Gas Bottle Level with Boiling Water Trick?
Submitted: Monday, Jul 16, 2007 at 11:18
ThreadID: 47760 Views:22220 Replies:11 FollowUps:7
Hi All,
Does the old tip boiling water on the side of a gas bottle really show you the level? Or am I just being had on. I normally weigh them but the digi scales are on the blink.
Thanks in advance
Matt
Reply By: Member - Mike DID - Monday, Jul 16, 2007 at 11:21
I just shake the bottle to get an idea of how full it is.
AnswerID: 252682
Follow Up By: Matt(WA) - Monday, Jul 16, 2007 at 11:28
Thanks Mike,
I would but they are the 9kg ones and are in a sealed part of the boot of my van that is self draining. They are a bugger to get out and I have a crook back so have to get someone to give me a hand. Thanks for your response
Matt
FollowupID: 513737
Reply By: Member - MrBitchi (QLD) - Monday, Jul 16, 2007 at 11:25
It works OK. The water dries quickly off the top of the bottle (the empty bit) and leaves condensation on the lower bit. Works best if the bottle is warmed in the sun. Can also get those stick on tell tales that you pour water over.
AnswerID: 252683
Reply By: Member - Fred L (NSW) - Monday, Jul 16, 2007 at 11:33
I tried the hot water trick & it showed me nothing. Still using the tank after 4 weeks.
Fred
AnswerID: 252684
Follow Up By: fisho64 - Monday, Jul 16, 2007 at 11:47
maybe it was full at the time you tested it? Just a thought?
FollowupID: 513740
Follow Up By: Member - Fred L (NSW) - Monday, Jul 16, 2007 at 11:51
Hey fisho64,
I am pretty sure it was not because I filled it many moons ago - can't remember when.
On the other hand, maybe you are right.
Fred
FollowupID: 513741
Reply By: mick - Monday, Jul 16, 2007 at 11:48
Matt,
Works fine for me. Pour the hot water on the outside of gas cylinder, wait a few seconds then run your hand up and down the side. You will actually feel a difference in temperature where the level is, as the liquid gas is colder as compared to the vapour. As a previous reader wrote, you can get those stick on ones, may be a little easier.
Mick
AnswerID: 252685
Reply By: Matt(WA) - Monday, Jul 16, 2007 at 12:03
Thanks for all your replies. Might have a look for these stick thermometers at bcf later on in the week. Will try the hot water when the kettle has boiled. Thanks all
Matt
AnswerID: 252687
Reply By: DIO - Monday, Jul 16, 2007 at 14:19
Just install a safety cut-out device with a gauge built in. Apart from the priceless safety feature of the auto cut-off, in the event of a leak etc, it also indicates remaining gas level.
AnswerID: 252708
Follow Up By: rags - Monday, Jul 16, 2007 at 19:38
Dio
Just dont rely on these to cut off if the leak is only a small/slow leak [which can be potential as deadly] as a slow leak gas flow would appear no different to the gas flow of an appliance burning,These only work when you have a broken pipe ie a rush of gas through the rego.
Russ
FollowupID: 513842
Reply By: SARocks - Monday, Jul 16, 2007 at 18:31
Bought an ultrasonic device in the UK that gives accurate reading of gas in bottles.
Mounts underneath gas bottle. Brilliant made in Germany
AnswerID: 252740
Reply By: garryk - Monday, Jul 16, 2007 at 19:17
Best way is to pour the boiling water down one side of bottle , then run a finger UP the bottle , that way you can feel when cold becomes hot
But doing it from top to bottom i.e. from hot to cold it is not very easy to feel the level
Garry
AnswerID: 252756
Follow Up By: OnYaBike (Cairns, QLD) - Monday, Jul 16, 2007 at 21:20
Should you test the bottle after gas has been burning for a while so that you get the cooling effect of evaporation above the liquid? Just a thought, I've never tried it myself.
FollowupID: 513884
Follow Up By: garryk - Tuesday, Jul 17, 2007 at 17:34
I do not think so
I just do it after bottle has been standing unused for some time and works fine
Garry
FollowupID: 514079
Reply By: Sand Man (SA) - Tuesday, Jul 17, 2007 at 00:20
I bought my bottles with a built-in gauge.
Internally there is a float mechanism and externally a small plastic indicator gauge.
Available (I think) in 4.5 & 9 litre bottles.
In South Australia , you can buy them from Maxbuilt Trading at Norwood.
Bill
AnswerID: 252864
Reply By: Flight Sargent - Tuesday, Jul 17, 2007 at 20:07
G,day.....there is a gas fuse that I have bought for my bottles cost about $30 each from Kmart, big W etc.....they actually show you how much is left in your bottle and also protect from flash back etc.
If you require the make etc let me know and I will post the details.
SARGE
AnswerID: 253023
Reply By: Ian from Thermoguard Instruments - Tuesday, Jul 17, 2007 at 20:28
Hi all,
First to Matt: Yes it does work. As decribed above, you run hot water down the side of the bottle for, say, 10 seconds, wait 10 -20 seconds, then run your fingers up & down the side of the bottle. The liquid/gas level is usually easy to find unless the bottle's either full or just about empty.
Just a thought and would welcome feedback from readers: As an active caravanner, I've had in mind for a while a remote gas bottle level detector. Nothing as flash as an ultrasonic device but rather one that gives a four or five step indication (i.e. full, 3/4, 1/2, 1/4, "not much left"). So, if this was available and safe and reliable to use in-situ in a caravan/motorhome boot/cabinet, would you buy one? Would around $100 be reasonable? I'd be pleased to receive comment on this. Ta.
AnswerID: 253029
Follow Up By: Ian from Thermoguard Instruments - Tuesday, Jul 17, 2007 at 20:30
Sugar!! I wish there was an "edit" function on this forum. Sorry for the typos and spelling mistakes.
FollowupID: 514110
