Decca AGM batteries - from USA . QUESTIONS ON FITTING THESE BATTERIES
Submitted: Wednesday, Sep 26, 2007 at 12:03
ThreadID: 50043 Views:6572 Replies:7 FollowUps:13
I am thinking of getting two of these to replace the two current deep cycle "normal" batteries (in my cvaravan) which are now six years old and must be close to dying .
The gent I spoke to gave me a choice of Life Line or Decca - both made in the USA . He told me that the Decca was a bit cheaper and was charged at the same voltage as the "normal" batteries , but that the Decca charged at a higher voltage .
A saleman could tell me anything in this area and I would have to believe him , so I was wondering if you Forumites had any comments on this .
Will I have to alter the settings on my " in van " electronics , to ensure the Decca AGM batteries charge correctly ?
I have three solar panels - an original Bushtracker installation . Can I put two 200 AH Decca batteries in , or will this capacity be too high for my charging system to handle ?
Will I be able to charge these batteries from the car's alternator ? In the tow vehicle (Landcruiser) , I have two "normal"cranking batteries and a "normal" deep cycle battery (used for running a car fridge ).
Thanks a lot ,
Willie .
NOTE : My "normal" batteries , are the old lead acid non sealed type .
Reply By: Member -Signman - Wednesday, Sep 26, 2007 at 13:19
Caravan??? Mate- have you become a 'grey nomad'???
AnswerID: 264020
Follow Up By: Member - Willie , Epping .Syd. - Wednesday, Sep 26, 2007 at 22:21
I 'm the grey Gnomad or as some rude person said , the grey gonad !
FollowupID: 525804
Reply By: Mainey (WA) - Wednesday, Sep 26, 2007 at 13:22
Willie,
what's the capacity of the original two old lead acid non sealed type "normal" batteries you presently use ??
Have you any tech spec for the two (new) AGM batteries ?
Fortunately, your Solar powered, so you will have no problems charging two large AGM batteries.
AnswerID: 264021
Follow Up By: Member - Willie , Epping .Syd. - Wednesday, Sep 26, 2007 at 22:24
The original ones are ACDELCO low maintanence "semi Sealed" ( sorry , I got that wrong before ) deep ycle marine batteries .
I cannot see how many amp hours they are .
I have no specs for the new batteries , but I guess they are on the Durst website or the Decca website . I will check it out tomorrow .
Thanks ,
Willie .
FollowupID: 525805
Reply By: Member - Olcoolone (S.A) - Wednesday, Sep 26, 2007 at 13:26
Hello Willie, with the charging most car alternators will charge that many batteries and that size.
A couple of things thou, car alternators have a duty cycle, what I mean is when they design a alternator it is olny designed to charge the main battery in the vehicle and as you increase the demand the longer it runs, the hotter it gets and then you start doing damage.
It may not happen in a couple of weeks or even a couple of years but it will happen.
I would not be overly concerned about what I said above.
The other thing is when they design a charging curcuit in a vehicle it is designed to only charge the battery between 70 to 85% full charge, this gets down to the main design critteria of the vehicle should start in X amount of times and there is no need to charge the battery 100% every time as the battery is ONLY there to start the vehicle it also gives a saftey margin in differant battery types and enviroments saving the battery from over charging and explosion.
The only way of testing a battery charge is by an electronic battery / load tester.
So your auxillary batterys will only get 70 to 85% charge off of the vehicle, the ideal way is to connect a smart charger and charge the batterys up to 100% charge before leaving home.
As newer vehicles start comming on the scene with there battery charging controlled by the engine ecu we will start to see more problems and heaaches.
I am sure alot of people will say that there vehicle charges there batterys to 100% and that they never had a problem, this may be true to a certian extent but it's how they designed it.
Regards Richard
AnswerID: 264022
Follow Up By: Mainey (WA) - Wednesday, Sep 26, 2007 at 13:52
the original Deep Cycle batteries are 6 years old, they are not dead yet, an they are hard to keep charged when compared to AGM's
something must be going right in the charging arena
obviously it must be the Solar system :-)
FollowupID: 525726
Follow Up By: Member - Mike DID - Friday, Sep 28, 2007 at 17:00
If they've lasted 6 years, then they obviously are being charged well above 90% most of the time.
FollowupID: 526011
Follow Up By: Mainey (WA) - Friday, Sep 28, 2007 at 18:14
Wonder if it's even possible to maintain a battery ""charged well above 90% MOST of the time"". . .
. . . with a generator :-((
Obviously with-out the neighbours complaining during the day lol
now Mainey, you know that's a stupid question :-)
FollowupID: 526018
Reply By: drivesafe - Wednesday, Sep 26, 2007 at 13:57
Hi Willie, first off if your current batteries are working, why replace them.
If you want to know how there going, simply go and get them load tested, this is free and will indicate whether the batteries are still up to scratch and if so, if it ain’t don’t fix it.
Next, if you have managed to get 6 years out of a set of “normal” batteries, as you put it, if I were you, when ever you needed to replace them, I would fit the same batteries again because you are quiet obviously doing something right and if you keep doing it, you can save yourself a bundle.
Last but not least. One last word of warning, anybody who posts that an alternator can not fully charge ANY automotive battery, has not got a clue about battery use.
Cheers.
AnswerID: 264025
Follow Up By: Axel [ the real one ] - Wednesday, Sep 26, 2007 at 16:00
Drivesafe , just remember that the fellow you refer to that has not got a clue about batteries /charging /voltages /Waeco fridges /alternators/ solar ect ect is an "expert" , or at least he thinks he is because he read it somewhere ,,LOL.
FollowupID: 525742
Follow Up By: Member - Olcoolone (S.A) - Wednesday, Sep 26, 2007 at 16:06
Driversafe, instead of comming on here and saying people have not got a clue why don't you have an active input as say it is incorrect and say why, so people like me who have not got a clue and others can learn from your expertise.
It seems on this forum and others you are involved with you do much the same.
With your knowledge of designing dual battery systems including controllers and you electrical engineering skills on a commercial scale I would expect more information from you to help me and other forum users undestand stuff that we have not got a clue with.
Perhaps you would like to tell why myself and many others can't get a fully charged battery in there vehicles.
Or is it top secret!
CHEERS.CHEERS.CHEERS.CHEERS.CHEERS.
FollowupID: 525743
Follow Up By: drivesafe - Wednesday, Sep 26, 2007 at 17:32
Olcoolone, I don’t consider myself to be an expert but I do have a working knowledge of matters pertaining to this field while you come on as an a self proclaimed expert in a field you quiet obviously have very little knowledge of, which in itself means nothing, but when you continually make statements that, to put it mildly, are grossly inaccurate and in some case will simply have people, who have come to this site for genuine help, thinking your advice is correct and go off and spend hard earned money for nothing, it is the moral obligation of anyone with any real knowledge of this subject, to correct you.
This has been done before in other threads on this site but you simply persist in making up false statements and then when you are labelled for what you are you make out you are ill done by.
Don’t make out you would accept being corrected because you have been repeatedly corrected by myself and others and you simply ignore the info being put forward and continue to post information that has little resemblance to the true facts of the subject being discussed or you simply think it’s great to amuse yourself at the expense of else’s genuine request helpful information.
If you don’t like being criticised, stop trying to mislead others.
And for the benefit of others, my apologies.
FollowupID: 525756
Follow Up By: Mike Harding - Wednesday, Sep 26, 2007 at 21:25
Having read a number of his posts I'm inclined to think drivesafe knows what he is talking about when it comes to batteries, 12V systems and similar thingies.
Mike Harding
FollowupID: 525789
Follow Up By: Mainey (WA) - Thursday, Sep 27, 2007 at 13:44
. . . . . . . . I agree with Mike & DS :-)
DS, 'apologies' are not required when giving honest & accurate advice.
FollowupID: 525892
Reply By: Sand Man (SA) - Wednesday, Sep 26, 2007 at 19:44
One of the biggest culprits in the misunderstanding of charging issues is the FAQ out out by www.batteryfaq.org/.
Quote:
"14.2. MYTH: Driving a car will fully recharge a battery.
False! There are a number of factors affecting a vehicle charging system's ability to recharge a battery, such as how much power and charging voltage from the alternator is diverted to the battery, how long the power is available, and the temperature. Generally, idling the engine or short stop-and-go trips during bad weather or at night will not fully recharge a car battery or will leave your battery undercharged which causes sulfation. When a dead battery needs to be recharged, it is best to use an external battery charger because you could overheat and damage your vehicle's charging system and your will save a lot of gas and wear and tear on your engine."
Now this is very badly written indeed and gives the impression that many people sprout on this and other forums.
You need to read the full statement in its entire context and then think about what it actually says.
What it does say that in certain conditions, e.g. stop/start trips during bad weather, or at night, will not fully charge a car battery and this makes sense when used withing the criteria stated.
What it doesn't say (but perhaps should) is that a partially discharged, but otherwise healthy battery, can obtain a full charge from the alternator if certain (normal) conditions are met.
These conditions are basically that the charging rate going into the battery need to be higher than that being drawn out of it by other devices and given sufficient time, a full charge can be expected. a wet cell battery will take longer than an AGM type battery as the AGM can (will) receive a higher charging rate.
It is indeed unfortunate when a URL site issues "misleading" information due to poorly written statements.
Bill
AnswerID: 264066
Reply By: Member - Willie , Epping .Syd. - Wednesday, Sep 26, 2007 at 22:35
The gent that sold me the caravan , reckoned that the batteries must need changing as they could lose the plot out in the never never on the next trip .
Maybe I am a worry wart and should leave them until they finally die .
A big question still remains though . When I do change them to the Decca AGMs , how big can I get them - I mean what is the max amp hours I can get in the new batteries , that the three solar panels can charge successfully ?
Thanks ,
Willie .
AnswerID: 264095
Follow Up By: drivesafe - Wednesday, Sep 26, 2007 at 23:00
Hi Willie, if your solar panels are maintaining your present batteries than there is no reason why you can’t achieve the same results if you change to the Decca batteries.
Now this is a bit of a simplification but if your solar panels are capable of replacing the amount of power you are using now, then as long as you don’t increase you power usage, your solar panels are still going to be replacing the same amount of power, no matter what type of batteries you use.
Cheers.
FollowupID: 525812
Follow Up By: Muddy doe (SA) - Wednesday, Sep 26, 2007 at 23:04
To answer that Willie, to me battery capacity is much the same as a water tank. They have a rated AmpHour capacity (my Trojan wet cell deepcycle is rated at 115AH). That is just like saying the water tank will take 100 litres.
The bigger the physical size of the battery the more lead plates it will have and the more capacity it can store. I saw a 450AH battery at the 4WD show. Great! but it was about 4 foot long and 100kg and would fill half the camper! Depends on the space you have to fit it. If it has to go in a standard 12" battery tray under the bonnet the 115 AH is going to be about the max (that I have found).
As far as charging goes, it is just like a hose. The bigger the hose you have pointed into the water tank and the more pressure can be applied from the source then the quicker the tank will be full.
For a battery it is similar, run a nice fat cable from your charging source (altenator, solar panel, 240v charger) and pump those Amps in there. Just as fast as the source can produce them. Naturally there may be limits, AGMs apparantly can take the charging amps quicker than standard wet cell batteries. Solar tends to be a fair bit slower than an altenator or generator/charger but goes all day (hare v tortoise). If you manage to get 3/4 charge into them with the solar in a day then so be it - as long as you are staying in front of the amount of Amp hours that you take OUT of the battery bank then you are fine. Same as the water tank!
There are complications such as how fast you suck the power out. 115AH @ C20 rate (taken out over 20 hours) may only be 100AH at C10 or 90AH at C5. The quicker you take it out of the battery the less you get. But to keep it simple - just think of the battery bank as a big power tank. If you put it in you can take it out.
Hope that helps.
Muddy
FollowupID: 525813
Follow Up By: Mainey (WA) - Thursday, Sep 27, 2007 at 13:52
yeah, pretty well what he's said :-)
Willie, if you can charge the DC battery system now, then with the AGM DC's it will be even faster and you won't need as many 'sunhours' per day to get the same charge into the AGM's.
FollowupID: 525894
Reply By: Member - RnR (NSW) - Thursday, Sep 27, 2007 at 09:58
Willie,
Why not ask this question on the New Bushtracker forum.
http://www.bushtrackerownersforum.com/viewforum.php?f=34
You will probably have Steve Gibbs reply to your query
RnR
AnswerID: 264153
