tomtom navigator 6
Submitted: Tuesday, May 01, 2007 at 13:19
mickandchelle
just recently received a HP ipaq rx5700 pda for work. has tomtom navigator 6 installed and built in SiRFstarIII gps. does anyone know of the availability and where to get more detailed maps for this unit. i am wanting to get some of inland australia away from major towns and
simpson desert????
is this possible and how hard is it to do????
Reply By: Des Lexic - Tuesday, May 01, 2007 at 14:35
You need to install a CE version of Oziexplorer and then the Natraster map of Australia. that will get you most
places. Do a search on Ozie here and you will find heaps of info.
237124
Follow Up By: Bonz (Vic) - Wednesday, May 02, 2007 at 20:52
You PDA compendium you hahahahahah
498553
Follow Up By: Des Lexic - Wednesday, May 02, 2007 at 22:28
But in 3 weeks time I shall be much wiser
498594
Reply By: mj1 - Tuesday, May 01, 2007 at 16:59
won't answer your question but these are a laugh for tomtom users :)
Site Link
237166
Follow Up By: Pajman Pete (SA) - Wednesday, May 02, 2007 at 07:29
Great link - thanks
Pete
498342
Reply By: Sand Man (SA) - Tuesday, May 01, 2007 at 18:00
As Des has stated, you need something else for inland Australia.
Navigator and other similar products are only designed to give voice prompted turn by turn directions in the metropolitan areas of the major cities.
OziExplorer CE and NATMAP Raster (maps) is the most common and popular product for touring Australia.
237181
Reply By: Kumunara (NT) - Tuesday, May 01, 2007 at 20:45
Mickandchelle
I have an rx5765 and they are a good unit.
I have loaded OziExplorerCE and have Hema, Westpring and Natmaps on SD cards.
I have TomTom for the blacktop and Ozi for off road.
Tjilpi
237257
Follow Up By: mickandchelle - Wednesday, May 02, 2007 at 07:18
thanks for that....I downloaded a trial version of oziexplorer..seems hard to use. Is this so or am I just one of the uneducated??????
is there a tutorial for this or do you only get it when you purchase a full version?
498340
Follow Up By: Kumunara (NT) - Wednesday, May 02, 2007 at 19:42
mickandchelle
The help file is very good. I printed it out from a PC and put it in a folder to learn the program.
I have Oziexplorer on my laptop and was familiar with that so the transition was easy. You can also use Moving Map on oziexplorer using you Ipaq as a NMEA only GPS.
Tjilpi
498513
Reply By: Pajman Pete (SA) - Wednesday, May 02, 2007 at 07:25
I have the same unit and use OziExplorer CE and the Natmap rasters. They are a good unit. You can also have both the tom tom software and Ozi CE running at the same time so if you leave Ozi on the screen the voice prompts from the tom tom will still come through.
I am told that the IPAQ can also be used as a CPS linked to a laptop to drive Ozi on the lap top. I haven't tried this yet.
Pete
237335
