Tuesday, Jul 03, 2007 at 22:47
Well Richard, I have not seen what data from Denso Japan you are talkin about, nor what engines/components they are discussing. I'd be interested in seeing it.
Denso make air con systems don't they? Anyways, I know that some
diesel fuel injection systems don't work
well with Biodiesel, and Denso gear may be one of the few.
What you say about solvents is difficult to understand. Of course diesel and biodiesel in their own right are solvents. The oil is "liquified" in the normal way solids are liquified - the application of just a little bit of heat! There is another solvent - methanol in most biodiesel production processes, that is used to create a (so called) methoxide agent (or similar) that stimulates the reaction to create the biodiesel. This methanol is not found in the final production biodiesel except in miniscule amounts, as stipulated by the Biodiesel standard in Australia - which happens to be what is used in Europe.
Commercial suppliers of biodiesel do in fact, warrant their product in Australia - examples are SAFF in
Adelaide. If it causes damage to your engine they will see that you are properly compensated. Try them out. Call them and see. They are selling a consumer product in a market governed by the Trade Practices legislation of the states they operate in, and are liable.
With the amount of misinformation going around about the subject it is little wonder that Australia is so far behind in the adoption of Biodiesel here versus Europe. Interestingly major oil companies here are buying up almost the entire production of biodiesel in Australia to blend with their standard product because it is better for the environment (burns cleaner), has better lubricating qualities, and can be included in standard diesel up to 5% without affecting compliance with the diesel standards.
In addition to the link above, see The
Caltex Site where I quote:
"Consumers can have full confidence in the petroleum products they are purchasing at service stations and know that the ethanol blends sold are fit for purpose in most new and older vehicles, as specified by individual vehicle manufacturers. Manufacturers have also approved 5% biodiesel blends (B5) for general use as a retail
fuel."
You are more than likely using it and you don't it!
Andrew.
511766
