Thinking of BFG TA Tyres over coopers
Submitted: Monday, Oct 29, 2007 at 08:46
ThreadID: 51031 Views:6075 Replies:9 FollowUps:10
Ok, so thanks to all the negative remarks over coopers, I am now swaying towards the BFG tyres for my 99 Patrol, who has an opinion on these? It will be for some camping and occasional off roading, but mainly on road. Are these ok for sealed roads with noise and wear etc?
I know they are overkill for mainly onroad this but want a good AT tyre instead of a HT for the big road trips, corrugated roads, off roading etc.
thanks a lot
Justin
Reply By: flappa - Monday, Oct 29, 2007 at 08:57
I'm a big fan of BFG AT's.
Been using them for many years on all my 4wds.
IMO , they are a very good allround tyre.
To get good wear , I would recommend making sure you rotate the tyres regularily.
AnswerID: 268889
Reply By: QLD Kev - Monday, Oct 29, 2007 at 09:00
I have had BFG AT's on the Triton for over 50 000km and they are wearing well. I do occasional offroad and mostly on road city driving ATM and I love them.
The new cruiser has Cooper ST's on it so I will see how they go, if they are crap I'll put BFG AT's on it.
Cheers Kev
Russell Coight:
AnswerID: 268890
Reply By: MEMBER - Darian (SA) - Monday, Oct 29, 2007 at 09:01
We have put our faith in the BFG AT's and never been let down - yet to have a flat. We are conservatice drivers, and take it quite easy on the stony surfaces outback - adjusting pressures as indicated - you should get 80,000km at least from a set you look after. One thing - because of the robust wall construction, they give a very firm ride on the blacktop, but its a mistake to reduce pressures - shortens their life.
AnswerID: 268891
Follow Up By: Member - Denis G (QLD) - Monday, Oct 29, 2007 at 10:43
Agree entirely - have used nothing else on my last 4 L' cruisers (nms much pressure from a mate who sells Coopers), and it has been nothing but a pleasure. Agree regular rotation (<every 10,000 kms) prolongs life, as also sensible pressures, and 80,000 kms is not at all unusual. Use mine as a daily commute - and at least one long (3 week) off road trip , and a couple of shorter ones, each year.
FollowupID: 531678
Follow Up By: Andrew from Vivid Adventures - Monday, Oct 29, 2007 at 17:58
"its a mistake to reduce pressures - shortens their life"
Now now Darian. That is a pretty inflamatory statement.
Which pressures were you talking about? Under what conditions? With what load?
Without those caveats you might be shortening the passenger's lives.
FollowupID: 531750
Follow Up By: MEMBER - Darian (SA) - Monday, Oct 29, 2007 at 18:48
Inflamatory statement ? No - inflatory maybe :-o) ...... if you run BFG's in the mid 30 psi range around town, the shoulders will wear out while useful tread remains in the centres - to gain even wear across the face, the pressures need to be 40 psi at least in my view, hence the firm ride. I recall others here saying the same -reducing the BFG pressures for town travel won't soften the ride much - while rated to 65 psi, safety is not an issue (all other things being equal) - when in the bush on mixed surface gravel roads, my whole approach changes - pressures there range from about 25 psi through to the low 30's.
FollowupID: 531764
Follow Up By: Andrew from Vivid Adventures - Monday, Oct 29, 2007 at 19:18
That is nice to hear and I think the clarification helps a lot.
The pressure should be related to the load... over-inflating tyres can result in uneven wear too.
The important thing it to know how bagged your tyres should be for the circumstances... load, road, speed...
FollowupID: 531770
Follow Up By: Members - Bow - Monday, Oct 29, 2007 at 22:48
I run BFGs at 30psi round town and on the open road and have never had a problem with wear on the shoulders.
Higher than 35psi the ride is to hard.
FollowupID: 531851
Follow Up By: Andrew from Vivid Adventures - Monday, Oct 29, 2007 at 22:55
But Bow, that is exactly why little snippets of information does not make for good practice for everyone.
30psi for you won't be enough for my even partially loaded 100 Series... it can be seen how much the tyre have bagged. When they are that bagged life might be fine 80km/h on dirt roads, but when I am on the bitumen at 110km/h, the sidewalls don't have the necessary rigidity to carry the load...
Suppliers do provide dealers, or can provide dealers with details of what PSI for what loads, but poor old dealers don't get the full details from their clients about what loads they are carrying on their axles...
Everyone's mileage will vary, to coin a phrase... what is good for someone else it not what's right for you.
FollowupID: 531855
Reply By: splits - Monday, Oct 29, 2007 at 11:04
Justin
I am new on this site and I have been spending a lot of time in the last couple of weeks reading through the archives. I have noticed when it comes to tyres there are plenty of comments both for and against every brand on the market.
In my younger days I have worked in the motor industry in both the Riverina area of NSW and the Snowy Mountains. I am now back near Sydney. I do not believe there are any bad tyres but there are a hell of a lot that are used for the wrong purpose or are driven in a manner that takes them outside their design limits. In over forty years of driving I have used all of the popular brands on both sealed and unsealed roads and I have had a good run out of all of them. While in WA in the early 1970s I even bought four 6.40x13 no frills el cheapo cross plies for my EH Holden then got 32,000 miles, not ks, out of them and that included two trips over the Nullarbor when 500 ks of it was still unsealed.
I would suggest you do a couple of things. The first is to select tyres with the highest load ratings possible then keep the car well within those limits. These load rates can vary a fair bit between tyres of the same size but different brands. Don't overload the car, pay close attention to pressures and don't drive like a bat out of hell over unsealed roads. I have seen plenty of damage caused to tyres, wheels, shocks, shock mounts, spring hangers etc by people doing that in an attempt to get a smooth ride by "floating" over the surface. You might feel comfortable inside but you are giving the car and tyres hell underneath.
Another thing is remember the old saying about what to do when in Rome. If you want to drive on mountain tracks then ring a couple of tyre dealers up in the Snowy and find out what tyres the local people use. Do the same in the Outback and ring dealers out there. When you go into those places you want something that works and is readily available if you need a replacement and speaking to the people who live, work and drive in the area is the best way to find out.
Brian
AnswerID: 268907
Follow Up By: Member - George (WA) - Monday, Oct 29, 2007 at 18:39
A very sensible reply, could not agree more
FollowupID: 531763
Reply By: Member - joc45 (WA) - Monday, Oct 29, 2007 at 11:38
I fitted BFG ATs to my Patrol new in 2000. Got about 95000 out of the set of 5, but admittedly, that did include a few kms of a 6th one after wrecking one of the originals. At 95000, bought a set of 4 and am about to replace them after 80,000 for the four. Will certainly go for them again. I also had them on my earlier Maverick on split rims and was very happy with them.
I find that they balance well,wear evenly and have had no probs with the so-called Patrol front-end wobble syndrome I hear so much about.
Gerry
AnswerID: 268908
Reply By: Bob Y. - Qld - Monday, Oct 29, 2007 at 13:05
Justin,
We used BFG AT's on an 80 series for about 9 years, doing about 200K clicks in that time.
Had a few flats, mainly due to nails, welding rods etc, and never had a blow-out. They are as good as mentioned above in other replies, though we never got the high mileage others have claimed. Mainly due to wear on stony roads, and high-ish speeds during hot weather.
They don't like stony roads, and chip badly on these roads. Otherwise very good tyre.
Ran them (265.75R16) @ 32psi almost all the time, and the wear was very even. Definitely worth a try,
Hooroo...
AnswerID: 268916
Reply By: Member -Dodger - Monday, Oct 29, 2007 at 17:03
I have used BFG tyres on most of my 4wd vehicles and have found them to be reliable.
On my present vehicle the BFG's have currently done a total of 60k and are just about shot but will still use them for a few more k.
I the AT KO series from US not the Jap or Korean ones.
Cheers Dodg.
AnswerID: 268944
Reply By: justin71 - Monday, Oct 29, 2007 at 18:50
Thanks a lot for all the input guys.
I wanted to ask a question regarding the ply of the tyre, the Atkos are 6 ply according to tyrepower and the Cooper ATs are 10 ply.
What does this difference atually mean in the real world? The BFGs look tough as steel so it surprised me they werent 10 ply like the coopers.
thanks
Justin
AnswerID: 268967
Follow Up By: Andrew from Vivid Adventures - Monday, Oct 29, 2007 at 19:34
looks can decieve ;-)
The "ply rating" is an international standard rating - no longer is it the "actual" number of layers in the construction, but the stiffness of the construction compared to a notional number of layers in a typical tyre construction.
Not all Cooper ATRs are rated at 10 ply either... Cooper ATR Tyre Specs
In the real world lower rating could mean more proness to staking and less load bearing capacity... but the load bearing capacity is best determined by the load rating these days.
FollowupID: 531779
Follow Up By: justin71 - Monday, Oct 29, 2007 at 20:57
Hi Andrew
Thanks for the message and the info, its a shame its not still the "actual" number of layers, thats certainly what the name "ply" indicates, layers. The cooper I was referring to is a 265 75 16 which is a 10 ply according to the info. I am going to check out the load ratings of the tyres now. Someone once mentioned to me that its better to have a 75 instead of 70 tyre on the patrol, I cant remember the exact reason, what do you think?
Justin
FollowupID: 531819
Follow Up By: Andrew from Vivid Adventures - Monday, Oct 29, 2007 at 21:23
The reason the ply rating is not actual layers these days is that technology has moved well ahead of canvas layers crossed at 40 degrees to each other... but the ply rating was the common point of comparison. (Thank God I say, but Willem will differ)
The load rating, however, has largely replaced it in purpose, and is more relevant.
It really feels like you need to get good advice from your dealer - if it doesn't correspond with what you hear here, by all means validate it, but there are a lot of considerations.
Your activities. Your wheels. Your suspension. Your load. Effects of changes in rolling diameter on performance. The law. How much space you have in your wheel well... to name a few.
You get a little clearance with bigger tyres.
You gain a little load bearing capacity usually with bigger tyres.
You add a little extra unsprung weight with bigger tyres.
You get a little higher gearing from bigger tyres.
You lose a little power (effectively) with bigger tyres.
You pay a little extra with bigger tyres.
For me, I drive larger than standard tyres on my 100 series 1HZ - I run Cooper STTs (John R from Vic thinks this is a paid advert so I'll get my money's worth) and LT285/75R16 specifically. I put up with the higher gearing, the speedo under-reporting, and slow driving up the bigger hills... and I get to take the cruiser anywhere I have wanted to.
FollowupID: 531829
Reply By: TD100 - Monday, Oct 29, 2007 at 20:53
Hi All,i have also run BFG A/Ts and Muddyies on 60s,80s,100s and hiluxes and had excellent results on all vehicles with either style,the only gripe is the muddies are very noisy,so when due for a set of muddies for the 100 series a friend of mine said try a set of Procomp mud terrains in which i did(i know iknow they are made in the cooper factory but on different line and spec)and have had an excellent run sofar with them(45k on them and expecting another 30 odd k)some fair chipping and small chunks out of rears only after last simpson expedition.fronts still perfect.as for noise they are less than half the racket of the BFGs,so next muddies i think will be the procomps again as no punctures nor other problems.thats my 20c worth anyway cheers Paul
AnswerID: 269005
