Power off whilst away for a while?
Submitted: Sunday, Nov 18, 2007 at 19:16
Steve
As we still have the little Angels at home we're limited to school hols and don't get away for long periods. We're planning a trip to the Red Centre in winter for about 5 weeks and wondered if it was worthwhile switching the electric (off peak)
water heater off) or am I only saving $12 for the trouble?
Reply By: Member - Andrew (QLD) - Sunday, Nov 18, 2007 at 19:24
What trouble? It's only a switch.......turn it off and enjoy your holiday.
Andrew
272367
Follow Up By: Steve - Sunday, Nov 18, 2007 at 19:56
I suppose I was thinking of coming home to cold
water but I'm sure we can arrange for somebody to come and switch it back on the day before we get home. Just never been away for more than two and a half weeks.
535638
Follow Up By: QLD Kev & Darkie - Sunday, Nov 18, 2007 at 20:05
So your not going to have hot
water on tap for 5 weeks what is another night with out??
While your at it why not turn the fridge and freezer off and the other electrical items (TV, Computer etc) off at the wall.
Cheers Kev
| Russell Coight:
535639
Reply By: Motherhen - Sunday, Nov 18, 2007 at 20:00
Yes Steve, switch it off. I have known unexpected leaks to cause a larger than usual power bill while people have been away.
272376
Reply By: Steve - Sunday, Nov 18, 2007 at 20:08
This year was the first time we'd not been away in winter for a long time and the difference in the home electric bill was an eye opener....and that's without turning the
water heater off when we do go away so I imagine it'd make an even bigger difference switching off.
272382
Reply By: obee - Sunday, Nov 18, 2007 at 20:36
WE shut the gas off and could not get
the pilot to light up again on return. I dismantled the mechanism and put compressed air to the tube and cleared the problem. I should do house calls.
Owen
272396
Reply By: Stephen M (NSW) - Sunday, Nov 18, 2007 at 22:43
We turn every thing off except the fridge/freezer. As mentioned above you will be pleasantly surprised at your next electrical bill with the hot
water system not cutting in to heat up
water your not going to use. Maybe if you have nice neighbours you could ask them to flick the switch back on for you the night before. We also pull the plugs on the FM aerial (stereo) and the TV's incase of electrical storms (lightning) not that Im worried about the TV going bang as a new one would be nice but incase it starts a fire.Not sure if that can happen or not ?? Rgards Steve M
272427
Reply By: Sand Man (SA) - Monday, Nov 19, 2007 at 01:05
Well we don't turn anything off.
The only "active" appliance would be the hot
water service.
Look at it this way. The
water heats up until the thermostat registers optimum temperature then switches off power to the heating element.
If you don't use any hot
water, the next cycle should be shorter as the
water doesn't need to be heated as much. (no cold
water has been added to dilute the hot
water)
If you have an off-peak meter, which uses cheaper electricity than normal, you wouldn't be saving much if any at all, by turning the hot
water service off.
When you arrive home and turn the hot
water service back on, my thoughts are, you would not get HOT
water during the first 24 hours. The timer for the off-peak meter would not be set long enough to heat the quantity of
water in the storage
tank. (probably no more than a 6-8 hour cycle)
Therefore the heating element would run flat chat for the first and maybe most of the second cycle to reach the temperature where the thermostat will switch off the power and therefore, probably using up as much electricity as it would have used if you just let it "short-cycle" each day.
That's my thoughts anyway.
272447
Follow Up By: Steve - Monday, Nov 19, 2007 at 08:11
Your argument is a bit like whether to turn off the Waeco/Engel overnight or not. There's a case for and against but then there is the safety issue I suppose.
535721
Reply By: AdlelaideGeorge - Monday, Nov 19, 2007 at 08:03
We built our home and it's now 7 years old. last weekend We noticed
water streaming out through mortar joints and under the bottom of an outside wall where it abutts the verandah surface. $300 odd dollars later a burst had been fixed by our friendly local plumber. The burst occurred at
the junction of 'plastic' piping and copper piping - a ferrule had simply split and let go the coupling.
We got to wondering what damage might have been caused if it had happened last July/Audgust when we were away for 3-1/2 weeks in the 4x4.
We'll be turning the hot
water heater AND the
water off in future.
happy days
George
272464
