TJM roof rack/basket on 80 series
Submitted: Friday, Jun 15, 2007 at 21:48
ThreadID: 46711 Views:2474 Replies:2 FollowUps:2
Have alluminum TJM roofrack is made of square box section with bar across it
which way do I mount it i.e. which end does the most over hang go too?
Reply By: Sand Man (SA) - Friday, Jun 15, 2007 at 22:45
Don't know about the overhang Graham but I would assume the front of the rack would be angled. The bottom would protrude a bit compared to the top so that a wind deflector could be mounted with a sloped back angle.
Bill
AnswerID: 247168
Follow Up By: Graham & Lynne - Saturday, Jun 16, 2007 at 11:14
Both ends of the rack are completly square, it is not angled for a wind deflector, a 80 series roof gutter is not straight, the only difference in the rack is one end over hangs more than the other on the mounts
FollowupID: 508054
Reply By: Gone Bush (WA) - Friday, Jun 15, 2007 at 23:06
Graham & Lynne, look at the uprights on the roofrack. Then position them to match the B and C pillars and that should show you the correct fit.
AnswerID: 247171
Follow Up By: Member - Ian H (NSW) - Friday, Jun 15, 2007 at 23:27
Correct.
FollowupID: 508009
