior to xmas and ran it at -16 as freezer and didnt miss a beat and was running off main starting battery for 7 days. We were obviously starting/using the vehicle everyday so runnuing the battery flat was not going to be an issue. Prior to high country went up farm and got 2 &1/2 days out of a fully charged 720cca battery. Was the old one out of my lux but still ok so took it with me as my dual battery controller shat itself prior to going away so whacked in a new heavy duty battery for the starting of the hilux and threw the old one in the back. Was going to use it to jump start if needed. The 50L draws very minimal power. Not knocking engel they are a brillian fridge as well but went the waeco due to 5 years warranty and cheaper will it last the distance who knows but so far so good. Regards Steve M Regards steve M
AnswerID: 229336
Reply By: Member - Doug T (W.A) - Friday, Mar 23, 2007 at 19:59
yes
AnswerID: 229337
Reply By: Crackles - Friday, Mar 23, 2007 at 20:34
dj an interesting post. 22 replys & barely an issue with any. This begs the question is that because Waeco's don't have any problems or are the owners that aren't happy just not game to admit it? Quite a few I travel with have had reoccuring issues with warped lids, the light not working, broken latches, fawlty power leads & complete failure of the electronic control unit. One had been back for warrenty 4 times, which I must say Waeco has an excellent back up service.
Possibly to get a better idea on what can go wrong with them is to look back through the archives.......plenty of storys on them there.
Have you done the right thing?........of course you have. It's nice & light, easy to transport, compact, has a 5 year warrenty & is great value for money. (It even keeps things cold ;-))
Would I buy one..............................? No.
Cheers Craig.
Autofridge.
AnswerID: 229342
Follow Up By: Jimbo - Friday, Mar 23, 2007 at 20:50
A very "balanced" opinion from someone who has never owned or used the product.
Armchair expert????
FollowupID: 490120
Follow Up By: Crackles - Saturday, Mar 24, 2007 at 07:27
Don't actually need to own one to see how they work. Around camp I've spent a little bit of time with multi meters & pointy nose plyers trying to fix a few ;-)
Cheers Craig.........
FollowupID: 490166
Reply By: sav - Friday, Mar 23, 2007 at 21:11
I have both a 40 litre Engel and 50 litre Waeco.
Both are solid performers, however the Waeco (18 months old) has needed a warped lid replaced (that also resulted in breaking one of the plastic tabs.
If they sorted out the plastic tabs on the Waeco there wouldn't be anything between them IMHO.
The steel tabs on the Engel are simply more robust.
Sav.
AnswerID: 229349
Reply By: Alan W - Saturday, Mar 24, 2007 at 00:14
My philosophy is to try before you buy, so for our Simpson desert trip in 05 I hired a engel and also a waeco fridge.
On this trip we had in total 3 engels, 2 waecos and 1 finch.
Both waecos died, including my hired one, as did the finch. The 3 engels, no problems.
So I went out after the the trip and brought myself a 60 Ltr engel and as expected ,have had no problems.
The majority of replys to you are favourable towards the waeco so sit back and enjoy that cold beer that just came out that fridge.
AnswerID: 229395
Reply By: Member - Russell H (WA) - Saturday, Mar 24, 2007 at 00:25
I have two Waecos, 40l and 50l. The older one is now 6 years old. These fridges have been in the back of two vehicles that the road conditions completely destroyed, all the while the fridges never missed a beat. Thats almost 400,000 K's without issues.
What I do know is this: The Waeco DC cords have a plug that allows them to be plugged in a standard ciggy socket or a more "postive locking" socket. Use the latter. Either replace your ciggy socket or add the positive locking one. I have burnt out two cords because the contact was "feathering".
Also my fridges are quite sensitive to input voltage...they are designed that way... so invest in some good, heavy-duty wiring to where the fridge is and you won't have any trouble.
AnswerID: 229397
