Dometic Diesel Heater - Just got one put in - what a beauty !
Submitted: Friday, Nov 16, 2007 at 10:37
Member - Willie , Epping .Syd.
Yesterday I picked up Elvis from Barnes Caravans in
Sydney . They have installed a Dometic diesel heater to warm my old bones during winter on the WA goldfields .
It is such a small unit but produces an amazing amount of heat in the 16 foot van . On low setting it uses only 110 ml of diesel an hour and the
tank which holds 4 litres , is filled through an external filler port .
I had it installed in the rear compartment and the hot air blower is situated at floor level , near my bed .
Luxury !
Willie .
Reply By: Member - Ian W (NSW) - Friday, Nov 16, 2007 at 10:53
What a coincidence. Willie, I was just sitting down to Member Message you to enquire if you had as yet had your heater fitted.
Do you have ESP or something?
Ian
271989
Follow Up By: Member - Willie , Epping .Syd. - Friday, Nov 16, 2007 at 15:20
Ian ,
Did you have a question ?
Willie .
535157
Reply By: Member - JohnR (Vic)&Moses - Friday, Nov 16, 2007 at 15:01
Do yourself a favour Willie and fit a bigger
tank. I have a 12 litre
tank. Do you have a timer to shut it down again or is it permanently switched?
272030
Follow Up By: Member - Willie , Epping .Syd. - Friday, Nov 16, 2007 at 15:18
Hi John ,
I do not have a timer . Are you sure I would need a bigger
tank ? This one theoretically, will give me 4000 divided by 1100 - 36 hours on low setting .
I would only have it on for half an hour in the morning and bugger all at night . I don't spend much time in the van unless it's raining .
What have you found out in your usage ?
Thanks ,
Willie .
535156
272031
John,
You have a stutter !
535158
Follow Up By: Gramps (NSW) - Friday, Nov 16, 2007 at 15:50
It's an echo
535163
