Surge Protection.
Submitted: Saturday, Nov 03, 2007 at 08:36
ThreadID: 51222 Views:3546 Replies:5 FollowUps:7
Hi, is it safe to charge a lap top using a modified sine wave inverter and using a 240v surge power point protector.Thanks Bat.
Reply By: Bonz (Vic) - Saturday, Nov 03, 2007 at 08:42
well of course its safe to do so, but the surge protector would never do anything as the inverter would barely have enough oomph to create a surge IMHO
AnswerID: 269830
Reply By: Footloose - Saturday, Nov 03, 2007 at 08:48
Others might say they get away with it, but I wouldn't use a mod sine wave inverter to power any electronics. I've seen too many blown power supplies as the result of using them.
AnswerID: 269831
Reply By: Sand Man (SA) - Saturday, Nov 03, 2007 at 09:36
You don't need a 240 volt surge protector in my opinion.
The source supply is 12 volts and is unlikely to "surge" to any large amount.
The standard laptop power adapter (switched mode power supply) which you would still use, will filter everything anyway and the majority of these will run successfully from a modified sine wave inverter.
Now having said that. Why use an inverter anyway. You are taking a 12 volt DC input, converting it to 240 volt AC output, then feeding this into the laptop power power adapter which converts it from 240 volts AC back to a DC voltage of whatever value required for the Laptop. (somewhere between 12 volts DC and 19 volts DC. This seems to be a waste of energy, plus you need room to contain the inverter.
Unless you have a really weird laptop, a "laptop adapter" is a much better proposition. Something like the Kerio adapter from Dick Smith's comes with a variety of different "blades" to set the output voltage to your laptop's specific voltage requirement and is very compact in size.
About the only laptop that won't allow it's internal battery to charge from the adapter is a Dell, although the laptop can still be powered successfully. The Dell has it's own proprietary method and only a Dell adapter (which I use) will charge the battery as well as power the laptop.
Bill
AnswerID: 269837
Follow Up By: swampy66 - Saturday, Nov 03, 2007 at 10:10
Sand man,
could you please give a little more information about how you power the dell. ive been trying to run my laptop from my adapter (12-24v) as you mentioned above.
im using an original Dell connection and have joined positive and negative to this connection.
when i plug it in, it knows im not using a Dell 65w charger - yet the laptop still powers up and charges at 19v.
my original 240v charger is 19.5 output. the laptop is an Inspirion 6000.
i suspect this all has something to do with the centre pin.
Swampy
FollowupID: 532740
Follow Up By: Member - Olcoolone (S.A) - Saturday, Nov 03, 2007 at 10:59
Go and your self a proper Targus notebook car charger, they cost about $100.00.
I agree with what sandman said and can not understand why people insist on using 12v to 240v inverter and then the 240v to 19v (or what ever your lap top runs on) factory supplied power supply.
The Targus charger we use is only about 100mm long, 15mm thick and 40mm wide and will deliver 10 amps at around 19 volts.
Regars Richard
FollowupID: 532752
Follow Up By: swampy66 - Saturday, Nov 03, 2007 at 11:07
Rickard,
Are you running a Dell laptop with your Targus notebook car charger?
The laptop car charger i'm using works fine on other laptops, but i want to hear from people using it with Dell laptops.
swampy
FollowupID: 532757
Follow Up By: Member - Olcoolone (S.A) - Saturday, Nov 03, 2007 at 12:03
"but i want to hear from people using it with Dell laptops."
Im so sorry swampy.....but I was not replying to your post I was refering to the original post and sandmans!
Ill make sure I don't make this mistake again so sorry.
FollowupID: 532766
Follow Up By: Mainey (WA) - Sunday, Nov 04, 2007 at 12:33
I run my DELL Inspiron 6400 from my 300 Watt Cotek pure sine wave inverter without problems, that's what they are designed for.
I don't have to worry about Computer warranty problems either, as I asked that question of the DELL technical (not sales) staff before I bought it, I was advised not to use a 12v charging system.
FollowupID: 532943
Follow Up By: Sand Man (SA) - Monday, Nov 05, 2007 at 11:17
Hi Swampy,
My Dell Laptop is a Model 6000 Insiron and one of the accessories available for it was a "replacement" Auto/Air adapter. (model HP-AF065B83)
It looks the same as the standard power adapter but by replacing the 240 volt AC power cord with a cord that plugs into 12 volt, or an airplane socket, the adapter configures itself to run from those power sources.
It's the only adapter I need to use now, wherever I am. Cost was around $90 when I bought it online.
Couldn't see it on the Dell web site but maybe a call to them may give an answer as to their current availability.
Bill
FollowupID: 533129
Reply By: Steve - Saturday, Nov 03, 2007 at 15:51
surely it depends upon the power source. If it was, for instance a GMC gennie with it's volatillity, then maybe it would be relevant to run: Gennie-surge protector-inverter-Laptop. That's my understanding, anyway - but I may have mis understood the question.
AnswerID: 269880
Reply By: Motherhen - Saturday, Nov 03, 2007 at 17:26
We got a pure sine wave inverter for the laptop - not worth risking loosing an expensive laptop for want of a $300 investment (which is more than adequate for the laptop - we could have gone smaller). We kept the old modified square wave one as it is fine for charging batteries. They are set up in the caravan, so we had the room for both.
AnswerID: 269896
Follow Up By: Member - Graham H (QLD) - Saturday, Nov 03, 2007 at 18:06
I use a Projecta D6000 12 v 6 amp power supply. $69 at Battery world
Depends on the laptop but mine gasps on the smaller 4amp one and had to upgrade.
I have a Compaq Core duo 1.73 so needs a bit of grunt o keep it going.
If you are worried about the battery just remove it and run on the power supply.
It wont hurt it and before I did that I rang the service center who confirmed the fact.
FollowupID: 532809
