Dual Batteries
Submitted: Monday, Sep 17, 2007 at 09:37
ThreadID: 49777 Views:2372 Replies:3 FollowUps:7
Anybody out there suggest a good place to have a dual battery and anderson plug for the camper installed in the southern suburbs of Melbourne. I need it done right the first time.
TD
Reply By: Member - Doug T (Qld) - Monday, Sep 17, 2007 at 09:54
T.D
Try ARB Northern at Thomastown.
AnswerID: 262628
Follow Up By: Member - Doug T (Qld) - Monday, Sep 17, 2007 at 11:01
I know you wanted Southern but the ring road is a good run,
793 Nepean Highway
Brighton VIC 3186
Tel: (03) 9557 1888
Might be better
FollowupID: 524114
Reply By: pheonix - Monday, Sep 17, 2007 at 10:21
TD,
Try Brighton Electrical, East Boundary Rd, Bentleigh East. Had one installed in a TD Prado. A fair bit cheaper that other stores.
Graeme
AnswerID: 262637
Follow Up By: T.D. - Monday, Sep 17, 2007 at 12:39
Thanks I will give them a try and it is a new Prado I need them fitted too
TD
FollowupID: 524138
Follow Up By: Member - Stephen F (VIC) - Monday, Sep 17, 2007 at 13:58
T.D.,
I enquired about a dual battery at Brighton electrical and they recommended a simple solenoid from what i have read on this forum a solenoid is not the best option.
There number is 9570 2844
FollowupID: 524151
Follow Up By: pheonix - Monday, Sep 17, 2007 at 14:22
Stephen,
I have the solenoid and its been in for about 18 months, runs fridge, fluro no worries, just about to get them to run a cable to the rear for an anderson plug to charge battery in jayco.
Graeme
FollowupID: 524161
Follow Up By: Sand Man (SA) - Monday, Sep 17, 2007 at 16:14
But what it doesn't do is protect the batteries from each other.
All a simple solenoid does is connect the two batteries together in parallel and therefore a fault in one battery (or circuit) will drain power from the other one.
Me, I want the confidence to know that I can still start the Jack when I'm 200km from nowhere. I justified a smart controller just on that basis.
Bill
FollowupID: 524185
Follow Up By: T.D. - Monday, Sep 17, 2007 at 20:14
Sandman
I have had a solenoid system in the old Patrol for five years and no problems. The idea is that the solenoid isolates the start batery from the second one to prevent it being drained. Simple but effective
TD
FollowupID: 524230
Follow Up By: Sand Man (SA) - Tuesday, Sep 18, 2007 at 03:18
TD,
The solenoid only separates the batteries when it is turned off.
Is it manually operated via a toggle switch?
When you turn it on, both batteries will be connected to each other all the time. Should one battery short circuit, or go open circuit, or become drained when the fridge is left on too long, the result will be two flat batteries. Then you are stuffed.
A "smart" dual battery controller will keep the two batteries electrically isolated from each other so that a fault in one battery will have no adverse effect on the other. You have the ability to swap the batteries over, so you will always be able to start the vehicle to get you out of trouble.
It's your choice mate. But for me, the investment in a quality Isolator gives me peace of mind.
Bill
FollowupID: 524315
Reply By: Member - Tonester (VIC) - Monday, Sep 17, 2007 at 16:16
A little further away that directly south in Melb, but Battery World in Wantira and great. Speak to Chris.
AnswerID: 262689
