Tuesday, May 13, 2003 at 11:00
Hi again Brian
Sorry for squabbling and name throwing on your thread.
There is a specially built 3 way isolater available in the states, called a "hell roarer" or something like that. It would be perfect for you but you would probably have to sell the Nissan to afford it. Because you are intending to go outside the manufacturers of second battery isolaters design, by putting in a third, and not having it there all the time means you wont find a standard fix. I have done thesame with my caravan, and get around the difficulty of a depleted battery by swapping or jumping the second battery (not the starting one that controls my injection etc)
My advice is to persue an auto electrician or three for the best information and fix.
IMHO all the systems listed here work including that old reliable diode one from the Arc - the sure power. If it didnt, it wouldnt still be for sale.
The questions you asked originally are summed up like this...
When batteries are joined together, they try to equalise their electrical pressure. (Voltage) this is sensed by the alternators voltage regulator, and as a consequence,the alt makes more current (amps) or flow of volts available to each of the batteries. Adding a third will do thesame thing, but remember the variable here-the resistance of the length of wire and plug you are using.
It can be thought of (by us novices) as 3
water tanks on a farm. Your pump can supply pressure and flow, and depending on which valve is opened, will fill one or all together. The new electronic isolaters are like the valve that fills the first
tank full before opening a valve to fill the second
tank. Some of the first
tank will backflow to the second
tank until their levels are thesame and then the pump will fill them both up. If
tank 2 is empty when the valve is opened, a greater rush of flowing
water will come from the first
tank, if the second
tank was nearly full, a small flow of
water will result. Add a third
tank over in the next padock, and the small hose that joins it to the second
tank will dictate how much flow gets to it to fill it. Even if you use thesame size pipe as used with the other tanks, it will still effect flow rate, slowing it down. In thesame way, the third battery will be slower to charge than say the second because of its proximity to the alternator (or pump)
There is another way of looking at this Brian. When possible, have the trailer connected to the vehicle, so both trailer and second batteries are joined, that way, the trailer battery wont go flat as fast or as bad.Driving the vehicle daily will help to keep the second battery full and this will assist the trailer one when they are reconnected after the drive. Because neither is depleted, there will be minimal flow of amps between them, and less harm to either.
Andrew
Wollongong 94 fzj80 landcruiser plus caravan and 3rd battery.
12637
