Monday, May 28, 2007 at 08:47
It just goes to show, what one likes, another has different ideas.
I actually like the "tube" when emptying the contents. you can direct the waste into the
dump point (Caravan Parks) or hole (Bush) more easily.
Over all though, I think most of the better known brands, (Thetford Porta-Potti or Fiama, etc) are good products.
Two points I would suggest.
1. Size - The
toilets are made in different sizes and in the smaller ones, the waste compartment will fill quicker and your Bum will be closer to the ground.
The larger sizes hold more but take up more room in storage.
Either are probably a compromise one way or the other.
2. Chemicals - regardless of brand, chuck away, (disposing of properly) the chemicals you get with the original purpose and replace with Bio Magic.
Bio Magic contains no hazardous chemicals as it is predominately oxygen, which speeds up the breakdown process and eliminates the smell, rather than just disguise it.
503865
