O/T:IE7 question
Submitted: Sunday, Nov 25, 2007 at 18:37
TD100
Evening all,windows did its usual update the other day and also asked if i wanted to update to IE7 (guessing mines about 5?)ahhh why not,5 minutes later no worries restart your computer WELLLLLLLL let me tell you it chucked an absolute mental,couldnt open things,couldnt get into anything.panic stations wooop wooop what now?after 45 minutes of restarts and trying to get into my computer i did a system restore to 2 days earlier and walah all OK.has any one else had IE7 do this?it asked me today if i wanted to install it but it can #@&! right off,not after last time.not being a computer efficionado(spelling?)i managed to escape this one this time!any help/feedback would be appreciated cheers Paul
Reply By: Willem - Sunday, Nov 25, 2007 at 18:46
I had all kinds of hassles with IE7. I then uninstalled it and reverted back to IE6, which runs sweetly on my computer. Update isn't always upgrade....lol
273642
Reply By: Member - 'Lucy' - Sunday, Nov 25, 2007 at 19:13
There is not enough or adequate, derogatory, abusive etc etc words in the English Language to describe IE7.
I just switched to FireFox and all is fantastic AND NO drama's in doing so.
Micro Soft have finally emulated the Do-do bird with IE7 - you know! constantly turning circles till their heads have gone up their (you know what).
273649
Follow Up By: Member - MR 1927 - Sunday, Nov 25, 2007 at 19:18
I run both IE7 and Firefox and I have no trouble with either. I believe Firefox provides more features and I use it most of the time.
I run Vista home premium.
537039
Follow Up By: Member - Longtooth (SA) - Sunday, Nov 25, 2007 at 20:17
No problems here with IR7 either.
537057
Reply By: Member - Sam (NSW) - Sunday, Nov 25, 2007 at 20:42
Paul,
I am assuming you are running XP (which came with IE 6 from memory)
Do you have XP Service Pack 2 installed plus all the other updates? If some of these are missing, you could have problems, although I would expect Windows Update or IE installer to work this out - but we are talking about MS aren't we.
It might also pay to download the standalone installer for IE7 rather than letting windows update do it.
Also, is your version of Windows legit? This can also cause issues.
273661
Follow Up By: TD100 - Sunday, Nov 25, 2007 at 21:20
Hey Sam,
yeh i am running XP,it is a legit windows program and have s/pack 2,all the latest updates available.dont know why it did what it did but i might try the standalone update IE7.cheers Paul
537080
Follow Up By: Sand Man (SA) - Monday, Nov 26, 2007 at 09:16
No, No, don't do it TD,
You made the correct decision to back out. Leave it at that mate.
There are two ways to back out of IE7.
The first method is to simply uninstall Internet Explorer. Because you can't delete IE6, this method will uninstall IE7 and leave IE6 as it was before the "upgrade".
If for some reason you can't uninstall, restore Windows to a pre-IE7 upgrade level via system restore function.
I too tried IE7 and didn't like it. It wasn't causing a problem but I just didn't like the new "features". IE6 works perfectly
well and gives you all you need.
537127
Reply By: Member - MrBitchi (QLD) - Monday, Nov 26, 2007 at 09:43
If you want to use IE7 then I suggest the only time to load it is with a fresh install. DON"T use Windows Update to load it! That's the only way I've had any success with it. Runs fine that way.
Firefox is better though ;-)
273714
Follow Up By: TD100 - Monday, Nov 26, 2007 at 21:21
Mr B,
tried that too but it still had a coronary,so bugger it im stickin with IE6!!cheers Paul
537198
Reply By: Truckster (Vic) - Monday, Nov 26, 2007 at 13:35
Its a feature
273735
