Tuesday, Sep 25, 2007 at 19:37
Just because the battery is rated at 200 AH does not mean you will have to recharge it the full 200
You only have to replace what you take out of it !!
(dumb example) If it's an average 90 AH battery, and you use it for 3 x days running fridge @ 26A per day (maybe average for a fridge, numerically speaking) the 90 ah battery is close to (dead) empty, however the 200 AH battery is still way more than 1/2 full. (as I said not a literal example)
You will be able to recharge it from the Alternator, this takes time and
fuel too.
Consider a Solar system, they will replace the power used, as it's actually being used, daily, and you never have to start the engine, assuming you put more in than you remove, you have to know the specs for the fridge and lights etc to be able to answer that question.
About 120 watt panel of "quality" design will more than replace what you use - if you use a decent 3 stage solar regulator and not a budget priced on/off regulator (~$1,400)
The solar panel will run a fridge and will also recharge the battery when the fridge is NOT running, (the fridge does not run 24/7) because the sun shines ~8 hours (average) per day and the fridge is only running ~3 of those hours, and the battery will run fridge at night, so you use less than 1/2 the power quoted.
The fridge uses ~3AH (max)
The Solar delivers ~6AH
However, the Solar panel ALSO replaces the power used during the night, early the next day.
So after a month or so you have still a fully charged (agm) battery, with-out starting the engine ( if the solar puts in, more than the fridge takes out, if not then it's only a toy )
525568
